patrice f.
Soundcare standard
Dimitrios K.
Neotech usb cable
Pierre H.
Condo Mundorf 22000µF/63V
Cyril K.
broches a souder
Un connecteur de bonne qualité,mais les broches a souder sont trop petites ,il manquerait également une clé Allen pour viser le corps du connecteur.
Robert C.
AUNE AR5000 Open-back Dynamic Headphone Ø50mm 28Ω 108dB 5Hz-41Khz Aune's AR5000 are open-back headphones with a dynamic MLD ("Multi-Layer Distributed") driver of no less than Ø50mm. Thanks to its innovative driver, high-tilt acoustic...
True reference performer
Neutral, transparent, never harsh sound.
Very solid and robust aluminum design but yet comfortable.
I'm using these as reference headphones in my system.
Highly recommended.
Robert C.
Nice little Class D amplifier
I'm really satisfied with Fosi Audio ZA3 stereo Class D amplifier. It is very flexible and capable amplifying solution.
For the price I don't have any remarks.
My recommendation for further improvements in SQ domain is to use more quality OPAs (e.g. Sparkos).
Jean-Pierre D.
PANGEA PREMIER SE MKII HDMI 2.1 Cable Silver Plated Cardas Copper 8K 60Hz / 4K 120Hz HDR 48Gbps 1.5m With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper...
correctif avis
Malheureusement, ce câble a été défaillant, mauvaise qualité de la soudure d'un des contacteurs, c'est dommage, autrement il était bien. Peut-être défaut de fabrication....
Zsolt B.
Elecaudio
Nagyon jó termék!Az üzletet is nagyon ajánlom mindenkinek!!
Gyors,korrekt és jó árban vannak a termékek.
Norbert R.
XANGSANE SP-8525 Speaker Cable Silver-Plated OFC Copper 2x2.5mm² This Xangsane SP-8525 is a speaker cable whose conductors are both made of 7 strands of silver-plated OFC copper for enhanced conductivity. The...
Excellent cable!
Fast delivery, great service! Excellent cable at a very fair price. Signal flow direction impressed. Great to work with, great sound. I would happily buy here again
Edgar T.
The best amp/dac for the price.
I use it when I'm working.
It has an amazing sound. The connections are very good. All the youth problems reported are already corrected. I am very happy with it. Recommend.
Edgar T.
Does it job well.
Inexpensive and works very well.
Christophe M.
DESCRIPTIF CONFORME
Belle scene sonore, belles définition, belle musicalité, bref dans la lignée de qualité d’écoute de ce fabricant et comme toujours à prix imbattable. Privilégié au Genalex Gold Lion qui est déjà une très belle référence. Installé sur mon préamplificateur Aesthetix, les tubes livrés fonctionnent parfaitement (4éme série de tube commandée chez Audiophonics et parfait fonctionnement pas comme chez TAD). Appairage pas nécessaire pour un préamplificateur, la balance est respectée. Donc sans hésitation.
Patrice P.
FIIO BTR7 Portable Headphone Amplifier DAC 2x THX AAA-28 2x ES9219C Bluetooth 5.1 aptX HD LDAC 32bit 384kHz DSD256 With the BTR7, FiiO offers a high-performance portable headphone amplifier and DAC with a modern design. It is ideal to accompany a smartphone, in order to enjoy a high quality...
top Produit
Audiophonics est une très bonne entreprise, très bon suivi client, très bon produits, livraison rapide.
J'ai acheté le Fiio BTR7 qui est un excellent DAC avec batterie, très bonne musicalité, super puissance, bref que du bon, mieux encore que le KA5.
Cyril B.
NEUTRIK NTP3RC-B Jack 3.5mm Connector 3 Poles Stereo Angled Gold Plated Ø4.5mm (Unité) This 3.5mm NTP3RC-B jack connector from Neutrik has 3 poles with gold plated contacts, ensuring good conductivity but also excellent oxidation resistance. The connector body is...
Petit mais fragile
Très court, donc pratique s'il vous n'avez pas beaucoup de place.
Par contre je confirme l'avis précédent, dans un Fairphone 3 et un LG si vous laissez la coque le connecteur ne s'enfiche pas à fond.
Pour finir, le conception est limite, j'ai abîmé le pas de vis qui permet de vérrouiller la partie du bas avec le coude.
Stéphane t.
