The Neutrik NC3FM-TOP is a combined female and male XLR chassis connector with 3 poles designed for chassis mounting, relying on a sealed TOP construction to ensure direct and reliable interconnection in outdoor environments.
KEY POINTS:
Technical specifications
| Specifications | |
| Product type | Combined XLR connector |
| Connector | 3-pole female + male XLR |
| Contact material | Brass |
| Contact plating | Gold |
| Capacitance between contacts | ≤ 4pF |
| Contact resistance | ≤ 5mΩ |
| Dielectric strength | 1.5kVdc |
| Insulation resistance | > 5GΩ |
| Rated current per contact | 16A |
| Rated voltage | < 50V |
| Insertion/withdrawal force | ≤ 40N |
| Lifetime | > 1000 cycles |
| Standards | UL94V0 IEC 60068-2-20 IP65 & IP67 |
| Temperature range | -30°C to +80°C |
| General | |
| Packaging | Sold individually |
| Max cable diameter (mm) | N/A |
| Mounting type | To weld |
| Connectic | Male & Female |
| Contacts number | 3 |
| Max panel thickness (mm) | N/A |
| Connector | XLR |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
