Walter V.
Great product!
Joli mais non..
NAEL C.
Marvelous !
Customers reviews - There are 19047 reviews.
George T.
A TRULLY EXCELLENT PRODUCT!
I CONSIDER THIS DIGITAL GIANT IT TO BE THE BEST BUY IN HIGH END AUDIO IN NOW DAYS. I PUT IT IN MY SYSTEM REPLACING A WEISS INT 202. THE WEISS JUST CAN'T STAND BESIDE GUSTARD....THE U18 UNIT BEATS IT IN ENERY AREA BY A WIDE MARGIN. IF ANYONE OF YOU HAS AN "OLD" HIGH END DAC (I HAVE AN AUDIO RESEARCH DAC 2) THIS IS THE WAY TO RESURRECT IT!! JUST PAIR YOUR BELOVED OLD DAC WITH A GUSTARD U18 DREAM MACHINE AND THANK ME LATER! TODAYS DAC JUST DON'T SOUND THAT GOOD!
MY SYSTEM : MACBOOK AIR M2-AUDIO RESEARCH DAC 2-MARK LEVINSON 326S - NUFORCE 9 REFERENCE MONOBLOCKS- MARTILN LOGAN REQUEST SPEAKERS
Oliver H.
Pricekiller
Wow. The best entry-level DAC you can get. Perfect if you want to experiment with MQA/Tidal.
Oliver H.
... all i need.
High-quality cable at a moderate price.
Oliver H.
AUDIOPHONICS DIGIPI+I2S Digital Interface WM8804G for Raspberry Pi SPDIF I2S TCXO This Audiophonics DigiPi+I2S interface expands the output connectivity of a Raspberry Pi, giving it an additional panel of digital audio outputs. It includes a Toslink optical...
Great for RaspberryPi 3B
Runs smoothly in my volumio setup and sounds awesome. Fast delivery, thanks Audiophonics.
Edgar T.
Excellent XLR cable.
The quality of the cable is outstanding.
A must if you want to have a stack of hi-fi components linked via XLR.
Edgar T.
Very good cable for the function.
A solid cable that fulfills its function very well.
Edgar T.
TOPPING A30 PRO Headphone Amplifier NFCA Black The Topping A30 Pro is a high quality NFCA headphone amplifier that will delight lovers of headphone listening. With two headphone outputs at different impedances and a...
A little monster.
Little in size, But a giant in sound.
Drives all my headphones without any problems, even the more difficult with high impedance
The price is unbelievable, considering the quality of the amplifier.
It's not my only headphone amplifier, but it's become a favorite..
Laurent F.
Belles fiches (banane et fourche) solides et bien protégées dans une boîte avec la clé allen et gaines thermo
Les vis de serrage sont assez grande pour un bon contact
Audiophonics toujours impeccable
Francis-Arnaud C.
Une surprise
appareil bien en emballé , look sympa compact , alors au moment de la mise en route et après une petite chauffe , place à l'écoute , une cata
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 2.2μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
Comme des Mundorf Suprême Classics.
Aussi performants que les Mundorf Suprême classiques c'est dire !!
J'adore déjà les condensateurs Jantzen Cross-Cap et là on est largement au-dessus en terme de musicalité.
Parfaits pour le montage de mes filtres Cabasse Caravelle M2 trouvés sur le forum Cabasse (9 condensateurs et 7 selfs et une résistance) 2 condensateurs en parallèle pour obtenir les 4,4 µF requis et montés en série derrière le Cabasse Dom12.
Voilà un Dom12 calmé et devenu très performant, plus aucune mise en avant du médium, mariage impeccable avec le tweeter Dom4 lui-aussi filtré comme il se doit avec ces condensateurs Jantzen Supérior Z-Cap.
Audiophonics propose des articles de grande qualité avec une livraison express.
David K.
Ravis
Monté en XLR avec des connecteur EIZZ EZ pour relier un lumin D2 à un atoll IN 300. l'absence de soudure est un plus, néanmoins montage peu compliqué faire pour un néophyte. j'ai suivi une recommandation "d'usiner" les connecteurs avec un foret de 12mm.
Résultat: Cable très équilibré offrant en même temps de la matière et détails dans tous les registres. avec une lichouninette de chaleur qui rend l'écoute très fluide. on rentre très vite dans le plaisir de l'écoute de l'oeuvre et on oublie tout le reste. Bref très, très, très satisfait. En ce qui me concerne, la quête se termine ici.
Super soudure.