LINDY CROMO LINE Interconnect Cable RCA-RCA Copper Gold Plated 3m (Pair) The Lindy Cromo Line RCA cables benefit from a beautiful design quality. Its conductors are made of Copper ensuring a very good conductivity and its connectors plated with 24k...
Image trompeuse
Il fait le taf, mais esthétiquement parlant je suis très déçu, sur la photo on a l'impression que la câble a un diamètre conséquent, dans la réalité, il n'y a qu'un seul câble qui se dédoublent en y au niveau des prises et son diamètre est très très petit, c'est un produit très bas de gamme, je doute qu'il y est le moindre blindage.
Guy H.
Audiophonics AP300 S250NC
Reçu hier après midi et aussitôt mis en service. Branché sur un ampli Musical Fidélity M3i très sympa mais un peu trop juste pour mes enceintes KEF Q900 . A la mise en route bonne surprise . Mes enceintes aiment ça, Les basses moins lourdes et plus punchy et plus de dynamique pour la rythmique et de détails mais les aigus un peu trop présent à mon goût ... Mais au bout de 24h de fonctionnement c'est beaucoup mieux donc nickel. Mes doutes étaient bien fondés . Ils leur fallait du jus aux Q900.
Ilari M.
Thats send my Audiophonics ncx600 amlifier to new level.I give 10 points;-)
Vincent S.
Très bonne qualité sonore pour le prix
Ce petit ampli a une qualité sonore très bonne pour sa taille et son prix. Je l'utilise avec des enceintes bibliothèque Focal. Je le recommande !
Kresimir M.
DYNAVOX AMP-S PRO Audio Selector Switch for Speakers / Amplifiers Silver The Dynavox AMP-S Pro makes it quick and easy to switch between two amplifiers and two pairs of speakers, without having to make new connections. Ideal for comparative tests...
Spaces between Speaker terminals too narrow
quick and easy to deploy this switch but in case you are using robust (e.g. standard) speaker cables you will face problems with connecting all cables on the very narrow distance between speaker terminals.
Dominique L.
AUNE S17 PRO Discrete Class A Balanced Headphone Amplifier / Preamplifier 7500mW @32Ω Black With its S17 Pro, Aune unveils a powerful headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone...
Méconnu ...
Aucun avis sur le S17 Pro d'Aune ?. Je suis étonné ! Après 1 semaine d'utilisation, je ne peux que me réjouir de l'avoir choisi. J'écoute beaucoup au casque, j'ai donc acheté et essayé pas mal de combinaisons d'appareils, ampli-casques ou amplis intégrés, Topping, Fiio, Smsl, Rega, Marantz, Pioneer, AD 18 qui fonctionnaient assez bien avec mon Hifiman et mon Sennheiser. Pourtant l'Aune m'a fait franchir un gap et je suis encore sous l'effet "waou" après une vingtaine d'heures.
Le S17 est en classe A, il lui faut être à bonne température avant de totalement s'exprimer (30 mn), la température est d'ailleurs indiquée sur l'écran. On peut choisir le courant de repos et le gain.
L'Aune a de la matière, de la densité tout en étant transparent et détaillé. Je peux suivre les lignes de basse comme jamais auparavant, les voix sont très présentes et suaves, les aigus sont présents, sans agressivité ou sans sibilance. Mais, la qualité à laquelle je suis le plus sensible (et mon Hifiman aussi), est la séparation des instruments, l'espace que prend la musique, l'image, certainement fausse en réalité, mais tellement plaisante pour ceux qui aiment écouter au casque.
Trop de qualités pour être vrai diront certains ... oui, le temps me fera sans doute modifier une partie de mon appréciation. Mais pour l'instant, je profite de ma "lune de miel avec cet appareil" et ce, j'espère, pour un long moment.
Nb 1 : pour éviter de trop monter en température, mieux vaut surélever l'appareil. Je l'ai fait en le positionnant sur 4 petites équerres de bricolage placées en dessous, en position horizontale.
Nb 2: la pile de télécommande est fournie, contrairement à la description. (j'ai fait 15 kms pour rien!).
Nb3 : Commande passée un mercredi matin et reçue le vendredi matin à 700 kms d'Audiophonics ... chapeau !
Cris K.
Outstanding
This is a strange kind of cable. Its cost is very low but the sound performance is outstanding. I suppose this has to do with the carbon layer because the cable is made of OFC copper. But what matters for audiophiles is the extraordinary final result. This cable outperforms cables that cost many, many times more. This is a giant killer.
