Claude T.
Bonne config
L'ensemble
- Monitor Pro contrôleur.
Apporte un plus...
Claude T.
Bonne config
L'ensemble
Apporte un plus...
Manuel S.
Noisefree wonder amplifier
If you search an amplifier which generates no noise, even when pressing your ear against a horn tweeter of a Triangle Australe Titan tweeter, you will find it here.
I looked for the Sparkos edition as I only use a Marantz AV Receiver as pre amp. So the Sparkos would be the best choice in the pre buffer section.
The shipment of the amplifier was turbo fast to Germany. Unfortunately, the first amp had a problem with the right channel. But no problem with audiophonics after sales support. They sent me a retoure label, checked the amp, confirmed the failure and sent me a new one after checking it.
Again a turbo fast delivery and now everything is fine.
The crystal clear and simulateously dynamical sound of this amp is wonderful. I compared it to the ICE Power Modules in XTZ amps: No comparison. Absolute big difference!
There is so much more "life" in this Purifi amp. I think this will be the last amp for years now and I hope it will last a long time.
Before I had a Musical Fidelity m6 500i 30kg monster and it did not sound as good. It had a white noise permanently (not to loud but with horn tweeters,you got to hear it in 2m distance) . Furthermore it drew 120W of expensive current. This Purifi based beauty only takes 20W.
Additionally it does not get warm and does not convert your listening room in a hot and dry desert.
I just can recommend Audiophonics as not only the products are perfect. Also the support really is top!
Franck M.
puissant uniquement si bien alimenté!
si on lui met 600watts de reserve en amont on peut faire une mini teuf avec 2 pauvres hps de 10cm de diamètre! sinon avec une alimentation pas ouf en 3ampères ca s'arrrete à l'oeil à 2x5watts!
Eric K.
Ampli phono FOSI
parfait. Fonctionne très bien.Merci
Perfection
Je fais peu de CR cause peu de temps mais ce 3001 de Néotech est a mes oreilles et mon système proche de la perfection.
N'attendez pas qu'il règle un problème car il est simplement ou plutôt parfaitement neutre et transparent.
Il lui faudra quelques heures de rodage (cablos-sceptiques s'abstenir) mais au bout quelle récompense, il est carrément addictif.
J'ai tout dis il y a peut être mieux mais dans cette gamme de prix ce sera difficile, il est monté en xlr avec les excellents EIZZ vendu ici aussi et le résultat est simplement fantastique.
Guy L.
JANTZEN AUDIO Bass Reflex Port Tube 102mm Ø25mm This Jantzen Audio Bass Reflex speaker vent has an internal diameter of 25mm. It will be perfect for any small speaker. In the shape of a pavilion, its flared opening prevents...
Très bien, fait le travail
Intégré dans enceinte bluetooth .https://youtu.be/xEGvq1JDTl8
Guy L.
Très content de ces hauts parleurs que j'ai intégré dans un enceinte bluetooth.
didier g.
TOPPING L50 Balanced Headphone Amplifier NFCA Black The Topping L50 is a desktop headphone amplifier with an architecture optimized for incredible sound performance. It features a new generation NFCA circuit, based on the one...
Bon appareil
Testé en Jack TRS, pas en RCA, bon appareil bien fini.
Le sélecteur de gain est appréciable, je suppose pour les écouteurs IEM, par exemple. Si je garde le gain le plus élevé pour des casques à rendement faible ou moyen et impédance moyenne ou élevée, par contre même avec des casques à impédance de 32 ohms ou à rendement moyen ou élevée, je préfère rester sur cette position même si le potentiomètre n'est utilisé qu'au début de sa course: la restitution est plus incarnée: en position de gain 0dB, la clarté est excellente mais je trouve un aspect montant et désincarné gênant.
Gestion de la commande par Audiophonics: sans souci
didier g.
comparé un à un ancien petit DAC 24 bits, 192 kHz, la clarté est appréciable. Appréciable aussi le fait de pouvoir jouer sur le filtre de sortie, qui me semble (c'est subjectif) avoir une influence subtile mais audible sur la douceur de restitution ou au contraire une restitution définie mais un peu désincarnée. Testé en Jack TRS, pas en RCA. Télécommande pratique.
Gestion de la commande par Audiophonics: aucun souci.
rob m.
