mickael C.
Une des meilleures prises
mickael C.
Michel P.
Michel P
DDHifi TC07S USB-C Cable Pure Silver / OFC Copper OTG 50cm The DD TC07S cable consists of a male USB-C OTG connector on both sides. The cable features an optimized structure with perfect separation of the data and power conductors to...
sous des cables
LAURENT G.
ETI KRYO Silver Plated Tellurium Copper Binding Post Ø17mm x 52mm (Set x4) The ETI Kryo are top of the range terminal blocks designed with exceptional components. It features a Tellurium Copper conductor with Silver plating for maximum conductivity and...
Excellents borniers
LAURENT G.
Pratique et bonne qualité
Bonne qualité pour le prix.
Je conseille vivement.
LAURENT G.
Guillaume F.
SHANLING M0 PRO Compact HiFi Digital Audio Player DAP DAC 2xES9219C Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD Green Shanling offers with the M0 Pro a technical and aesthetic evolution of the M0 high fidelity digital player. This Pro version benefits from an improved digital/analog conversion...
DAP Shanling M0 Pro
Laurent M.
Très très bon câble H.P
Sur ma config;
les connecteurs :
Le résultat est magnifique !
C'est beau !
très bon
très bon
toujours content
ca dépends du système
Anton N.
Excellent bornier.
Excellente fiche banane
Emmanuel A.
Haut de gamme
Joris J.
Loose physically connected
Joris J.
Superb reclocker
Eugen M.
TSP facile
Eugen M.
Très surpris en bien
Joris J.
Exceptional value
Almost for free.
Philippe K.
ASTELL&KERN KANN MAX Digital Audio Player DAP HiFi 4x ES9038Q2M Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Gray The KANN series is a line of portable digital music players, particularly popular with audiophiles for their performance focused on high output and clear sound. The KANN MAX,...
Erik J.
naturel
Thierry V.
Surprenant!
Rimantas S.
Nice little DAC
Nothing to complain about.
Jean L.
Très bon RQP
Gregory F.
Impressionnant
bernard T.
fiche bananes
Très belle fabrication, dommage que les vis soient un peu courtes car même avec un câble de 4mm2, elles peuvent tomber dans le corps du connecteur à la fin du serrage.
TAD ECC803S Tube Twin Triode (Unité) The TAD ECC803S tube is a double triode with a long plate, based on the Telefunken ECC803S design. It has a 1dB lower gain than the ECC83-Cz but offers a much more detailed and...
En rodage
Première impressions face aux tungsol qualité standard que je viens remplacer.
Plus de présence et de définition dans les basses fréquences.
Pas vraiment plus de details mais il n'ont que 3 ou 4 h d' exercice.
De prime abord, tien de fou face au tungsol.
On verra dans le temps...
Cela reste de bons tubes.
ARYLIC B50 Amplifier Two-Way Bluetooth 5.2 aptX HD HDMI ARC 2x50W 4Ω The Arylic B50 is an extremely versatile and practical Bluetooth 5.2 amplifier, endowed in addition to its wireless connectivity with a wide panel of connectors allowing it to...
Très très bon ampl avec l hdmi parfait pour un televiseur
Excellent ampl très étonnant pour sa gamme de prix. Il fonctionne à merveille pour épauler une TV avec l hdmi arc et l aptx hd s entend c est étonnamment bon quand les appareils connectés supportent le même code pour un système d'appoint ou du quotidien sans prise de tête tv et musique de qualité c'est parfait. En plus l appli est très bien faite franchement super pratique et Son qualitatif.
Didier G.
NEOTECH NEET-3008 Ethernet RJ45 Cable UP-OCC Copper 3m Neotech offers with its NEET-3008 an excellent RJ45 Ethernet cable, benefiting from an exceptional design. It integrates four UP-OCC Copper conductors with a cross-section...
Didier G.
Patrice L.
Excellent choix
Cette nouveauté chez AudioPhonics est excellente .
Du connecteur cuivre doré dans des proportions minimalistes afin de ne pas perdre le signal dans des masses métalliques inutiles ( sauf pour l'égo de certains ... ) .
La coque est également en cuivre qui lui confère une bonne rigidité pour un poids assez léger.
L'accès à la soudure est déjà vue , hyper pratique, l'isolant tient bien la chaleur.
