Tolerance (%)
1 % - 5 %
Power (W)
0 - 250
Resistance (Ohm)
Resistors
Daniel W.
Connecteur
J'ai envoyé une photo et...
Moyen
Elle se retourne en...
Giacomo P.
No for me
Absolutely no!
Resistors
  • Wire wound resistors
    Wound resistors are essential components for audio and electronic circuits, offering greater precision and reliability in the management of electrical signals. Constructed with a resistive wire wound around an insulating core, these resistors are designed to withstand high powers while minimizing resistance variations due to temperature changes. Their robust design allows for efficient heat dissipation, making them ideal for applications where long-term stability and consistent performance are crucial. Whether you're working on amplifiers, filters or power circuits, wound resistors ensure precise regulation and optimum reliability. Discover our selection and find the right resistors to guarantee the performance and durability of your electronic projects.
  • Ceramic resistors
    Ceramic resistors
    Ceramic resistors are designed to deliver outstanding performance in demanding environments and high-power applications. Manufactured from high-quality ceramic materials, they provide excellent thermal stability and efficient heat dissipation, making them ideal for circuits requiring enhanced reliability and robustness. Their ability to withstand high temperatures and high currents without degradation makes them a preferred choice for amplifiers, audio filters and power circuits. Thanks to their low temperature coefficient, ceramic resistors guarantee consistent precision and increased durability. Explore our range of ceramic resistors and choose the components that best meet the requirements of your electronic and audio projects.
  • Film resistors
    Film resistors
    Film resistors are essential components for ensuring exceptional precision and stability in your electronic circuits. Constructed with a thin layer of resistive material deposited on a substrate, these resistors offer excellent regularity and low thermal drift, ideal for audio applications and high-precision circuits. Their careful design ensures low tolerance and rapid response to current variations, contributing to stable, reliable performance. Whether you're working on audio amplifiers, filters or measurement equipment, film resistors deliver consistent value and unrivalled sound clarity. Explore our selection to find the right film resistors to meet the specific needs of your electronic and audio projects.
  • Ref : 16099
    In Stock
    Mundorf MResist Classic resistors offer very good performance. They are similar but slightly simpler in construction than the MResist Supreme resistors. The MResist Classic series is designed to bridge the gap between ordinary MOX resistors and the top-of-the-line MResist Supreme.
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16100
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16101
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16102
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 16103
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 12980
    In Stock
    The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer details and a much better spatialization.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 14450
    In Stock
    The Mundorf MResist SUPREME range of resistors offers products of exceptional quality. With a real impact on sound reproduction, these resistors allow finer details and much better spatialization.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 15558
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4063
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4064
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4065
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4066
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4075
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4076
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4077
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4078
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4067
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4068
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4079
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 6436
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4069
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4070
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4080
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 15336
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4071
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 16061
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4072
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4073
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4074
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 16109
    The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors.
    16,10 € 13,42 €Ex.
    In Stock
  • Ref : 16113
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16114
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16115
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16116
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16118
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16122
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16123
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16124
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16125
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16134
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