Incredible
My system is a BlueSound Node through a Audiolab 8300A and Kef LS50 Meta. The Mogami opened up the system, it's unbelievable what this cable can do, Highly recommended
Michel P.
Multiprise de bonne facture pour le prix, mais un peu légère qualitativement : ne pas s'attendre à une amélioration remarquable.
Normal : structure en plastique, absence de blindage, schulko très moyennes, ma prise DIV (bois - carbone - blindée - schulko et câblage de qualité en étoile) à été à la hauteur de mes attentes. Mais bien que réalisée par mes soins est beaucoup plus chère.
Michel P.
Excellent rapport qualité prix, beaucoup de définition et un très bon équilibre tonal. Personnellement, pour un prix équivalent je préfère les Viborg : même qualités mais "en mieux" peut être la différence de placage.
Michel P.
Assez bien
Le connecteur est indéniablement de bonne qualité, mais à une tendance à comprimer un peu la dynamique et la définition : "trop sage". Utilisé sur un ampli audio résultat moyen, mais très bon sur un AVR de moyenne gamme de qualité (lisse peut être les défauts de ces appareils en audio).
Michel P.
Excellent câble avec des connecteurs de haut de gamme et une conception irréprochable, comparaison avec d'autre produits : on ne paye pas la marque mais le résultat absolu.
Michel P.
Excellente
Remarquable en qualité audio (neutralité et définition), toutefois assez longue et lourde : attention requise si le dégagement derrière l'appareil est insuffisant ou si l'embase recevant le connecteur est peu profonde (celui-ci aura tendance à glisser vers le bas).
Michel P.
superbe cable
Excellent câble hautement blindé, d'autre part sa structure mono brin permet de s'affranchir des problèmes récurant en audio (sans être un spécialiste) : stabilité et intégrité globale de la transmission du courant. Toutefois très rigide difficilement pliable, utilisé pour réaliser une multiprise 8 ports, à nécessité une hauteur interne de celle-ci de 10 cm, pour s'affranchir de la courbure maximale possible.
Michel P.
excellente prise en audio
qualité audio indéniable : équilibre tonal et définition sans artifice. mais un peu fragile : serrage de l'embase dur le support avec précaution au risque de fendre celle-ci, les visses des plots sont à six pans creux : insérer l'outil de serrage avec attention (droit et profondément, sans faillir lors de la connexion) au risque de détruire la visse, toutefois en respectant cette attention le serrage sera puissant et sur.
Philippe V.
TOPPING EX5 Headphone Amplifier DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Silver Topping offers with its EX5 an extremely powerful DAC and headphone amplifier combo. Its conversion stage is indeed based on two ES908Q2M DAC chips and allows the reading of...
Excellent Dac
Passe quasi parfaitement le test de lecture de l'album Myopia d'Agnès Obel que tant de Dacs massacre. L'ampli n'est pas en reste et fait un très bon travail. Enchanté de mon achat chez Audiophonics
Ethernet RJ45 Cable Cat 8.1 40Gbps Shielded Gold Plated 10m This RJ45 Ethernet cable takes advantage of the recent Cat 8.1 standard, offering a bandwidth of up to 40Gbps. The cable itself has a high quality design with a double shielding...
Excellent, mais attention lors des angles de murs
L'excellent triple blindage fait que c'est assez rigide, vous ne ferez pas d'angles droits avec ce câble ! Sur dix mètres, il y aura des virages, il faudra faire des doucines. C'est hélas obligatoire avec cette norme hyper rapide.
Ethernet RJ45 Cable Cat 8.1 40Gbps Shielded Gold Plated 0.5m This RJ45 Ethernet cable takes advantage of the recent Cat 8.1 standard, offering a bandwidth of up to 40Gbps. The cable itself has a high quality design with a double shielding...
Très bonne qualité mais assez rigide
La qualité est là, mais l'excellent triple blindage oblige à une certaine rigidité, lors de son installation
Très performant pour son prix
Ne pas hésiter à le comparer à des marques audiophiles réputées. Idéal pour alimenter un disque dur auto alimenté en USB 3.
Excellent câble mais assez rigide
Voilà de la qualité, pour l'excellent triple blindage se paie par une rigidité qui se remarque lors de son installation.
Patrick R.
Complément d'avis
Pour compléter mon précédent avis.