Je ne me perdrai pas dans la critique de la concurrence, mais à conception équivalente et à très exactement 4 x le prix, chacun se fera son opinion.
Cette fiche n'est pas blocable mais perso je ne m'en sers pas dans une régie/son , donc ....
Dans les ratios prix/matériaux/conception/fabrication, je ne chercherai pas plus loin.
Merci Audiophonics pour cette excellente initiative.
Bonnes soudures à tous
Alan S.
Très belle et bonne barrette secteur
je souhaitais refaire un peu mon setup home cinéma et il restait une partie à ne pas trop négliger l'alimentation de ce dernier (TV ampli HC platine Blueray, Console, PC multimedia, décodeur TV ) .
J'ai opté pour cette barrette 8 prises afin de disposer d'assez de prise en tenant compte du placement d'un filtre IFI AUDIO AC iPurifier pour la partie vidéo. J'ai associé des câble secteur de chez PANGEA AC-14SE MKII et franchement ça match bien. Il faudrait que je permute afin de voir si tous les bénéfice sont là mais en tout cas pas de bruit parasite ou de neige à l'écran ni au niveau du système sonore. Ça respire la qualité. Alors est-ce un effet placebo ? En tout cas quand j'écoute une bonne source ( FLAC ) sur mon système je le fais avec un grand plaisir :D
Alan S.
Indispensable pour écoute nomade sur Smartphone
Ayant deux casques de qualité, je voulais pouvoir les utiliser sans souci sur n'importe quel smartphone. Après un moment de recherche, je me suis arrêté sur le Fiio KA3. Et franchement je ne le regrette pas le moins du monde.
Je peux maintenant profiter en mode "nomade" de mes casques ( Hifiman Sundara & Denon AH-D5200 ) sans le moindre souci de performances ( tant puissance que qualité ). ce DAC rikiki permet de les "driver" sans aucun problème. De plus ayant changer de smartphone, le Samsung A53 ne dispose plus de port 3.5mm jack. je me balade donc en permanence avec mon DAC. Ecoute de fichiers lossless ( FLAC ) et streaming via abonnement Qobuz et vrai régal.
J'ai fait écouter le combo à plusieurs collègues et franchement ils étaient stupéfaits de la qualité de rendu.
Je ne peux que recommander ce produit. ( livraison rapide et soignée comme toujours avec audiophonics)
PS : non, je ne suis pas sponsorisé ^^ mais quand un produit est bien il faut le dire. Quand il est mauvais aussi ^^
François R.
efficaces
beau produit protègeant bien le parquet!Il eut été plus confortable qu'elles soient livrées avec la rondelle de caoutchouc déjà installée car cela est fastidieux à mettre
Richard Ö.
This amplifier sounds fantastic !
Having heard many different highend amplifiers the last 20 years, Im very impressed by the sound quality from this amplifier. It is very clean, neutral and powerful, and the spatial qualities and resolution are stellar.
The sound from this amplifier is an upgrade from the otherwise very good sounding Fosi V3 and Aiyima a07.
M A.
IAN CANADA GPIO 40PIN Extension Kit for Raspberry Pi Ian Canada offers a GPIO extension kit for Raspberry Pi, allowing to make an off-set of this connector, especially useful for a box integration of some modules.
another beautiful product from ian canada.
exactly what I was looking for, this way it is easy to expand the gpio of a raspberry pi.
a minus point is that the product is quite pricey ..... something cheaper would have been nice, Other than that it's worth 5 stars.
M A.
LHY AUDIO Triple Linear Power Supply Module LT1963A 5V / +/-5V This LHY Audio triple linear power supply module offers a very nice design quality, using three LDO voltage regulators LT1963A to provide a clean and stable electrical signal....
Build quality is good and easy to adjust.
It would be even better if it could deliver higher amps.
all in all a perfect product.
M A.
good quality for a reasonable price.
build quality is good and looks nice.
M A.
nice quality and works fine
already bought several ian canada products and just like this one it really adds something and a very good quality.
use this in combination ian canada PurePi to 3.3 volt input FifiPi MA.
Pascal L.
