DOUK AUDIO H5 MM Phono / Line Preamplifier with GE-4BZ6 Tubes
The DOUK AUDIO H5 is a MM tube phono preamplifier designed to integrate a turntable or an RCA source into a stereo or 2.1 HiFi system.
Reference : 22492
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 01-12-2026.
DOUK AUDIO H5 GE-4BZ6 Tube MM Phono / Line Preamplifier / NE5532 Op-Amp
DOUK AUDIO H5
The DOUK AUDIO H5 is a MM tube phono preamplifier designed to integrate a turntable or an RCA source into a stereo or 2.1 HiFi system. It combines a MM Phono input compatible with moving-magnet cartridges with an RCA Line In input for connecting a DAC, CD player, streamer, computer or other analog source. Its GE-4BZ6 tube stage, powered at 180V, provides a warm sound and rich midrange, while its ±6 dB Bass/Treble tone control allows the sound to be quickly adjusted.
The H5 also features two RCA outputs delivering the same signal simultaneously, as well as a SUB Out with a switchable 180 or 250Hz low-pass filter, making it easier to integrate an active subwoofer. A 20Hz high-pass filter is also available on the Phono input to limit unwanted very low frequencies, particularly those caused by vibrations and the mechanical wow of records.
DOUK AUDIO H5 circuit
DOUK AUDIO H5: Replaceable GE-4BZ6 Tubes or NE5532 Op-Amp
The DOUK AUDIO H5 is designed around two GE-4BZ6 tubes, combined with a tube power supply circuit operating at 180V. This design aims to provide a warm sound, with greater midrange body and an analog depth particularly suited to vocals, jazz and vinyl listening. The tubes can be replaced, but only with compatible 4BZ6 models.
The stage also features a dual NE5532 op-amp mounted on a socket, allowing it to be replaced with a compatible model to explore different sound signatures. Douk Audio specifically indicates compatibility with the OPA2604, OPA2134, LM49720 or MUSES02. A dedicated shield for the tube stage power supply also helps limit interference.
DOUK AUDIO H5: Subwoofer Output with 180/250Hz Low-Pass Filter
The H5 features two RCA outputs as well as a SUB Out dedicated to an active subwoofer. The latter uses a switchable 180 or 250Hz low-pass filter, allowing the frequency range sent to the subwoofer to be limited and facilitating its integration with the main speakers. The maximum SUB output level reaches 3.2V at 180Hz and 5.5V at 250Hz.
The two main RCA outputs retain a full-band signal and can simultaneously power two amplifiers or two active speakers. The volume control operates jointly on the RCA outputs and SUB Out, while the bass and treble controls do not affect the SUB output.
In Phono mode, the 20 Hz high-pass filter helps reduce unwanted infrasonic components, particularly those caused by turntable vibrations and record warping.
DOUK AUDIO H5: Tone Control
The DOUK AUDIO H5 features independent Bass and Treble controls offering a range of ±6 dB, allowing the sound to be quickly adjusted according to the speakers, room acoustics or listening preferences.
The device also incorporates a fourth-generation relay designed to reduce switching noise, as well as a power supply shielding system for the tube stage to limit interference. The Phono input provides a response conforming to RIAA characteristics, while the RCA input offers a frequency response from 20 Hz to 20 kHz (±0.3 dB).
DOUK AUDIO H5 Overview
1Power On / Source Selection
2LED Indicator
3Bass Adjustment
4Treble Adjustment
5Volume Control
6RCA Output
7Subwoofer Output
8180Hz-250Hz Low-Pass Filter
9RCA / MM Phono Input
1020Hz High-Pass Filter
1112V DC ≥1.5A Power Supply via DC Jack
Technical Specifications
Product TypePhono Preamplifier
Tubes2x GE-4BZ6
Op-AmpNE5532 (replaceable DIP8: OPA2604, OPA2134, LM49720, MUSES02)
Inputs1x RCA
1x RCA Phono (MM)
Outputs2x RCA
1x Subwoofer
Input SensitivityRCA: 1V
Phono: 5mV
Output LevelRCA: 2V
Phono: 500mV
Frequency ResponseRCA: 20Hz–20kHz (±0.3dB)
Phono: RIAA
THD+NRCA: 0.5%
Phono: 0.15%
SNRRCA: ≥104dB
Phono: ≥78dB
Subwoofer Output LevelCutoff frequency at 180Hz: 3.2V
Cutoff frequency at 250Hz: 5.5V
High-Pass Filter Cutoff Frequency20Hz
Tone ControlTreble / Bass: ±6dB
Power Supply12V DC ≥1.5A via 5.5/2.1mm DC jack
Dimensions265 × 240 × 65mm
Weight0.8kg
Package Contents1x DOUK AUDIO H5 Phono Preamplifier
2x GE-4BZ6 Tubes
1x 12V DC Power Adapter
InputPhono
OutputSubwoofer
ClassTube amp
