NEUTRIK NC5FM-TOP 5-Pole Female + Male XLR Connector Chassis Mount
The Neutrik NC5FM-TOP is a combined female and male XLR chassis connector with 5 poles designed for chassis mounting, relying on a sealed TOP construction to ensure reliable signal continuity in outdoor environments.
Reference : 22186
7,15 €tax incl.
5,96 € tax excl.
Neutrik NC5FM-TOP 5-Pole Female + Male XLR Connector Gold-Plated PCB Mount
Thumbnail of the Neutrik NC5FM-TOP
KEY POINTS:
  • The combined female + male side-by-side configuration allows input and output to be grouped at a single connection point, simplifying wiring architecture.
  • The airtight construction prevents air ingress, ensuring long-term stability of electrical performance.
  • The IP65/IP67 rating protects against dust and water splashes, allowing operation in outdoor environments.
  • The design for demanding applications ensures mechanical robustness suited to intensive use constraints.
  • Flame-retardant materials (UL94 V0) limit flame propagation, enhancing integration safety.
  • The die-cast alloy body ensures structural rigidity and resistance to mechanical stress.
Diagram showing the structure of the Neutrik NC5FM-TOP
Technical specifications
Product typeCombined XLR connector
Connector5-pole female + male XLR
Contact materialBrass
Contact platingGold
Capacitance between contacts≤ 7pF
Contact resistance≤ 5mΩ
Dielectric strength1.5kVdc
Insulation resistance> 5GΩ
Rated current per contact7.5A
Rated voltage< 50V
Insertion/withdrawal force≤ 40N
Lifetime> 1000 cycles
StandardsUL94V0
IEC 60068-2-20
IP65 & IP67
Temperature range-30°C to +80°C
PackagingSold individually
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale & Female
Contacts number5
Max panel thickness (mm)N/A
ConnectorXLR
NEUTRIK NC5FM-TOP 5-Pole Female + Male XLR Connector Chassis Mount Gold Plated
The Neutrik NC5FM-TOP is a combined female and male XLR chassis connector with 5 poles designed for chassis mounting, relying on a sealed TOP...