Excellents résultats audio
Je recherchai une alimentation 5v cc pour remplacer l’alimentation d’origine à découpage d’un streamer audio. Convaincu de l’amelioration apportée par une alimentation linéaire régulée et filtrée sur des équipements audio analogiques, s’agissant exclusivement d’un streamer donc de circuits numériques j’étais pour le moins dubitatif…
Dans un premier temps j’ai remplacé provisoirement mon alimentation à découpage d’origine (5v 5w) par le chargeur d’origine de la marque à la pomme de l’IPad 6 ( 5v 10w) , dispositif également à découpage et là déjà, l’écoute a très nettement gagnée en définition, dynamisme, présence des basses et réalisme des médiums.
J’ai donc décidé d’acquérir sur les conseils avisés du service clients d’Audiophonics, cette alimentation 5V 25VA filtrée et régulée…
Une fois installée, là encore une étape a été franchie par rapport au chargeur de l’IPad 6, à savoir:
- Basses nettement plus profondes et mieux définies,
-Médiums et hauts médiums plus présents, plus détaillés et timbres plus justes
-Aiguës légèrement accrus et détaillés sans aucune agressivité
-Transparence, aération, dynamique, analyse , équilibre des registres, ouverture de la scène sonore nettement améliorées .
En un mot c’est comme s’il ne restait plus que la musique et non plus du son…
Résultat tout à fait similaire à une montée significative en gamme des équipements voire à passer sur un ampli à tubes ou de classe A.
Écoute réalisée à partir d’un streamer moyenne gamme, d’un DAC et d’ un ampli hi-fi de qualité audiophile et d’enceintes 3 voies d’un constructeur Brestois …liaison streamer -DAC via fibre optique en verre véritable et liaison Dac-ampli par l’intermédiaire d’un câble RCA, d’une société Américaine , de qualité réputé pour son équilibre général .
En conclusion : une bonne alimentation permet également d’améliorer la restitution d’un appareil numérique ( je suppose qu’il en est certainement de même pour des équipements vidéo ?)
L’investissement nécessaire reste relativement modique par rapport aux gains obtenus
N’hésitez pas à questionner Audiophoniques car leurs réponses sont pertinentes et très rapides .
Dernier point, matériel reçu rapidement et très bien emballé
Produit bien conçu, bien construit et de qualité .
Je recommande ce produit ainsi que la société Audiophonics.
Bonne écoute à tous
Patrick F.
SUPER
Quelques soucis initiaux dus à un cable coaxial de mauvaise qualité qui hachait le signal. Parfait après correction
Quelle différence d'écoute ensuite, des basses propres et sèches, des aigus denses.
Quel changement comparé à l'audio d'une AppleTV
Vive le FLAC et l'i2S avec Qobuz
Alain S.
Comme cité précédemment ...
Petit appareil qui m'a permis de corriger facilement la qualité de sortie douteuse d'une TV 4K d'entrée de gamme.
Fonctionne à la perfection.
Jean Paul G.
Prise qui Apporte un plus dans tous les registres, neutre et transparent, ne changeant pas les caractéristiques de votre ampli, cd.. c’est étonnant en enlevant, et en remettant une prise lambda avec un câble normal …magnifie un câble plus haut de gamme..
coude.. plus petit? Serais mieux mais garder la même qualité sonore, recommandé
RQP? AAA+
Jean Paul G.
RQP excellent
Prise apportant un plus au niveau sonore large, bande passante, neutralité aucune couleur RQP imbattable
J’ai trouvé le côté pratique très bien, la même chose un petit peu plus plat pour certains endroits serait judicieux. À part cela, je recommande cette prise qui apporte une réalité augmentée dans la transparence à neutralité, ce que nous propose pas toutes les prises électriques. Je suis agréablement surpris, connaissant depuis de longues dates des problématiques rhodium, argent, or et toutes ces prises ESO de prix justifiés ? qui enfin de compte nous font oublier la simplicité de la musique.
Jean Paul G.
Le son est meilleur..
Le son avec cette prise en cuivre est très bon, neutre, équilibré, juste ce qu’il faut partout. Pas trop et genre je fait de l’holographie fatigante. Câble barrette secteur le résultat est la!! Tout est mieux dépourvu un tarif contenu.
Pratique . RQP…
Recommandé
Thierry V.
Excellents!
A nouveau sur conseils de Mr Aubert("re merci")...cable tout cuivre, qui fait enfin chanter mes tannoy mini...avec le modul Canare, je ne me pose plus de question..musique!
Dans ce système , chez moi et oour moi, mieux qu un Melodika sugar b. et surtout qu un inakustik s 1,8ke !
