Sine to Square Wave Low Jitter for FifoPi
The Ian Canada SinePi is a low jitter dual input sine to square wave conversion module that allows an external high performance clock oscillator to be adapted to the FifoPi. The SinePi uses an architecture and topology specifically designed to maintain signal integrity and ensure very low additional jitter. A unified sine to square converter has been implemented to eliminate interference between the two active converters. This module also provides full signal isolation between the SinePi and the unselected input to reduce interference and crosstalk. The use of this module is very simple as it can be directly installed on the FifoPi.
Key features :
| Specifications | |
| Product type | Sine to square wave converter |
| Compatibility | FifoPi Q1 / Q2 / Q3 |