Voilà un beau rouleau de 250 grammes d'étain sans plomb avec ajout de cuivre, un stock qui devrait durer.
Parfait pour étamer des fils HP et pour souder des composants sur circuits imprimés.
Audiophonics toujours aussi performant dans ses livraisons et dans la qualité de ses articles.
Geoffrey D.
AUDIOPHONICS TPA-S25BT Class D Amplifier TPA3116 QCC3008 Bluetooth 5.0 2x45W 4 Ohm Gray The Audiophonics TPA-S25BT is a compact amplifier with a low price but still offering very good sound performance. It is ideal for use with bookshelf speakers or small...
Très satisfaisant
Produit acheté pour piloter en signal bluetooth deux enceintes 40W dans un atelier.
Le boitier est bien fini, le rapport qualité / prix est vraiment bon.
L'intégration de la réception bluetooth + du DAC dans le même boitier rend le produit efficace et peu encombrant.
Bien évidemment, ce n'est pas de l'audio ultra haut de gamme, mais pour le prix il s'agit d'un bon choix pour une installation minimale. Les réglages bass + treeble en façade permettent une bonne adaptation du signal pour exploiter les enceintes sans les faire saturer.
Attention toutefois, les alimentations proposés par audiophonics pour ce produit sont vraiment cheap. J'ai commandé une 19V 5A, et au vu de la qualité visuelle et du poix ridicule de l'alimentation, celle-ci semble vraiment de basse qualité.
Klaus M.
very interesting product
mounting this plug instead of a conventional outlet brings a clear, big, 3D sound with much details, the only drawback is a slight loss of focus.
Louis-Bernard D.
IBASSO DX170 Digital Audio Player DAP 2x CS43131 Bluetooth 5.0 aptX LDAC WiFi Android 11 Grey iBasso offers with its DX170 an excellent audiophile DAP. This one benefits from a careful design, using quality components, allowing to provide a faithful, precise and dynamic...
Très bon petit DAP !
Un très bon DAP. C'est mon premier DAP, un son qui me plait beaucoup, un look sympa. Son autonomie est un peu faible lorsqu'on écoute de la musique Hi-Res. Dans l'ensemble très satisfait de mon achat, livré très rapidement est bien emballé.
Louis-Bernard D.
Très bon petit DAP
Great Product
Great in every aspect. Well made, pure copper conductors, gold plating. Very reasonable price. Most important, sounds great. (No bling bling, no rhodium, no ncf, just what you really need...)
jerome F.
La source principale
Après avoir utilisé pendant pas mal d'années un ordinateur portable comme source dématérialisé , je suis passé à un streamer Eversolo , et bien l'amélioration a été très nette ! plus d'espace de naturel de détails , bref tout ce qui rend la musique plus incarnée . L'utilisation avec un dac Bel Canto est magnifique et la scène sonore plus vraisemblable .Très satisfait de mon achat .
Yes! Just great.
Great Product. This low mass principle works. Gives a wide, neutral well balanced/homogenous sound. Very well built, carefull sensitiv, as not too much material. Hard to make better. You get the best of this conducter material. Absolut bang for the buck. Yes, in practice would be nice to have a wider contact area for spades, but would it sound better? Max.
Wow!
A great product. Both channel attached to each other, which was fist odd to me. But easy to handle, light, flexible, easy to cut appart. Large diameter (wires). I think it sounds great. Very homogenous, over all (treble, middle, low/bass), airy, nice resoloution. At least everything you need. A bang for the buck.
ETI LINK BANANA Banana Plugs Gold Plated Tellurium Copper Ø9mm (Set x4) The ETI Link Banana plugs offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good...
Not so practical at lest with big wires
Please see my review of the ETI Link Spade, which I find an excellent Product. Here it would be same, but opposite to the Spade version (where you have the same large opening with same, about 1cm long, diameter tube, with 2 screws to hold the wire), the tube, here you enter with the wire and it looses hal of the diameter (the tube) after the first screw. To hold a wire with one screw, just after the opening, makes it for me useless. A shame for that in theory great product.
Eric H.
Eric H.
MUNDORF MLYTIC AG Capacitor 25V 22000μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Nicolas T.
AUDIOPHONICS CANARE Digital SPDIF Coaxial Cable 75 Ohm RCA-RCA 10m This SPDIF coaxial cable assembled in our workshops in France consists of an L-5CFB Canare cable and RCAP-C5F connectors of the same brand. This is a high quality 75 Ohm model...
Excellent Rapport Qualité/Prix !