Au moins 150h de rodage sont nécessaires pour vraiment apprécier ce DAC à sa juste valeur. Le grave est plus équilibré, la scène sonore semble plus précise encore, le coté "naturel" s'accentue encore.
Vraiment très satisfait de mon achat. Un appareil qui se place largement au-dessus de la mêlée des DAC à 500 ou 1000€.
Il semblerait que Gustard ait annoncé les petits correctifs UPnP attendus sur ce R26 (et A26 aussi qui partage le même streamer).
Henri F.
Quique
Très bon amplificateur de puissance... Très précis..' cela dit.. pour des personnes qui veulent en faire un système principal... Un bon classe AB ou A ou lampes . Ces classes restent supérieure en musicalité... C'est mon avis après l avoir comparé.....
Dominique H.
pas d'amelioration flagrante
Testé sur mon lecteur réseau Bluesound je n'ai pas noté d’amélioration significative à l’écoute, peut être que mon réseau Ethernet n'est pas trop pollué ? dans ce cas on peut s'en passer.
Yngve I.
Unexpected
I'm having a hard time finding the words to describe how good these amps sound. They just do everything right. Period. ( powering martin logan electrostatic speakers)
Brice D.
Câble exceptionel!
J'ai pris ce câble pour mon streamer Aqua LinQ et DAC Aqua Formula xHD.
Le résultat est absolument incroyable, ce Furutech surpasse largement mes ex Audioquest Firebird Souce c'est dire!
Par contre je confirme qu'il est vivement conseillé de faire l'effort d'équiper ce câble de connecteurs Furutech FI50, vous serez récompensé.
Câble très charnue qui apporte beaucoup de musicalité à votre système couplé à la transparence des connecteurs FI50.
Chaudement recommandé!
Themis M.
Interconnect Cable Female XLR - Male XLR Gold Plated CANARE L-4E6S 2m Red This XLR male to XLR female modulation cable has a nice design quality, using a Canare L-4E6S cable. The cable has copper conductors insulated with PE jackets and is shielded...
High quality.
Christopher J.
Good sound but ..
Easy to construct. Only the Volumio OS would boot for me. Spurious click noises at selection end, but sound otherwise good. Slow to boot and often UPnP interface fails to appear, requiring multiple re-boots. Best left permanently on. Software functionality lets down the good hardware.
Joel B.
SOMMERCABLE EPILOGUE Modulation Cable Male XLR to Female XLR 3m (Pair) This high quality XLR cable pair consists of a Sommercable Epilogue modulation cable and Neutrik connectors, specially designed for optimal signal transmission. The cable...
Le câble
Que dire de plus qui n’a déjà été dit? Ce câble ne fait pas de musique comme c’est souvent le cas ,mais est un formidable passeur. Inespéré, magnifique! Merci à AUDIOPHONICS pour le bon conseil.
Mateo K.
MUNDORF Fiches Banane
Tout simplement les meilleurs fiches bananes. Beaucoup de fabricant de câble hdg (LUNA) les utilises car ils offres une connexion parfaite la soudure est extrêmement simple a réaliser (grâce à l'encoche) et ils valent leur prix. C'est tout simplement ma référence. Je conseille fortement de les allier avec les DCA16GA de chez duelund !!
Bertrand O.
Bon produit - Attention pas de télécommande!!
Voici quelques jours que j'essaie ce petit boitier bien intéressant.
Les plus:
- Pas de souffle, reproduction fidèle
- Alimenté en direct sur le PC, donc s'allume et s'éteint en même temps que celui-ci
- format rikiki
Les moins:
- Son un peu plus fade que mon "vieux" ES9038
- Pas de télécommande comme annoncé (du coup, hop une étoile en moins!)
- petit clac quand on change de source sur le PC
Bref, ça le fait, surtout pour le prix. Si la télécommande n'est pas nécessaire pour vous, vous pouvez y aller!
Jean Louis L.
Câble DC en haut vol :
J'ai déjà posté ici un avis sur ce remarquable câble de modulation. J'aimerais évoquer un usage un peu original mais très performant.
J'ai monté un câble d'alimentation DC pour relier une alimentation linéaire de 9 volts et un reclocker SotM-USB. Les résultats sont fabuleux. Bien utiliser des connecteurs en cuivre pur et non en laiton comme les modèles ELECAUDIO DCT-2.1G en cuivre tellurique vendus ici.
je viens d'en commander un nouveau pour relier une alimentation linéaire à une interface USB MATRIX X-SPDIF 2.
