Refurbished product - Grade A
3.5mm jack connector not perfectly aligned with the hole that receives it.
Streamer Bit-Perfect WiFi AirPlay 2 Bluetooth 24bit 192kHz
Octavio offers with the Stream an improved version of its first streamer model. Extremely easy to use, it is designed to modernize an existing HiFi system by transforming it into a real bit-perfect and multi-room streamer. It features today's best technologies to allow you to access your music remotely, whether it's stored on a NAS, a computer or even on your smartphone.
In this new Stream version, the player adds AirPlay 2 support for easy streaming from Apple devices, but also Tidal Connect to control playback directly from the Tidal app. A status LED also appears when setting up the device, for easier use.
Setting up and using the Octavio Stream is extremely quick and easy. Just plug the network player into your HiFi system and connect it to your WiFi network to access all your music content. The control is done directly from your smartphone, thanks to the Octavio application.
Bit-perfect is a term commonly used in audio to describe a player that can play a file without making any changes of any kind.
For example, if your Octavio Stream player plays a 24bit 192kHz Hi-Res file on Qobuz, the digital output will offer 24bit 192kHz. Just as if the music file played is in 16bit 44.1kHz, the digital output will propose this same sampling rate, without modification. In short, a real 1:1 ratio (input/output).
This is what we call a real bit-perfect reading, the closest to the musical reality of the piece played.
The Octavio Stream is compatible with the most popular streaming services and web radios with Qobuz, Spotify, Deezer, Amazon Music, Tidal or even TuneIn and iHeartRadio. In addition, thanks to the UPnP protocol, you can also access files stored on a smartphone, computer or NAS.
The Octavio Stream embeds a WiFi Lossless transmission technology. It ensures a high quality sound reproduction in wireless. Moreover, the transmission via WiFi does not apply any compression to the original audio signal, maintaining the integrity of the broadcast file.
The Octavio Stream has its own dedicated control application, available for free on the Apple App Store or Google Play for Android. This application allows you to access quickly and easily, via an ergonomic and intuitive interface, your favorite streaming services, many web radios as well as your locally stored music.
With Octavio's Spotify Connect compatibility, you can use the Spotify app directly to start playback on your connected speakers or players.
With Octavio Stream, music is shared with family and friends. Each member of the household can download the Octavio application and control the music being played and browse through the streaming services offered.
Setting up a multiroom system with Octavio is very simple. You just need to associate an Octavio Stream player to each of your home audio systems to integrate it into a multiroom ecosystem with centralized control via the mobile application. It is thus possible to play the same music in all your rooms or different songs for each audio system.
Analog
With the Octavio Stream, you can connect your audio system in analog, thanks to the integrated 3.5mm jack output. The DAC stage of the player supports resolutions up to PCM 24bit 192kHz.
Optical
In case your audio system has an Optical input, then you can connect it to the Octavio Stream's Optical input using a Mini-Toslink cable. This integration allows a transfer of the digital audio signal without interference.
The architecture of the Octavio Stream has been developed internally by the brand and thought for an important durability thanks to the use of quality components. Moreover, the audio processing stage is immune to electronic and electro-magnetic interference.
The Octavio Stream's WiFi reception capacity is ensured by a LinkPlay chip, a world-renowned player in the field of connected audio. Thus, automatic or manual updates are regularly available to improve the Octavio Stream's user experience. This technology has been designed to be scalable and adapt to the evolution of streaming.
Thanks to its sleek and elegant design, the Octavio Stream will easily fit into any audio system or room in your home. It also features touch-sensitive buttons to start or stop your music playback, without having to use your smartphone.
" Reduce obsolescence, give a second life, these are the terms used by the company Octavio for its communication around its product. As much to say that the bet is successful... "
| Specifications | |
| Product type | Streamer |
| Inputs | WiFi Bluetooth 5.0 |
| Outputs (Paired on the same connector) | 1x Jack 3.5mm 1x Optical Mini-Toslink |
| DAC Chip | PCM5102 |
| CPU | Amlogic A113X |
| WiFi / Bluetooth chip | Broadcom BCM43456 |
| Network module | Linkplay |
| Supported audio file formats | FLAC, OGG, ALAC, WMA, APE, MP3 |
| Supported sampling rates | PCM up to 24bit 192kHz |
| WiFi | 802.11 b/g/n 2.4GHz / 5GHz |
| Compatible streaming services | Spotify Qobuz Deezer Tidal Amazon Music Apple Music Napster TuneIn iHeartRadio |
| Supported transmission protocols | AirPlay 2 UPnP Spotify Connect Tidal Connect |
| General | |
| Dimensions | 118 x 65 x 22mm |
| Color | Black and white |
| Package | 1x Octavio Stream 1x USB power adapter 1x USB-C power cable 1x Optical Mini-Toslink cable |
| Input | WiFi |
| Input | Bluetooth |
| Output | Jack 3.5mm |
| Output | Optical Mini-Toslink |
| DAC / ADC Chip | PCM5102 |
| Max sampling rate | 192kHz |
| Color | Black |
| Color | White |
| Streaming services & Network protocols | Tidal |
| Streaming services & Network protocols | Web radios |
| Streaming services & Network protocols | Spotify Connect |
| Streaming services & Network protocols | Spotify |
| Streaming services & Network protocols | Qobuz |
| Streaming services & Network protocols | Amazon Music |
| Streaming services & Network protocols | AirPlay |
| Streaming services & Network protocols | Tidal Connect |
| Streaming services & Network protocols | Deezer |
| Refurbished Grade | Grade A |
