The S8 Pro Robin from Hidizs is a portable balanced DAC and headphone amplifier combo based on two Cirrus Logic CS43131 converter chips and capable of delivering 160mW + 160mW at 32 Ω. Furthermore, the device supports sampling rates up to PCM 32 bit 384kHz and DSD256. Moreover, this device has dual balanced and unbalanced outputs to suit all applications.
The Hidizs XO is the ideal companion to accompany a smartphone and enjoy a high quality sound reproduction. Combo DAC and portable headphone amplifier, it benefits from very good performances and a neat design, perfect to listen to your music in the best conditions, especially on the move. It even provides a double balanced / single-ended output to fit...
With the Olio, iEast offers a compact and powerful wireless audio receiver that works with both WiFi and Bluetooth. Extremely versatile, it supports numerous transmission protocols such as DLNA, AirPlay 2, Spotify Connect, Tidal Connect, and can even be controlled through Amazon Alexa and Siri voice assistants.
The iFi Audio DC Blocker is a power supply filter, which suppresses residual DC voltages in order to limit the noise level. The DC Blocker is simply placed at the IEC input of your device.
With the Go Bar, iFi Audio offers its most powerful USB DAC and ultraportable headphone amplifier. With its particularly compact size, it can accompany you on all your travels to provide you with great listening quality at all times, whether from a smartphone, tablet or computer.
The Hip DAC from iFi Audio is back, in a second version, now with an orange metal shell, but above all with improved audio circuits. This one integrates a 16-core XMOS USB interface, with a doubled clock speed and a quadrupled memory. MQA support has also been added, as well as an improved clock oscillator.
With its NEO iDSD 2, iFI Audio unveils an upgraded version of the NEO iDSD, fulfilling the functions of DAC / Preamplifier / Headphone Amplifier. The NEO iDSD 2 is one of the first DACs to integrate Bluetooth aptX Lossless technology. Versatile and high-performance, the NEO iDSD 2 can be used in a variety of ways: DAC/headphone amplifier, pure DAC coupled...
The iFi Audio Neo Stream network player has been designed to offer both versatility and excellent sound performance. It combines the latest version of the brand's network playback system with its excellent custom DAC to offer intuitive operation and precise, detailed and dynamic audio reproduction.
The Ikko ITM05 is an ultra-portable balanced headphone amplifier and DAC combo, integrating high quality components in an extremely compact and lightweight format. It's the perfect companion for your smartphone to give you the best sound experience wherever you are. Practical, it slips easily into a pocket or bag.
This KAIBOER XLR interconnect cable is an XLR male to XLR female interconnect cable. It features pure 4N silver conductors and a 2x 8-strand litz wire structure for maximum conductivity. In addition, the XLR connector contacts are 3u gold-plated for corrosion and oxidation resistance.
With the Keces S3 you get an all-in-one device, covering the functions of DAC, preamplifier and headphone amplifier. Carefully designed with high-end components, it provides a high quality sound reproduction that is as rich and precise as it is dynamic.
The Matrix Element M2 is part of the brand's line of network players, functioning as a complete standalone source device for your audio system and bringing your traditional HiFi system into the world of high-resolution streaming.
The Matrix Element P is presented as a high-end all-in-one device. Indeed, the latter is extremely versatile and takes on the roles of network drive, DAC and amplifier at the same time. All you need to do is combine a pair of passive speakers to enjoy a complete and extremely powerful HiFi system. Performance made possible by careful design but also by...
After 4 years of research and technical accumulation, the new X-Sabre DAC is born. The X-Sabre 3, a high-end DAC perfectly optimized and intelligently designed, offers exceptional performances, a particularly intuitive use and a clear and rich sound reproduction. The connectivity is also evolving, the X-Sabre 3 being fully connected to make it a DAC and...
McGee offers with the Harmony a high-performance hybrid amplifier, using both two 6N1 tubes for the preamplifier stage, ensuring a natural and warm sound, associated with transistors for the amplifier section, providing a power of 2x50W under 4Ω.
The Meze Empyrean is a resolutely top-of-the-range headphone. Using high-end materials, with undeniable know-how and an absolutely exceptional level of detail, this orthodynamic headphone is an awesome piece of art. Audio performance, design, ergonomics, nothing is left to chance for the greatest pleasure of audiophiles.
The miniDSP SPK-4P is a PoE+ full-range speaker combining audio streaming (AVB), Class D amplification and digital signal processing (DSP). A single RJ45 Cat5/6 Ethernet cable is used to power the speaker, stream audio and control the device, for a true Plug&Play experience.
The Monolith Liquid Platinum DAC is a compact DAC offering an exceptional sound reproduction quality with excellent measured performances. It is designed to be perfectly matched with the Liquid Platinum and THX-AAA headphone amplifiers of the brand, but also with any other HiFi headphone amplifier. The Liquid Platinum DAC combines an AKM AK4499EQ DAC, a...
With the Dawn Pro, Moondrop unveils a high-performance, affordable portable symmetrical DAC headphone amplifier. Two CS43131 DAC chips enable the Dawn Pro to support high-resolution sampling rates up to PCM 32bit 384kHz and DSD256.
This compact, versatile and high-performance O-Noorus PA-98E Class D amplifier uses a TDA7498E amplifier chip and is thus capable of delivering a comfortable 2x125W power output at 4Ω (1% THD).
Purifi's EVAL3 mono evaluation kit is designed to enable simple connection of the power supply and input/output signal to the 1ET7040SA amplifier module. The kit has been developed for evaluation purposes, but is also suitable for DIY applications.
The EM5 is a complete high-end DAC/headphone amplifier station, with a wide range of different connectors, including balanced XLR and 4.4 mm. It can also be used as a DAC and preamplifier when combined with a separate power amplifier or active speakers.
The M3 Ultra is Shanling's latest portable high-definition digital music player, following the excellent M3X. It uses the same architecture as the M3X with an improved processor, a newer Android version and many additional features. Its digital/analog conversion stage is based on a pair of ES9219C chips and its amplification section uses two independent...
Equipped with two ESS ES9038Q2M DACs, the Shanling M6 (21) is a high performance model, supporting high sampling rates, up to PCM 32bit 768kHz and DSD256. Versatile, it is also compatible with Bluetooth aptX HD and LDAC, as well as WiFi and can also be used as a USB DAC.
Soncoz unveils with its SGA1 a fully balanced headphone amplifier and preamplifier combo that is extremely powerful and musical. Benefiting from an intelligent and neat architecture as well as a sober and elegant design, it will delight the most demanding audiophiles and music lovers.
The Thieaudio Oracle MKII in-ear monitors were designed to provide a transparent sound reproduction, with the intent to mimic the tonal balance of professional studio monitors. It incorporates a hybrid technology, using an all-new 10mm LCP (Liquid Crystal Polymer) diaphragm dynamic driver, two Knowles Balanced Armature drivers and two Sonion electrostatic...
Topping proposes with its D10 Balanced a compact and above all extremely powerful symmetrical DAC. This one integrates high quality components to favor a limpid and precise restitution. It includes an ESS ES9038Q2M DAC and a XMOS XU208 USB interface, capable of supporting high resolution audio streams up to PCM 32bit 384kHz and DSD256.
TRASAM's DAC DS5 is based on a SABRE ES9028PRO chip with a USB XMOS interface and a Bluetooth chip CSR-8675 Apt-X HD, which allows it to benefit from an excellent connectivity while supporting high sample rates.
Triangle Borea BR03 Connect active bookshelf speakers provide a complete, versatile stereo sound system. They incorporate a high-performance amplifier, making it easy to add sound to rooms from 15m² to 40m².