J'avais déjà réalisé des câbles DC à l'aide du NEOTECH NEI-3004, mais en utilisant le NEOTECH NEI-3001 MkIII déjà très bon pour cet usage, or ici, on passe à un autre niveau.
Prévoir un rodage d'une semaine en fonctionnement continu avant de porter un jugement sur le résultat musical.
a voir selon les cas
Son plus doux mais pas amolli.
efficace
A réduit le bruit de fond . Une goutte sur axe moteur et axe plateau suffissent .
DYNAVOX NC5 Carbon Fiber Brush for Turntable Needle The carbon fiber brush Dynavox NC5 removes diamond dust from the needle of your turntables. An ideal tool to maintain the needle of your turntable but also to eliminate dust...
Bon rqp
fais le job efficacement ; prix raisonnable .
La lecture est plus précise au détriment de la scène sonore qui se rétrécie ; son moins épanoui . Ne répond pas à mes attentes .
Associé à Daphile sur un "vieux" Netbook Samsung NC10, voilà qui me permet de disposer d'une solution portable/nomade de musique dématérialisée suffisante pour mon usage sur mes différentes chaine hifi 'vintage' et à un prix doux.
Seul bémol : prévoir un câble USB court de qualité, non fourni. Les câbles d'imprimante sont inefficaces.
Thibaut M.
Superbe et pratique à l'usage
Excellent produit, avec une qualité de conception et de construction exemplaire.
Attention ce sont des borniers aux dimensions pour le moins généreuses à réserver aux enceintes de moyennes supérieures et grosses.
Je recommande pleinement
Gilbert H.
Expédition rapide comme d'habitude. Produits conformes.
Mait N.
FOSI AUDIO TB10D Class D Amplifier TPA3255 2x230W 4 Ohm The Fosi Audio TB10D is a compact and powerful Class D amplifier, offered at a contained price. Its amplification stage uses a TI TPA3255 high performance chip, capable of...
Excellent for bass
Powerful. Does not care of your speaker impedance curve. Dynamic. If there is sudden peak, it stresses this over. Probably you have to pay 10 times more for getting better amplification for your woofer. I have compared this to mediocre 4x more expensive Yamaha, this blows it away with ease.
On higher range, above 1000 Hz not so good any more. Still with power and dynamics but somehow the sound is like it transforms sinus wave to square a little bit. Also, as tested shows some harmonics there. Could be excellent choice for old and lazy paper driver system. Gives you dynamics and sharpness without need for new drivers. In case you have some metallic tweeters then the combinations is not the best.
But still, for the money it is more than five stars. Would buy again.
Mait N.
Bluetooth 5.0 Receiver CSR8675 aptX HD LDAC This compact Bluetooth 5.0 receiver will allow you to add a wireless reception capacity to an existing audio system. Thus, it becomes very simple to broadcast your music...
Partial functionality
Somehow LDAC to optical out did not work. It works to digital out, but not optical for me. Sound started cracking and whistling. So had to return it. All other functions were working.
Mait N.
LDAC is good
Good receiver, takes highest BT LDAC settings to optical out without any problem. Seems bigger on the picture, but in reality is nice small sized. Did not need or test other settings.
Guy H.
Belle esthétique et finition.
Silencieuse.
Livraison rapide et bien emballé.
LE ROI DES AOP
La technologie discrète est souvent préférée à l'intégrée pour des raisons qui sautent aux oreilles à l'écoute de ce SPARKOS. Lors des premières écoutes, c'est aussi bon que mes AOP TLE2142 CP mais ce n'est qu'après plusieurs heures d'écoute que le SPARKOS se réveille en révélant la musique dans son sens le plus fidèle. Je crois qu'on ne peut pas trouver de point faible à cet AOP. Le prix n'est certes pas donné mais la plus-value est certaine. Deux petits Sparkos ont transformé mon Aiyima A07 en un produit High End.
Constantin N.
The last amp you'll ever need
You know why you're here.
You've seen the measurements.
You know what this is amp is capable of - especially in bridged mode.
Is it expensive? Kind of.
Is it expensive compared to all the ultra expensive voodoo amps out there? No, it's actually a steal.
Go grab it and be happy ever after.
No but really, so far I bought two of them. Absolutely incredible clean sound - no frequency dependend distortion!