Pas trop de surprise avec un câble Canare ! Et ce, même sur une distance S/PDIF de 10 mètres ! Câble relativement neutre et transparent, sans rondeur ni raideur ; et qui descend proprement dans le bas du spectre avec une belle tenue... Le plus grand avantage de ce câble est incontestablement l'excellente réjection des interférences environnantes ! Et cela, est un vrai plus et qui a guidé mon choix ici... Parfois, il ne faut pas chercher plus loin qu'un grand classique déjà bien éprouvé !
Patrice W.
Retour
J'ai refusé la livraison pour retour. Motif: ces câbles sont beaucoup trop gros et ne passent pas dans mes gaines. Je ne doute pas de leurs qualités mais je ne peux les utiliser
Erwan C.
Bluetooth 5.1 Receiver DAC Optical 24bit 96kHz / USB files Player This small Bluetooth 5.1 receiver with integrated digital / analog converter will allow you to provide your audio system with a wireless reception capacity. Thus, it becomes...
recepteur BT petit prix mais fait très bien le job
réception rapide.
correspond exactement à ce que je cherchais.
il m'a permis de transformer un vieil ampli en ampli acceptant le BT.
Qualité du son très bonne à ce que j'ai pu en juger (sur une autre chaine orientée HIFI).
Seul bémol, le niveau de son est faible par rapport à d'autres sources même quand on règle le niveau de volume au max sur le récepteur et sur la source BT. Mais ça ne détériore pas la qualité du son.
Il n'y a pas d’alimentation mais c'est indiqué dans la description.
Radu D.
FERRUM POWER SPLITTER Power Supply Splitter The Ferrum Power Splitter allows two devices to be powered from a single power supply. It has been designed to work with the Ferrum Hypsos power supply (sold separately). It is...
Ferrum power splitter
It does it's job as a splitter for people with Hypsos source, OOR and Wandla, it provides power to both accordingly, nothing fancy otherwise. Price a bit on the expensive side, but very nice metal build.
Radu D.
FERRUM OOR Balanced Preamplifier Headphone Amplifier Ferrum's OOR is a high quality balanced headphone amplifier and preamplifier, capable of accompanying all types of headphones, including the most demanding, while preserving the...
Ferrum OOR
I had the OOR in the past, sold it at some point and now bought it again, in combination with Hypsos and Wandla it goes sonically way beyond it's price point
Iulian M.
Verry good with minor issues.
It does not seem to have any iron in the conducting part of the connector. Just the golden cock ring has some iron and I just cut it of (seems stupid to include it, the connector looks better all black) as it could act as a small filter (like a ferrite bead). The cap is aluminium but I dont see how it could affect the sound, a better solution may have been plastic like WBT connectors. These connectors are my go to as it seems to not affect the sound (compared with just wire) and are way cheaper than WBT.
Bertrand G.
Tout a déjà été dit, la qualité d'écoute vaut bien ce petit investissement (avec des câbles USB et RCA de qualité). J'ajoute que l'amélioration de la clarté notamment sur la parole permet une écoute plus attentive des langues étrangères.
En bonus : Ce DAC est compatible avec la console de jeu PS5.
Cristian S.
100u Capacitors upgrade
I revise my initial review. After the cap upgrade with 100u quality parts the frequency response greatly improved. If you consider this board exchange of the series capacitors (signal path) is mandatory. But you will not regret it, the result is pretty impressive. Will keep me satisfied for a while ;)
Christophe G.
hallucinant !!
Je n'en crois pas mes oreilles. Au bout de 3 jours d'écoute tres attentive, et bien ...mille fois hélas , mais j'ai revendu sur ..." E...y" mon ampli actuel Denon PMA 1700 à 2000 euros, oui vous avez bien lu...2000 euros !!! je rejoins certains commentaires qui disent la même chose ! franchement , je dois vous dire que j'ai l'oreille absolue (étant musicien depuis 42 ans) et mon oreille quasi infaillible, n'a franchement pas entendu de différence notoire entre ce petit bijou et mon ampli denon 17 kilos plus lourds !!! oui il y a d'énormes progres en matière de classe D et cet ampli en est la preuve évidente . Elles sont connectées à une excellente paire de Monitor Audio Silver 100 (biblio) . ce matin encore j'écoutais des lieder de Mahler et la voix magnifique de Mildred Miller dans un enregistrement magistral de Bruno Walter (années 60) ...résultat extraordinaire. ! la cause est entendue...je le garde !
Denis S.
