SURE ELECTRONICS is a specialist in audio and HiFi electronic products, such as amplifier modules, bluetooth modules, or audio amplifiers. They also own the WONDOM brand.
The Wondom CVA-1100 is a 100W amplifier module, consisting of a power section and an amplifier stage. It is primarily designed for distributed speaker installations, such as background music systems. It is capable of delivering 70/100V RMS continuous power without the need for an output transformer, thus reducing the footprint while improving the...
Wondom offers a programming card compatible with Sure brand DSPs. This module is essential for programming the DSP and managing the desired signal processing. Working with the free software SigmaStudio, this one will allow you thanks to a graphic interface to adapt the treatment carried out by your DSP. For this the module connects to the PC simply via...
With the DKT2X20AB, Wondom offers a DIY kit to assemble a 2x20W Class AB amplifier module yourself. Designed with a TDA7576B chip, this kit offers 20W output per channel at 4Ω, guaranteeing high-fidelity sound with low noise. Equipped with a robust heatsink, the DKT2X20AB benefits from an optimal cooling design for increased durability and longevity.
With the DKT2X20D, Wondom offers a DIY kit to assemble a 2x20W Class D amplifier module yourself. Designed with two MP7720 AMP integrated circuits, this kit offers an output of 20W per channel at 4Ω, guaranteeing high-fidelity sound with low noise and high efficiency.
With the DKT4X25AB, Wondom offers a DIY kit to assemble a 4x25W Class AB amplifier module yourself. Designed with a TDA7569BLV chip, this kit offers an output of 25W per channel at 4Ω and has been designed for use as a car radio amplifier. Equipped with a robust heatsink, the DKT4X25AB benefits from an optimal cooling design for increased durability...
Wondom presents its GAB8, a high-quality multi-channel amplifier module designed with particular attention to detail to meet the demands of home theater audio applications. Featuring 10 output channels, including 3 dedicated to subwoofers, the GAB8 offers unrivalled versatility for a wide range of audio configurations, with the possibility of integrating...
The Wondom ICP5 is the latest addition to the Wondom ICP range, with USB UART functionality for control via a PC interface and Bluetooth for control from a mobile application. It is designed to provide an accessible and easy-to-use environment for the control and programming of Wondom JAB systems.
The Wondom AA-JA11114 cable package is a set of cables specially designed to enable users to quickly and easily operate the JAB1 / JAB2 modules and their various functions.
Wondom's JAB2 V2 is an integrated Class D amplifier module, integrating a DSP and a Bluetooth reception function (aptX HD). This version of the JAB2 V2 is capable of delivering a power of 2x50W.
The Wondom JAB3+ is an amplifier module capable of developing a power of 1x60W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP for an all-in-one audio solution. Thanks to the latter, the JAB3+ can be programmed with SigmaStudio and AppControl via an intuitive graphical interface.
The Wondom JAB3+ is an amplifier module capable of developing a power of 2x50W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP for an all-in-one audio solution. Thanks to the latter, the JAB3+ can be programmed with SigmaStudio and AppControl via an intuitive graphical interface.
The Wondom JAB3+, part number AA-JA32474, is an amplifier module capable of developing 2x 30W power at 8 Ohm, and featuring Bluetooth 5.0 (aptX HD) functionality as well as an ADAU1701 DSP chip. Thanks to this DSP chip, the JAB3+ is an all-in-one amplifier module that can be programmed with SigmaStudio, AppControl and PC UI when coupled with a Wondom ICP...
The Wondom JAB3+ is an amplifier module capable of delivering 1x100W of power, supporting Bluetooth 5.0 (aptX HD) and incorporating an ADAU1701 DSP for an all-in-one audio solution. Thanks to this DSP, JAB3+ can be programmed with SigmaStudio and controlled via an intuitive graphical interface (requires the use of a Wondom ICP5 module, not supplied).
The JAB4 is a 4-channel amplifier module featuring Bluetooth 5.0 and an ADAU1701 DSP for an all-in-one audio solution. Based on a TPA3118 amplifier chip, the JAB4 can deliver 30W per channel at 8Ω. Thanks to its DSP, it supports programming via the SigmaStudio PC software.
The JAB5 is an integrated 4-channel audio amplifier board with Bluetooth 5.0 (aptX HD support) and DSP ADAU1701, offering a true all-in-one audio solution. It delivers 4x100W of power at 6Ω. In addition to its Bluetooth input, the JAB5 also has a line input and an I2S input.
This Wondom AA-KA32473 module is a very versatile amplifier, which can be used in a wide range of applications. It has four amplifier chips and is capable of delivering a power of 8x50W. Each chip can be used in PBTL 1x100W mode.
This Battery Management System (BMS) functions as both a power supply and a Li-Ion battery charger type 18650 and has 3 slots and a complete protection system. Very compact, it can power small systems or become a real portable battery. With its MPPT regulators, this module can therefore also operate as a charger, once powered by a voltage of 15-24V. The...
The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while offering more battery slots. The BCPB3 can thus accommodate 5 Lithium 18650 batteries in series.
The PS-BC12312 is a functional cable pack designed to provide quick and easy operation of the Wondom BCPB2 battery power and charging module. It incorporates a battery level LED indicator with a control button, a charge indicator LED and a LED to show when charging is complete. These elements provide a convenient display of the BCPB2 status.
The Sure 500W Boost is a DC-DC converter and voltage booster designed to be integrated into a vehicle. It has a perfect 12V DC input effect suitable for this type of use and will allow you to get an output voltage of 24V, 30V, 36V, 40V or 48V DC as well as a power up to 500W.
The Wondom PS-SP12159 is a SEPIC DC/DC converter (Single Ended Primary Inductor Converter), which converts a 12V DC DC voltage into an adjustable voltage via a DIP switch from 9V DC to 24VDC.
This 50cm 10-pin flat cable allows the connection of Wondom DSP modules to their I/O ports J1. Convenient, it provides easy access to audio inputs and outputs when you are not using the optional RCA interface module. The connectors are in PH 2.0mm format.
