WONDOM GAB8 AA-KA32479 Multichannel Amplifier Module
Wondom presents its GAB8, a high-quality multi-channel amplifier module designed with particular attention to detail to meet the demands of home theater audio applications. Featuring 10 output channels, including 3 dedicated to subwoofers, the GAB8 offers unrivalled versatility for a wide range of audio configurations, with the possibility of integrating 7.3, 7.1, 6.2, 5.1 or 4.2 systems thanks to its 10 channels and 10x 50W power.
Reference : 18755
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 09-06-2026.
Wondom GAB8 AA-KA32479 Amplifier Module Multichannel Class D 5x TPA3244 10x50W 4Ω
Wondom GAB8: Main view
To guarantee flawless audio performance without the ground noise problems of analog input systems, the GAB8 is equipped with a codec 7.1 USB daughterboard interface as input method. This innovative feature guarantees high-quality playback, elevating your listening experience to new heights. What's more, the USB codec requires no driver installation, guaranteeing maximum compatibility with Windows, Mac and Linux systems alike.
Reliability is a top priority in the design of the GAB8. To ensure maximum durability, the GAB8 is equipped with robust, industrial-grade components that are as efficient as they are effective. What's more, the GAB8 is equipped with Plug & Play connectors, greatly simplifying the installation stage and enabling rapid implementation.
Wondom GAB8: Connection diagram
Wondom GAB8: 10 x 50W channels
Powered by 5 TI TPA3244 amplifier chips, each channel of the GAB8 is capable of delivering 50W of power for a total output power of 500W. With its on-board fan, the GAB8 can even deliver a peak power of up to 75W per channel for dynamic, punchy sound.
Wondom GAB8 : 5 TI TPA3244 chips
Wondom GAB8: USB daughterboard for maximum compatibility
Wondom GAB8: Maximum compatibility
The Wondom GAB8 module features a USB interface with codec 7.1 for its digital input. This supports audio signals with bit depths up to 24bit and sampling rates up to 48kHz. By using the digital input, the GAB8 also eliminates the potential ground noise that can occur on analog input stages, guaranteeing impeccable audio quality. This USB module works without driver installation, ensuring maximum compatibility with Windows, Mac OS and Linux systems.
Wondom GAB8: Robust, high-performance components
The GAB8 offers a reliable and stable system, even for demanding applications. To achieve this, it uses high-quality components, specially selected for their durability. In addition, a fan and heatsink installed on the module ensure efficient heat dissipation to maintain module performance and component integrity.
Wondom GAB8: High-end components
Product typeMultichannel amplifier module
Number of channels10 (3 of which are dedicated to subwoofers)
Amplification typeClass D
Amplification chip5x TI TPA3244
Output power10x 50W
InputUSB-C
Efficiency90% @ 10x50W, 24V, 4Ω, 1kHz
Minimum load impedance3Ω
Output noise level169µV @ A-wt, USB
SNR101dB @ 10x50W, 4Ω, A-wt
THD+N0.18% @ 1W, 4Ω, 1kHz, /CH
0.14% @ 10W, 4Ω, 1kHz, /CH
0.69% @ 50W, 4Ω, 1kHz, /CH
DC offset10mV
Supply voltage15-30V DC (power supply sold separately) (for a 3Ω impedance, use a supply voltage less than or equal to 20V)
Dimensions152.4 x 114.3mm
Package1x Wondom GAB8 board
OutputPCB Connector
Channel10
Amplifier chipTPA3244
Power (W)50.0
WONDOM GAB8 AA-KA32479 Amplifier Module Multichannel Class D 5x TPA3244 10x50W 4Ω
Wondom presents its GAB8, a high-quality multi-channel amplifier module designed with particular attention to detail to meet the demands of home...