AIYIMA A200 Class D Amplifier TPA3255 2x180W 4 Ohm Bluetooth 5.0 Aptx-HD The Aiyima A200 is a powerful and affordable Class D stereo amplifier. It is based on a TPA3255 amplifier chip and a NE5532 AOP.
Oh My God !
Eh bien, c'est très bien... Il ne fonctionne qu'avec le Bluetooth, car c'est juste pour moi un ampli d'appoint... Mais il marche vraiment très bien, très étonné par la droiture, la puissance, le détail et la tenue des graves... Pour le prix, c'est un sans-faute, à découvrir. Grand merci à Audiophonics pour la livraison bien protégée...
Predrag S.
Very good product!
Bananas sit firmly, are solidly made and for the price there are no better ones!
Marius V.
IFI AUDIO GND DEFENDER Main Power Supply Ground Loop Filter 90-240VAC The iFi Audio GND Defender is a power supply filter, which eliminates ground loops. A ground loop can create low frequency hum. The GND Defender intelligently detects the...
Great
Works great, mains noise has been eliminated. Sound quality was not affected. I am very satisfied.
Maxime B.
DAYTON AUDIO PA130-8 Speaker Driver Full Range 50W 8 Ohm 88.2dB 90Hz - 15kHz Ø12.7cm The Dayton Audio PA130-8 is a good speaker at a low price, which can be used as a replacement for a defective model or for DIY speaker design. The wide covered frequency range...
Haut-parleurs de très bonne qualité
J'ai acheté ces haut-parleurs pour faire une paire d'Auratone DIY, et bien je suis bluffé du rendu. J'en ai fait plusieurs avec des caissons de taille différentes car pour copier des Auratone, le volume de la caisse est théoriquement trop petit par rapport aux spécifications constructeur. J'ai le sentiment que de respecter le volume donne un peu plus d'air, elles sonnent un peu plus vivantes.
Quand on regarde la courbe de réponse, on voit qu'elles sont très linéaires et c'est ce que je cherche. On arrive à entendre quand même du bas vers les 80Hz. Le gros + concerne toute la bande de bas et haut medium sur lesquels on a une super lisibilité, on entend les instruments avec beaucoup de détails, les effets de spécialisation ressortent très bien. Ca n'est jamais agressif.
Vraiment idéal pour trouver l'équilibre des instruments dans un mix entre le clair / obscure.
Pour le prix je suis bluffé et très content de mon investissement, je serais curieux d'entendre la différence avec des haut-parleurs de gamme supérieur.
Comme tout haut-parleur, ils ont besoin d'un temps de rodage car au début ça sonne assez dur, un peu de patience...
Jean-Christophe R.
Secteur
Câble de qualité que je raccorde à une barrette Audiphonics
Attention section importante et du coup assez rigide
Jean-Christophe R.
Barette
Fait le boulot, qualité au rendez vous
Je l'utilise pour une écoute au casque Haut de gamme et rien à redire
Super qualité, s'adapte sur plaque Dayton DBPP.
Lire mon avis sur la plaque Dayton DBPP pour passer mes Cabasse vintage en bi-câblage avec ces borniers.
Belle construction, câble hp jusqu'à 5 mm2 en serrage, fourches, fiches bananes aussi.
Livraison éclair d'Audiophonics.
Idéal pour passer mes CABASSE vintage en bi-câblage.
Souhaitant passer mes enceintes Cabasse Caravelle (les M2 : filtres avec 9 condensateurs, 7 selfs et une résistance) en bi-câblage, ces plaques sont idéales.
Elles se fixent sans aucune modification, à la place des anciens borniers en plastique marron, en position HORIZONTALE.
J'ai vissé dessus 4 borniers isolés EIZZ-304 (les borniers Jantzen Audio conviennent aussi) puis soudés les câbles internes, les 2 du bas vers les hp de graves 21NDB et les 2 borniers du haut vers les hp médiums DOM12 et tweeters DOM4 ensemble.
Cette plaque existe en simple câblage avec 2 trous mais la dimension ne convient pas (10x10 cm).
Il faut 10cm x 14 cm pour recouvrir le trou des Cabasse.
Cette plaque est suffisamment épaisse, de belle qualité.
Dernière précision, les encoches ou petites découpes horizontales autour des trous ne servent à rien, je les ai même bouché à la colle car elles laissent passer l'air.
Livraison ultra-rapide, toujours bravo à Audiophonics.
Le prix de la justesse ?
A mon tour de faire mon petit commentaire
Commandé après Noel et reçu 10 jours après malgrès une rupture de stock.
