Refurbished Product - Grade B
Insertion marks on the contacts.
Power Connector Schuko Silver / Gold Plated 24K Pure Copper Ø19mm Black
This Viborg VE501G Schuko connector is ideal for designing and upgrading high performance and high quality power cables. Its pure copper contacts with silver / gold plating ensure a very high conductivity and resistance to oxidation. The insulation is made of nylon and fiberglass, strong, light and electromagnetically neutral materials. The assembly is very simple thanks to a screwing system.
| Specifications | |
| Product type | Schuko connector |
| Contacts material | Pure copper |
| Contacts plating | Silver / Gold |
| Insulation | Nylon and glass fiber |
| Mounting type | To screw |
| Acceptable cable diameter | Ø6-19mm |
| Max conductor diameter / section | Ø4mm / 12.5mm² |
| Voltage / Current | 250VAC 16A |
| Dimensions | Heaight: 64mm Diameter : Ø33mm Length : 83.6mm |
| Color | Black |
| Max cable diameter (mm) | 19.0 |
| Connectic | Male |
| Connector | PLug CEE 7/7 |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Silver |
| Contacts Plating (Connector) | Gold |
| Rated current (A) | 16.0 |