Georges G.
ELECTRO HARMONIX 12AY7/6072A Tube Twin Triode (Unit) This Electro Harmonix 12AY7/6072A tube is a double triode with equipotential cathodes. It is mainly designed to amplify low frequency voltages in audio equipment.
Remplace judicieusement des 12AX7 sur mon preamp phono tubes
Achetés pour remplacer 2 tubes 12AX7 GoldLion de qualité mais à forts gains, sur mon préampli phono Yaquin MS-23B, avec des risques de hs sur les atténuateurs de volume de mon ampli ATOLL IN200 Signature, j'ai choisi ces tubes 12AY7 sachant que j'aurais près de 40% de gains en moins mais une meilleure précision dans les micro-détails. Le pari est plus que gagnant !
Freddy D.
Transformateur Torique
Livraison plus rapide que prévue , article conforme a la commande , toutes les tensions OK , transfo de qualité , parfait !
Freddy D.
Bouton axe cranté
Un peu léger mais fait le job , c'est le principal !
2 ème avis decevant
Suite à mon avis de 11/23 et au fil des écoutes j'ai constaté un manque de dynamique et un son très légérement terni, j'ai retiré ce DC blocker et j' ai retrouvé un son plus enjoué et insicif mais sans agréssivité . Le rodage de ce filtre sur plusieurs mois d'écoute à t' il modifier ses propriétés? Même constat sur ma chaîne secondaire.
Samuel M.
RCA Plugs Gold Plated (Pair) These standard RCA connectors are gold plated, ensuring good conductivity and resistance to oxidation. Each connector is equipped with a PTFE insulation ring. They can be...
TOP
Se démonte par l'intérieur, c'est très pratique.
Pas besoin de dessouder à chaque fois si on veut démonter la face arrière (projet diy)
Et de très bonne qualité.
Samuel M.
Switching Power Supply Module 700W +/-60V This LLC switch mode power supply module has a main output delivering ±60V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a...
Auxiliaire, pas terrible
Autant la sortie principale est bonne, stable, on peut taper dedans. Autant la sortie auxiliaire, bof.
Ne permet même pas d'alimenter un module softstart. (2 relais 12v). Pas de protection, une diode a cramé.
jean luc d.
CONNEX SMPS2000RxE Switched Mode Power Supply Module 2000W +/-55V The SMPS2000RxE switching power supply is a very high efficiency model capable of developing a rated power of 2000W for a reduced space requirement. It will therefore be able to...
attention
il faut savoir que l'alimentation a découpage n'est pas réparable, la référence des composants sont effacer. pas de schéma et pas de nomenclature de branchement, l'alimentation et livré avec deux connecteurs , mais on c'est pas à quoi ça correspond.
tous ce qu'on le sait , c'est une fabrication chinoise.
il faut en tenir compte .
Radek P.
Jirka Vopicka
Realy great. I need to buy next one.
Radek P.
Alain R.
Très bon connecteur
J'aime beaucoup les connecteurs de a marque Viborg et ceux ci en particulier.
Par contre, le rhodium rend la soudure à l'étain plus délicate. Il faut un fer puissant (80W mini) une panne assez grosse, pour pouvoir faire une soudure rapidement sans faire fondre l'isolant du câble. En cela, la version dorée est plus simple à souder.
Néanmoins, le rhodium garantit une tenue dans le temps irréprochable puisqu'il est totalement inoxydable dans nos ambiance.
Couplé avec un câble Neotech Nemoi-3220 dont le diamètre passe juste dans le connecteur, on réalise des câbles symétriques de grande qualité.
(ajouter un gaine de déco sur le 3220 passe encore dans le connecteur, mais ça force un peu. C'est ce que j'ai fait avec une gaine réf 1796. Le final est vraiment joli à regarder et si beau à entendre)
Alain R.
Excellent câble symétrique
J'avais déjà réalisé des câbles RCA avec ce 3220 mais je n'avais pas vraiment d'autres câbles pour faire un comparatif.
J'ai réalisé deux câbles symétriques d'environ 80cm avec des connecteurs Viborg XM et XF 202G. Je l'ai comparé à des câbles que j'ai fait avec du câble Canare L-4E6S et les mêmes connecteurs (je les aime bien).
Ces câbles sont entre un DMP-A6 et un Hegel H190.