Bravo AudioPhonics
Configuration : Audirvana-CHORD hugo2-Cayin cs55a-DALI menuet-REL zéro-câblage de très bonne facture.
Ces tubes sont ni plus ni moins les plus chères dans cette référence, excepté les NOS.
Valent-ils leur prix ?
Apres la chauffe réglementaire des 30 minutes :
Il se dégage une excellent équilibre sans effet notoire. La musique fille librement sans aucune coloration.
Tout au plus une légère présence dans le haut du spectre sans aucune agressivité qui me fait penser que les PSVANES étais pas très démonstratifs dans cette zone…
Ces aigus justement donne plus de lumière aux morceaux et plus de présence aux instrument dans les passages les plus doux.
Sur la musique classique les différents groupes de violons parviennent à se détacher les uns des autres par leurs timbres spécifiques.
Dans les basses fréquences aucun bridage ; ça pousse fort !
Le combo full MULLARD (12AX7-12AU7) avec les TUNG-SOL KT120 en puissance est très équilibré tant il est transparent avec la musique. Il y a énormément de détails et le fait de monter le volume ne permet pas d’entendre plus de choses
D’autre part la dynamique me semble assez rare, j’entend par là que les passages les plus doux et les plus fort « semblent » joués à même niveau comme au concert. Particulièrement convainquant sur de la musique classique.
Je m’attend avec le rodage à gagner en ouverture et en profondeur.
En bref, c’est une toute autre esthétique que les PSVANES. Fallait essayer pour le savoir…
Je remet un commentaire plus tard.
ETI LINK SPADE Spades Gold Plated Tellurium Copper Ø9mm (Set x4) The ETI Link Spade offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good...
Excellent Product!
Excellent Product, as per my opinion. Very well executed, quality and used materials. Large diameter to enter cable, screws same material as conductor. Very, shockingly, neutral, no turn to cold or warm, no smearing. Very homogeneous, e.g. in resolution, no preference for treble or low/bass. Bravo.
musicalité parfaite selon mes gouts ..sonorités impeccables ..en remplacement d'une electro harmonie 12au7..colis bien protéger et super rapide ..
Maurizio N.
Expectations confirmed.
I.m founding this preamp excellent in order quality construction and sound. It's very close and somewhat superior respect to my EC1 pre Electrocompaniet.
Quality sound improves noticeably after at least 100 hour and more burn-in (in the beginning is not too great).
I'm gonna replace output solen caps with better Janzten z cap superior.
Item arrived quickly in a few days, thanks to Audiophonics.
antoine L.
TAD EL84-M Power Tubes Pentode (Matched Pair) The TAD EL84-M pentode tubes offer a robust design and provide powerful midrange and well-defined bass. Durable, they provide up to 10,000 hours of use.
el84 tubes de puissances
je ne souhaitai pas intervenir, mais bon, Audiophonics m'a demandé d'intervenir, d'après ce que j'ai pu lire, ces tubes seraient fiables et solides avec une durée de vie importante, j'ai surtout acheté ces tubes pour les garder en secours, certaines références commencent à manquer ou à se raréfier,
Georges F.
Ces patins absorbent les vibrations sur mon parquet bois de façon très efficace, je recommande
Bernard T.
Fonctionne en continu depuis 6 ans avec un pc linux, convient parfaitement à la diffusion du son sur sur un ampli nad 302
Ralf S.
LHY AUDIO BATT-USB Regulated Linear Power Supply on Battery 5V 2A This LHY Audio BATT-USB regulated linear power supply module uses four 21700 batteries with a capacity of 4900mAh (a total of 9.8Ah) and an ultra-low-noise LDO LT3042 linear...
Gute Akkuversorgung für Medienkonverter
Ich nutze das Gerät für den Betrieb eines Medienkonverters. Laufzeit mit einer vollen Ladung reicht locker für einen Betrieb über 48 Stunden. Das Problem der nicht vollständigen Trennung vom Stromnetz habe ich mit einer 2-poligen Zeitschaltuhr gelöst.
Florent c.
Branché en sortie d'un wiim pro, afin d'alimenter un ampli atoll et un ampli casque. Rien à redire, pas de perte de signal. Très satisfait.
Gorazd K.
AUDIOPHONICS WIRE Interconnect Cable Stereo RCA OFC Copper Gold Plated 3m The Audiophonics Wire serie offers a selection of affordable yet high performance cables, hand assembled in our workshop in France. The Audiophonics Wire RCA cable consists of a...
Excellent cable and connectors for this price, it's hard to get a better cable of this length for this money. And as always fast shipping and safe packaging.
