Impedance (Ω)
Speaker Type
Diaphragm type
Loudspeaker diameter (mm)
102 - 460
Efficiency / Sensitivity (dB)
82 - 101
Xmax (mm)
1 - 22
Lowest frequency (Hz)
20 - 4010
Highest frequency (Hz)
0 - 57000
Speaker Power (W RMS)
25 W - 705 W
Jean-François D.
Impeccable !
Vasilios K.
Ça Chauffe !
Woofer
This section presents all our bass drivers dedicated to low frequency reproduction. Many brands are represented allowing everyone to find a model that will suit their project. The filters on the page allow you to make a more precise selection according to your needs.