Avec le 3220, le son est plus plein, plus vivant. Les graves sont toujours là, plus percutant encore, le medium est mieux placé et les aigus se sont étoffés, sans être agressifs.
Les points chaud et froid (2 et 3) sont connectés des deux cotés. Le blindage (1) n'est connecté que du coté source, sur les deux câbles.
J'aime beaucoup ce câble.
Jacques C.
Exeptionnel
Pour cette commande tout s'est bien passé et rapidement, et j'ai enfin pu écouter cet SMSL AO300. C'est tout simplement exceptionnel. J'avais déjà gouté un ampli numérique avec le V200 de I AM D (pas tout jeune, mais déjà très bon). Là je suis tombé dans une autre dimension d'écoute, impressionnant.
Le seul regret que l'on pourrait avoir, c'est au niveau de la documentation qui pourrait un peu expliquer les différents filtres et EQ. Si vous avez quelques écrits sur ce sujet, merci de les faire connaitre.
Encore bravo pour le produit et le service.
jouri k.
How is this possible!
Bought this cable to try out because of a YouTube channel recommended it and to finally find a good speaker cable for my Duntechs (Dynaudio drivers). Mismatch in the past, or hardly any difference between different cables. I had the cable laying around for year and last month i stripped it and hooked it up bare wire.
Initally it worked just fine. No difference with my solid core DMN's. But now approx 100hrs in and something has changed. I listen to rock a lot. And those recordings are mostly unlistenable. But suddenly it sounds so full and PRAT was :) The emotion in the song :) My phantom centre channel is much more vivid. With much clearer boundries of imaging. Subjectively i feel it just is starting to be played in. So i hope in the next 2 months it will sound even better. Occ is the real deal ladies and gentleman. Hop in, the audio water great, why pay more.
Patrice H.
KT88 Gold Lion de nouveau DISPOS à la Vente, :-)
Cela faisait plus d'un an que j'étais à leur recherche.
En raison de l'embargo des produits Russe infligé par l'UE, comme les technologies de pointe (par exemple les semi-conducteurs avancés, les composants électroniques etc..),
qui rentrent dans la liste des produits faisant l'objet de sanctions.
Donc déjà un grand merci à AUDIOPHONICS, d'avoir su trouver une alternative d'approvisionnement pour ces excellents tubes d'origine Russe.
En remplacement de mes KT88 estampillés McIntosh d'origine sur un MC275 MK6, qui m'ont donné un immense plaisir d'écoute de plus de 7800h, depuis 02/2016.
Ces derniers temps, les KT88, originaux montraient des signes de faiblesses, perte de dynamique, détails et distorsion à niveau soutenu.
Eh bien une fois les Gold Lion installés, et après contrôle et réglage du courant de repos, dès les premières notes je retrouve de très bonnes sensations, certes c'est serré et un peu sec, des basses bien rondes, mais retenues et les médiums et aigus encore un peu timides, mais l'on sens que le meilleur est a venir.
Après environ 40h de rodage, (ca fait juste 4 jours que ça tourne non stop), ça commence réellement à respirer, une scène plus large et claire, plus précise et puissante, des voix d'un réalisme qui vous transcendent, une finesse dans les détails, je retrouve parfaitement mes KT88 d'origine à leur premiers pas.
On va laisser passer une centaine d'heures d'écoutes, pour que les Gold Lion puissent bien se libérer et nous transmettre toute leur âme.
Ces GENALEX, KT88 Gold Lion, made in Russia, Saratov, sont d'excellents tubes, et cela depuis des décennies.
Je RECOMMANDE, les oreilles fermées, avec en plus le tarif imbattable que propose Audiophonics, pas d'hésitation pour ceux qui souhaitent passer le pas.
Un énorme merci à toutes les équipes d'AUDIOPHONICS, pour leur travail, ils sont très réactifs lorsqu'on les sollicite, service au top et la livraison respecte les délais annoncés.
Cordialement Patrice
Marcus L.
This was such a big improvement over the cheap, standard adapters.
Turned my coaxial cable from good to great!
Hocine H.
XANGSANE XS-005 Cable Male USB-A to Male USB-B 2.0 Silver Plated Triple Shielding 1m The Xangsane XS-005 is a high-quality USB cable. With a length of 1m, its 4 silver-plated copper conductors with a cross-section of 0.78mm² ensure excellent conductivity...
