LDOVR TPS7A4700/3301 Dual Ultra Low Noise Regulated Linear Power Supply -3V to -18V / +1.4V to +20.5V 1A
This TPS7A4700/3301 dual LDOVR regulated linear power supply module provides extremely low noise levels measured at only 4µvrms for the positive rail and 16µVrms for the negative rail. Its input voltage range is from 3 to 25VDC or 3 to 18VAC. Its outputs are adjustable from 1.4V to 20.5V 1A in 0.1V steps for the positive rail and from -3V to -18V in 1V steps for the negative rail.
Reference : 16286
104,90 €tax incl.
87,42 € tax excl.
Shipping date: 11-06-2026.
LDOVR TPS7A4700/3301 Module Alimentation Linéaire Régulée Double Ultra Faible Bruit -3V à -18V / +1.4V à +20.5V 1A
This TPS7A4700/3301 dual LDOVR regulated linear power supply module provides extremely low noise levels measured at only 4µvrms for the positive rail and 16µVrms for the negative rail. Its input voltage range is from 3 to 25VDC or 3 to 18VAC. Its outputs are adjustable from 1.4V to 20.5V 1A in 0.1V steps for the positive rail and from -3V to -18V in 1V steps for the negative rail, using solder pads on the PCB :
LDOVR TPS7A4700/3301: Output voltage adjustment
If no pad is soldered, the positive rail delivers 1.4V. To obtain the desired voltage, you must therefore add 1.4V to the voltage of the pad or pads to be soldered.
The negative rail delivers -3V, so you must subtract the value of each pad to be soldered to obtain the desired voltage.
Please set the desired voltage before soldering the two rails to the PCB.
Please note that the regulators are not soldered to the PCB.
Product typeDual regulated linear power supply module
Input voltage range3VDC to 25VDC
3VAC to 18VAC
Any-Out™ voltage modesUser programmable output via solder pads on the PCB
Positive output voltage range : +1.4V to +20.5V (0.1V step)
Negative output voltage range : -3V to -18V (1V step)
Output current1A
Output noisePositive rail : 4µVrms (10Hz, 100kHz)
Negative rail : 16µVrms (10Hz, 100kHz)
Ripple rejection82dB (100Hz) / 72dB (10kHz)
≥55dB (10Hz, 10MHz)
Dropout voltage307mV @ 1A
ProtectionsFixed current limit
Thermal protection
Operating temperature range-40°C / +125°C
External feedback option
PCB Dimensions60 x 60mm (approx. 45mm height)
InputScrew terminals
OutputScrew terminals
Output voltage (V)-18.0
Output voltage (V)1.4
Output voltage (V)-3.0
Output voltage (V)20.5
Output current (A)1.0
Input voltage (V)25.0
Input voltage (V)3.0
Power SupplyRegulated Linear Power Supply
This TPS7A4700/3301 dual LDOVR regulated linear power supply module provides extremely low noise levels measured at only 4µvrms for the...
