AUDIOPHONICS STEALTH Interconnect Cable AES/EBU 110 Ohm 5m
This AES/EBU cable, assembled directly in our workshops in France, offers high-quality design at an affordable price.
Reference : 21383
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 12-11-2026.
Audiophonics Stealth Interconnect Cable AES/EBU 110 Ohm Shielded Gold-Plated 5m
Photo du câble Audiophonics Stealth
This AES/EBU cable, assembled directly in our workshops in France, offers high-quality design at an affordable price. It features a Canare DA202 110 Ohm cable composed of two gold-plated copper conductors, each measuring 0.18mm², and covered with high-performance shielding. The cable is terminated with a Neutrik NC3FXX-EMC and a Neutrik NC3MXX-EMC connector. These 3-pin XLR connectors with gold/nickel-plated contacts also feature 360° shielding to protect the signal from interference that could degrade it.
Audiophonics Stealth AES/EBU: Neutrik NC3FXX-EMC and NC3MXX-EMC connectors
These Neutrik connectors feature a professional design with enhanced RF shielding for critical applications in live performance and recording. Their design ensures a continuous RF shield connection between the cable and the connector housing. This is achieved thanks to circular capacitors that act as a high-pass filter with a cutoff frequency of approximately 10MHz, while a 24-ohm EMI suppression ferrite bead at 1MHz between pin 1 and the cable shield provides a low-pass filter for better RF rejection.
connecteur Neutrik NC3FXX-EMC et NC3MXX-EMC
Product typeAES/EBU modulation cable
Connectors1x Neutrik NC3FXX-EMC
1x Neutrik NC3MXX-EMC
Length5m
CANARE DA202 Cable Specifications
StandardCoaxial 110ohm
Number of conductors2
Conductor diameter0.45mm
Conductor section0.18mm² / 25 AWG
ShieldingBraided
Cond. DCR< 10.6ohm/100m
Attenuation5dB/100m
Neutrik NC3MXX-EMC / NC3FXX-EMC XLR connector specifications
Contact materialBronze
Contact platingHard gold-copper (Au) alloy of 0.2µm on 2µm of nickel (Ni)
Mounting typeSolder contacts
Locking systemLatch lock
Nominal current per contact5A
Nominal voltage< 50V
Package1x Audiophonics Stealth AES/EBU interconnect cable 5m
Length (m)5.0
ShieldingYes
Section (mm²)0.18
ConnectorXLR
Conductors Plating (Cable)Gold
AUDIOPHONICS STEALTH Interconnect Cable AES/EBU 110 Ohm Shielded Gold Plated 5m
