Impedance (Ω)
Speaker Type
Diaphragm type
Loudspeaker diameter (mm)
0 - 530
Efficiency / Sensitivity (dB)
75 - 110
Xmax (mm)
0 - 34
Lowest frequency (Hz)
10 - 5010
Highest frequency (Hz)
0 - 57000
Speaker Power (W RMS)
0 W - 2005 W
Mohammed B.
Im Vergleich zu Mundorf...
Mohammed B.
Mohammed B.
die
Speakers
Find in this category all our loudspeakers / Boomers, from the midrange speaker to the bass speaker, including of course tweeters. The whole range to create your own HiFi speakers, or to replace damaged or out of order speakers. Major French brands such as ATOHM or DAVIS ACOUSTICS are available, so you can be sure of the quality and performance of their speakers.
  • Tweeter
    Tweeter
    This section presents all our tweeters dedicated to high frequency reproduction. Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
  • Midrange / Midbass / Full Range
    This section presents all our midrange, midbass and full range speakers. Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
  • Woofer
    Woofer
    This section presents all our bass drivers dedicated to low frequency reproduction. Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
  • Subwoofers
    Subwoofers
    This section presents all our subwoofers dedicated to subwoofer reproduction (very low frequencies). Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
  • Passive radiator
    Passive radiator
    This section presents all our passive radiators allowing you to reproduce low frequencies without bass reflex. Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
  • Horn loudspeakers
    Horn loudspeakers
    This section presents all our compression chamber type loudspeakers allowing you to obtain very good performances. The filters on the page allow you to make a more precise selection according to your needs.
  • Exciters
    Exciters
    This section presents all our exciters, allowing the creation of a sound wave by the vibration of a surface. Many brands are represented, allowing everyone to find a model that will suit his project. The filters on the page allow you to make a more precise selection according to your needs.
  • Audio Pro
    Audio Pro
    Find in this category all our loudspeakers, compression chambers and horns, intended mainly for use in a professional setting.
  • Ceiling Speaker
    Ceiling Speaker
    Find in this category all our in-wall speakers, ideal for use in a space dedicated to receiving the public or customers, in order to have a very little visible installation.