Only thing left to see is reliability, but this amp didn't even get remotely warm in my first week of usage. So I expect it to last decades, at least.
Rene C.
Do the job in a non hifi context
I purchased an offer =1,8 m
Used 1,5 m of this cable for my Ampeg Bass Combo BA-112. The 3 x 3,5 mm is spot on, the sound isn´t too fat / full.
The sound must not be to clean (hifi) a little dirt left, is to prefer !
Jean-Pierre f.
AUDIO-GD R2R-11 MK2 DAC Headphone Amplifier Amanero 32bit 384kHz DSD512 The Audio-GD R2R-11 MK2 is THE Swiss army knife for audiophiles. Combining the functions of DAC, preamplifier and headphone amplifier, it will meet most needs. It features a...
acoustiquement délectable
Acheté par curiosité audiophile pour cette technologie sans suréchantillonnage (merci à David et Grégory pour leurs conseils), j'en suis à présent totalement séduit. Mon convertisseur PS audio stellar gain est battu, ne m'offrant pas cette aération simple et claire, cette respiration pas spécialement dynamique mais qui respecte la sonorité d'origine des enregistrements. Ce n'est pas redécouvrir ses CDs comme on le dit souvent, c'est découvrir la musique comme elle a été jouée et chantée. Le plus frappant est ce naturel acoustique des voix et instruments, dès les premières minutes d'écoute. Et ce n'est que du RCA et du coaxial (et de l'USB pour mon ordi qui a tout de suite reconnu le DAC). J'écoute peu au casque et essentiellement via mes enceintes colonnes, des CDs et du flac sur disque dur externe. J'ai branché les jumpers fournis (il faut des doigts fins ou une pince à épiler !) pour le "warmer sound" préconisé par Audio GD, résultat plus fluide me semble-t-il. Pour éviter de légers "plocs" possibles à l'allumage, je branche d'abord le dac puis l'ampli (Allo Volt +D ou Sabaj A20A première mouture), pour éteindre, faire l'inverse.
Avis aux amateurs qui peuvent se permettre cet achat, émotion musicale au rendez-vous garantie !
xavier R.
excellent DAC
C'est mon premier achat chez Audiophonic et je recommande fortement ce site.
Choix des produits aux meilleurs prix, conseils et compétences.
Après 1 mois et demi d'utilisation de ce DAC S.M.L.S D300, je suis très content de mon achat.
Ce DAC sonne plutôt analogique et à pris place au coeur de mon installation.
Il est relié en USB derrière un mini-Pc Daphile qui gère ma collection de musique dématérialisée jusqu'au DSD.
Le bluetooth accepte des flux jusqu'à 24/48, très pratique pour lancer un streaming depuis un téléphone à la volée.
Il est relié à ma TV en optique.
Et à mon vieux lecteur CD/SACD SONY en coaxial et remplace avantageusement le DAC d'origine de celui-ci.
Ce DAC est agréable sur tout les styles musicaux.
Il manquerait peut-être un peu de tenue dans l'Infra-grave.
Mais à ce prix, rien de rédhibitoire.
Bref très satisfaite de cet achat pour le prix.
Arnaud T.
Très bon DAC et rapport qualité/prix
Voulant autre chose que le son sortant du Jack mon écran PC (venant lui-même de l'HDMI de ma carte graphique) par qui effaçait les basses et aiguës, j'ai voulu prendre de suite du durable avec un bon rapport qualité/prix pour mon casque Fidelio X2HR et futur upgrade(s). (bientôt un Hifiman XS probablement)
Eh bien là le son est parfaitement neutre en sortie de prise Jack (confirmé par des tests de par exemple Audio Science Review), enfin des basses et aiguës appréciables !
Le tout sans avoir besoin d'installer un pilote sur Windows 10 (et 11), même s'il faut aller dans les paramètres Windows pour aller au-delà du 44,1-48000Hz en 16 bits.
Avec la télécommande on peut régler certaines choses notamment que les LEDs oranges s'éteignent au bout de 30 secondes sans toucher/changer de paramètres, rendant l'appareil encore plus sobre et adaptable au look de son bureau ou setup.
Jeanphilippe c.
Restauration
Self pour le médium. Très bon. Je recommande. Détail sonore important. Merci à audiophonic pour sa préparation soignée et sa livraison rapide.
