The FiiO EH11 Bluetooth on-ear headphones are semi-open headphones offering high-fidelity sound and a retro-futuristic design. Their wooden ear cups, natural sound reproduction and acoustic performance are powered by a 40mm dynamic driver optimised to deliver controlled bass, detailed mid-range and precise treble. The ideal combination for everyday music listening.
The LDAC codec support via Bluetooth 6.0 connectivity ensures a stable connection and high-resolution wireless audio transmission. Combined with a battery life of up to 30 hours and a weight of just 92 grams, the EH11 is ideal for long, comfortable listening sessions, regardless of the connected device, and thanks to the dedicated app offering extensive control over basic functions.
In addition, the foam earpads are replaceable, and a second pair of foam in a different colour is included, ensuring the product's longevity.
The FiiO EH11 pays homage to the iconic mini on-ear headphones of the 1980s, with a modern twist that gives them a retro-futuristic look. The headphones feature a solid, transparent body that reveals the internal components, wooden ear cups and physical buttons, all combining to create a unique aesthetic.
Furthermore, the FiiO EH11 features a semi-open design with ventilation ports and attenuation filters to avoid the muffled sound often associated with closed-back headphones. This design delivers a wider soundstage, improved definition in the midrange and treble, and makes vocals sound more natural and transparent. It also helps to minimise the sound leakage typical of open-back headphones.
Its distinctive design and sound quality are complemented by its lightweight construction. Weighing just 92g and with a clamping force of 1.7N, the EH11 sits comfortably on the head, allowing for extended listening sessions and lasting comfort.
The EH11 headphones feature a 40mm long-throw dynamic driver with a highly damped composite diaphragm to reduce low-frequency dispersion. Furthermore, the resonance frequency has been lowered to 60Hz, enabling deep bass down to 17Hz, resulting in greater impact and improved transient accuracy for enhanced instrument separation.
The FiiO EH11 is designed to be practical and versatile, which is why it features Bluetooth 6.0 connectivity, minimising the need for cables to ensure maximum portability, freedom of movement and broad compatibility. Supporting high-definition LDAC Bluetooth, with a bitrate of up to 990 kbit/s, the EH11 delivers exceptional wireless audio quality certified as Hi-Res Wireless.
In addition, these headphones allow you to connect to two Bluetooth devices at the same time, such as a smartphone and a computer. With a battery life of nearly 30 hours and a full charge in just 2 hours, these headphones will see you through the whole day, whether at work or in your daily life. Listen to music, watch videos or play video games without interruption and without having to worry about the battery.
Using the FIIO Control app, you can fine-tune the EH11’s settings by choosing from a range of pre-set audio profiles (Pop, Classical, Jazz, Rock) or customise the sound yourself. What’s more, a dedicated gaming option is available to enhance the perception of sound effects and their precise positioning, whilst the built-in microphone ensures clear voice communication thanks to its integrated ambient noise reduction.
The wooden earcups of the FiiO EH11 also feature control buttons that allow you to adjust the volume (right earcup) or skip tracks (left earcup) with a simple twist. A button on the headphones allows you to manage the following options:
| Specifications | |
| Product type | Headphones |
| Type of headphones | Semi-open headphones |
| Main chip | JL7018 |
| Frequency response | 17Hz-40KHz |
| Speaker diameter | Ø40mm |
| Dynamic impedance | 16Ω |
| Earphone pressure | 1.7N |
| Bluetooth version | 6.0 |
| Bluetooth codecs | SBC / LDAC |
| Bluetooth calls | Oui |
| Battery life | Up to 16 hours (with LDAC at 85dB) Up to 27 hours (with SBC at 85dB) |
| Diaphragm material | Composite diaphragm |
| General | |
| Weight | 92g |
| Colour | Black transparent |
| Package | 1x FiiO EH11 2x Foam earpads pair (black, gray) 1x USB-A to USB-C cable |
| Color | Black |
| Impedance (Ω) | 16 |
| Efficiency / Sensitivity (dB) | N/A |
| Lowest frequency (Hz) | 17 |
| Highest frequency (Hz) | 40000 |
| Wireless | Yes |
| Cable termination | Wireless |
| Headphone / Earphone connector | Wireless (Bluetooth) |