Top produit
Super câble au vu de son prix, c'est de la très bonne qualité et surtout très souple. Je le trouve neutre dans la restitution avec de très bons connecteurs. Il mérite ses 5 étoiles.
Hocine H.
MUNDORF MCAP ZN Capacitor 630V 0.1μF Thanks to the latest winding technologies, Mundorf is able to manufacture its MCap ZN capacitors from ultra-pure, RoHS-compliant tinfoil. Their high conductivity ensures lively...
Top capuchon
Utilisé en bypass couplé avec du Jantzen Zcap ce petit capuchon apporte de la dynamique, du détail, du gain avec des transitoires plus précises, à utiliser sans modération.
Hocine H.
The Best
C'est la dernière chose que j'ai changé sur mes filtres passifs et je le regrette, car ça aurait dû être la première chose à changer. Vous savez que vous avez un produit de haute qualité en main, les pattes sont resistantes et souples à la fois, donc facilement manipulables et une fois soudées cette résistance est fermement maintenue. Cette gamme apporte de la clarté, du détail, du dynamisme et redonne un second souffle à la musique avec toute la transparence qu'elle mérite. Elles paraissent cheres, mais elles valent le coup et deviennent mes resistances de référence.
Bernard D.
SMSL D400PRO DAC AK4191 AK4499EX XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA Black SMSL presents with its D400Pro a DAC as versatile as it is powerful, benefiting from rigorous design and top-quality components. It is based on two AKM digital/analog conversion...
Excellent DAC - un pas supplémentaire franchi.
Le SMSL D400PRO Dac est dans la lignée du SMSL SU-1 Dac que je possédais déjà appréciant particulièrement les puces AKM.
Un pas de plus est toutefois franchi au niveau de la précision des aigus et de la profondeur des basses.
Une excellente note également pour la société Audiophonics dont la disponibilité et le professionnalisme sont remarquables !
Cédric R.
IFI AUDIO IPOWER MK2 Audio Power Supply Low Noise 5V 2.5A The iFi Audio iPower MK2 power adapter delivers an extremely clean and stable electrical signal to your audio devices. This new version of the iPower features improved...
Belle amélioration
C'est une belle entrée en matière pour ameliorer un streamer ou un switch. Apporte déjà beaucoup, on va dire 60 à 80 pourcent de ce que une alimentation linéaire ferait. Ce qui est très bien en regard du prix.
AUBRY L.
Trigger 12V
Bon produit. Fait le job..
Alexis L.
Mogami, fidèle a sa réputation.
Utilisé dans le cadre d'un recâblage intégral en symétrique de mon casque Beyerdynamic DT990 recouvert d'une gaine "ELECAUDIO ADIACIUM GB (PET) 4-11mm" en gris-noir, ainsi que pour le cable détachable qui alimente le casque en jack vers mini-xlr 4pins.
Ouverture, précision et douceur (vraiment) !
Présence accrue des médiums par rapport au cable d'origine du Beyer, on gagne en détails/nuances sur les aigus et les graves.
Bel étagement dans la scene sonore, rendu holographique, bon équilibre entre les fréquences, de la transparence mais surtout de la douceur !
Un cable a la japonaise ! Aerien et doux !
Se manipule très bien, la gaine plastique se coupe facilement, le cuivre présent entre les conducteurs et cette gaine est solide et protège bien !
Attention si vous l'utilisez avec le connecteur Amphenol AG4F,la petite bague en plastique qui vient se loger entre la colerette en fer et la piece en plastique où l'on soude les cables, cette bague est prévue pour du cable de 4mm de diametre, ce sera faisable mais un peu a l'étroit avec le 2534 pour faire passer les 4 conduteurs...idem pour le capuchon qui est censé se visser sur le corps en alu, il sera difficile de le faire tourner autour de cette piece en alu, il faudra bien le chauffer avec un briquet et penser a le raboter un peu a l'interieur si vous voulez faire passer les conducteurs jusqu'à l'attache en fer.
Mogami, incroyable !
Alexis L.
Impeccable.
Un petit ensemble très pratique ! Bon rétreint !
Les différents diamètres, c'est parfait !
Alexis L.
ELECAUDIO ADIACIUM GB Extensible PET braided sleeve Nylon 4-11mm Braided sleeve made in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety of applications. Thanks to its expansibility, the unique PET...
Belle et bonne gaine ! souple, se travaille facilement et bien tressée !
