Choisir son association avec l'IEC Cette Shucko V 512S silver associée avec une IEC Oyaide C004, constitue une association de haut niveau. Surement la force du...
The Hypex FusionAMP FA123 plate amplifier can be used to design a two- or three-way active speaker. It is based on two NCore modules capable of developing 2x125W RMS which can also be bridged to form a 1x250W amplifier. There is also a third NCore amplifier delivering 1x100W RMS for a tweeter.
The Hypex FusionAMP FA251 amplifier will allow you to design a one-way active speaker or a sub active subwoofer. This is based on an NCore module capable of developing 250W RMS.
The Hypex FusionAMP FA252 amplifier will allow you to design a subwoofer or a two-way active speaker. It is based on two NCore modules capable of developing no less than 2x250W RMS. The two modules can also be bridged to form a 500W mono amplifier. This high power allows the FA252 to accompany loudspeakers that need a lot of energy to reveal their potential.
The Hypex FusionAMP FA501 plate amplifier can be used to design a subwoofer or speaker as an active channel. It is based on an NCore module capable of developing no less than 500W RMS. This high power allows it to accompany speakers that need a large energy reserve to reveal their potential.
The Hypex FusionAmp FA502 is an amplifier module with integrated DSP, ideal as a design basis for an active 2-way speaker or active subwoofer. Due to the integration of SMPS power supply, DSP and Class D Ncore amplifier, the FusionAmp is one of the best solutions available for active speaker design.
The Hypex FusionAmp FA503 can be an excellent foundation for designing a powerful 2-way or 3-way speaker. It is indeed capable of delivering 2x500W RMS power at 4Ω using a pair of NCore amplifiers. It can also be bridged (BTL mode) to obtain a powerful 1000W RMS amplifier. An additional channel of 100W RMS allows to power a tweeter.
This kit, based on a Nilai500DIY amplifier module and a PS500DIY power supply board, will enable you to design your own 525W (under 4Ω) mono Class D amplifier. As the successor to the NC400, the Nilai500DIY incorporates a completely new control loop topology, taking its performance to a whole new level, for faithful, rich sound reproduction. The...
The successor to the NC400 NCore, the Nilai500DIY mono Class D amplifier module from Hypex is also equipped with a totally discrete buffer stage and integrated voltage regulators, but offers much better performance. As a power amplifier module, it delivers power up to 500W at 4 ohm (THD+N 0.00015%). The use of high-end components and a...
The Hypex UCD180HG module is a Class D power amplifier, capable of delivering 180W and which will adapt to very varied systems, up to high fidelity audio systems, including for professional use.
The UCD amplifiers in the HG range are high-end versions of the UCD180ST and UCD400ST amplifiers. They are available in 2 versions: UCD180HG and UCD400HG. They're perfect for audiophile use.
The ICEPower 2000AS1 HV is a Class D mono amplifier module based on IceEdge technology, capable of delivering up to 1x2000W of power at 4Ω. It features its own switch-mode power supply stage (SMPS) including PFC (Power Factor Correction) for a power supply of flawless reliability and stability.
The ICEPower 2000AS2 HV is a Class D stereo amplifier module based on IceEdge technology, capable of delivering up to 2x2000W of power at 4Ω. It features its own switch-mode power supply stage (SMPS) including PFC (Power Factor Correction) for a power supply of flawless reliability and stability.
Ce module amplificateur stéréo est idéal pour tout amateur désirant un son de qualité Haute Fidelité avec une bonne puissance sans les défauts de la classeD habituelle. Il sera assez facile à mettre en oeuvre avec une alimentation SMPS 800 Re +/-60V.
This LJM L15D-PRO amplifier module features an IRS2092S main amplifier chip and two IRFB4019 Mosfet transistors for power up to 300W at 4 ohms and low distortion (THD+N < 0.06%).
LJM's L15 is a dual mono amplifier module kit, each delivering 150W under 8Ω. These are based on 3 IRFP240 MOSFETs and 3 IRFP9240 MOSFETs used in a Class AB architecture. These modules support power supplies ranging from ±15V to ±70V. Each of the two modules is delivered attached to an aluminium plate, ready to be fixed within an enclosure.
The LJM L20.5 KEC amplifier module is based on 4 pairs of KEC PNP KTB817 and NPN KTD1047 transistors. It therefore operates in class AB and is capable of developing an output power of up to 400W into 4 ohm or 200W into 8 ohm and an output current of up to 15A, while maintaining an ultra-low noise level with a THD+N of 0.001% (A-weighted).
LJM's L7 is a dual mono amplifier module kit, each delivering 150W into 8Ω. These are based on an IRFP240 MOSFET and an IRFP9240 MOSFET, both from Vishay, and benefit from a Class AB architecture. In order to offer the best possible performance, these modules also benefit from a complementary feedback pair circuit (also known as Sziklai Pair) and...
The MX100 is a stereo amplifier module delivering 100W of power at 8Ω. It uses 2 Toshiba TTC5200 transistors and 2 Toshiba TTA1943 transistors. This module also includes a speaker protection, a rectifier filter for the power supply and an overcurrent protection. All you need to do is connect this module to a transformer, which the manufacturer...
LJM's MX50 SE is a dual mono amplifier module kit, each delivering 100W under 8Ω. It is based on a pair of KTD1047 and KTB817 transistors coupled to a Panasonic CBB capacitor at the input. These modules support power supplies ranging from ±15V to ±45V.
These high-precision dual-mono amplifier modules deliver 100 W under 8 ohm. Equipped with precision metal resistors, high quality capacitors, this kit is ideal for high power amplification modules with high-fidelity sound.
This high quality Class AB amplifier module with 4 channels is capable of developing a power of 4x80W under 4Ω, thanks to a TDA7850 chip offering what is more a rich and musical sound reproduction. The latter is mounted on a large heatsink allowing to dissipate efficiently the heat released.
This low-cost yet highly efficient Class AB amplifier module is based on a TDA7377 chip allowing it to develop up to 2x30W under 4Ω. The quality components integrated in this module, such as Nichicon capacitors for filtering or gold-plated contacts, ensure a beautiful sound reproduction.
This Class D stereo amplifier module embeds a TPA3116 chip, capable of delivering 2x50W power under 4Ω or 2x30W under 8Ω with a high efficiency, higher than 92%, while offering a clear and detailed reproduction. It also integrates its own volume control allowing to easily adjust the volume level.
This Class D stereo amplifier module features a TPA3221 chip, capable of delivering 2x85 power at 4 Ohm with 92% efficiency, while guaranteeing clear, detailed reproduction with sub-1% total harmonic distortion. This module also incorporates its own volume control. The amplification chip is topped by a heatsink to efficiently dissipate the heat generated....
This small amplifier module uses a PAM8406 amplifier chip allowing it to deliver 2x3W power at 4Ω. The input is on a 3.5mm jack connector and the output on a screw terminal. This module will thus be able to be perfectly adapted for the design of a small amplified speaker.