Utilisé pour recouvrir du cable Mogami W2534 dans le cadre d'un mod de mon casque Beyerdynamic DT990. Impeccable !
Beau rendu !
Photos:
https://drive.google.com/drive/folders/18LZ4JvVXgp_wNeRvT7herHoXQlIb02Wx?usp=drive_link
marc g.
FX-AUDIO XL01 Amplifier Class D 2.1 CS8673E Bluetooth 2x40W + 75W 4 Ohm The FX-Audio XL01 is a compact Class D amplifier with an integrated subwoofer output for passive subwoofers. This makes it ideal for integrating a small, affordable yet...
un ampli a essayer absolument...et qui vous ne coutera pas grand chose
Très clairement, à 45€, je ne vois pas comment faire mieux. La finition est très bonne, avec des vrais boutons qu'on peut toucher. Pas de petite chinoise qui met une musique agaçante au démarrage (comme sur le BT60W), une connexion bluetooth qui marche bien et avec un vrai bouton là aussi.
Ce n'est pas le cas hélas des bornes HP, bien trop petites: sans fiches bananes, point de salut!
le canal grave est très bien géré et filtré, avec un petit caisson, c'est au poil!
Au niveau du son, je me suis amusé à le comparer au fameux BT 60W, vendu au même prix. Ce dernier est un peu plus doux, mais moins précis, la sonorité du XL01est un petit peu métallique, surtout par rapport à un ampli Hifi "classique". Prévoir en conséquences des enceintes un peu "molles". Enfin, au chapitre des désagréments, la puissance n'est pas au RV. Où sont les 24W annoncés? Mais dans l'ensemble, je recommande chaudement ce petit modèle au rapport qualité prix totalement imbattable.
Daniel R.
Bien emballé !
Ben oui, pour une lampe c'est important d'être bien emballée ! Le colis est arrivé tout déformé, mais la lampe à l'intérieur n'avait pas du tout bougé : L'épais coussin de film à bulles d'air a parfaitement joué son rôle. Merci à celui qui fait les colis
HENRI L.
Wiring Cable Silver Plated OFC Copper PTFE Sheath 1.5mm² Ø2mm Black This Ø2mm wire has a 1.5mm² conductor made of silver-plated OFC copper. The conductor itself is made up of 19 strands of 0.32mm...
très bon câble
J'ai utilisé ce câble , rouge et noir pour recâbler les deux caissons de grave JBL HT1. D'origine le son est un peu lourd. Après avoir recâblé , j'ai trouvé une amélioration certaine , l'effet pataud était beaucoup moins prononcé , plus de détails. Du coup, une impression de plus grande dynamique , bien que déjà la dynamique est bien présente. Ces câbles sont faciles à souder et un peu moins rigide que certains câbles similaires. Le prix est très correct , toujours si l'on prend les prix généralement pratiqué dans d'autres lieux . En résumé je suis très satisfait !
Alain K.
Excellent RQP
Vaclav Z.
Banana Plugs Rhodium-Plated Lockable Ø9mm (The pair) These affordable banana plugs allow quick and easy connection to the terminals of your loudspeakers and amplifiers, while ensuring optimized contact. Rhodium-plated contacts...
Václav Z.
Again, very good value for money. Used on Neotech 3004 MK II cable. Review on the said cable...
Vaclav Z.
NEOTECH NES-3004 MK2 Speaker Cable UP-OCC Copper Silver plated 8x1.3mm² Ø 13mm This Neotech speaker cable features an 8-core StarQuad architecture with central insulation to lower the capacitive effect. The 1.3mm² conductors are equipped with strands...
Václav Z.
Excellent cable at a very good price, first cable I made myself, replacement for Audioquest Gibraltar bi-wir...highs, mids were enhanced, bass was tightened and accentuated...not expecting it I was afraid I had wasted unnecessary money... thank you fa Audiophonics.
Christophe M.
Installé sur ma barrette ANSUZ avec câblage ANSUZ, système Aesthetix/Lumin/Apertura. Recul du bruit de fonds = scène sonore plus large, plus d’information et plus précise, davantage de dynamique. Encore plus efficace avec 2. Je recommande
Christophe M.
Installé sur un meuble en bois de Finlande fait maison. La combinaison des deux est tout de suite audible, le traitement des micros vibrations = recul du bruit de fonds = scénario plus large, plus d’informations, plus musical. Equipement Aesthetix/Lumin/Apertura. A ce prix recommandation sans modération.
