OYAIDE PA-02 V2 Interconnect Cable
The Oyaide PA-02 V2 is a balanced dual-conductor shielded audio cable designed to ensure reliable transmission of both analogue and digital signals. It relies on 102SSC copper conductors at 102.3% IACS, combined with a proprietary twisted geometry, to guarantee high conductivity and consistent electrical stability across the full signal path.
Reference : 22179
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 24-11-2026.
Cable sold per metre
Oyaide PA-02 V2 Shielded Balanced Interconnect Cable Copper 2x0.75mm² Ø8.0mm
Oyaide PA-02 V2 : Front view
Suited to both audiophile environments and professional applications, it combines a controlled-impedance balanced architecture with a high-density braided shield, effectively limiting interference while maintaining signal integrity. This approach allows it to integrate into high-fidelity chains as well as AES/EBU links, while retaining stable behaviour under the constraints of installation and use.
Oyaide PA-02 V2 : 102SSC Conductor
The PA-02 V2 relies on the proprietary 102SSC conductor, drawn from primary copper conforming to JIS C1011 to eliminate any impurities associated with recycling, while a surface stripping process removes residual contaminants to promote uniform conduction. This approach is extended through drawing via natural diamond dies, refining the strand structure and improving their consistency, while maintaining a manufacturing tolerance of ±1µm that limits electrical variation. The whole, completed by a double annealing process reducing internal mechanical stress, achieves a conductivity of 102.3% IACS, ensuring stable and predictable signal transmission.
Oyaide PA-02 V2 : Internal structure
Oyaide PA-02 V2 : 3E Structure
The patented 3E technology is based on the concentric combination of three distinct strand diameters, allowing the internal arrangement to be densified while reducing the gaps between conductors. This geometric organisation improves bundle cohesion and ensures a perfectly circular cross-section after twisting, promoting uniform contact with the insulation and limiting thickness irregularities. Beyond the mechanical precision, this homogeneous structure translates into more consistent electrical characteristics, contributing to greater signal stability across the full bandwidth.
Oyaide PA-02 V2 : Shielded balanced architecture
Adopting a traditional two-conductor shielded construction, the PA-02 V2 arranges its conductors at a regular pitch to achieve an impedance of 120 ohms, enabling use in both analogue and digital applications (AES/EBU). This architecture is extended by a 102SSC braided shield, comprising 24 groups of 8 strands of 0.12mm, whose 80% coverage rate effectively limits electromagnetic interference while preserving signal integrity. This structural consistency allows integration in both domestic and professional environments.
Oyaide PA-02 V2 : Halogen-free insulation
The expanded polypropylene insulation with a low dielectric constant reduces capacitive losses, while the halogen-free polyethylene outer jacket, RoHS compliant, introduces a mechanical damping effect that attenuates parasitic vibrations. This material/structure combination limits permittivity variations at low frequencies, resulting in controlled attenuation and more stable bass reproduction. The assembly thus ensures coherent signal transmission, while maintaining mechanical properties suited to the demands of audio installation.
Product typeInterconnect cable
Number of conductors2
Conductor cross-section2x0.75mm²
Conductor material102SSC copper
Insulation materialExpanded polypropylene
Internal filler materialPolyethylene string + washi tape
Shield102SSC copper braided sleeve
Outer jacket materialHalogen-free polypropylene
Cable diameter (nominal)Ø8.0mm
ColorPurple
PackageSold per metre
Diameter (mm)8.0
Insulation materialPE
ShieldingYes
Section (mm²)0.75
Ground / ShieldingYes
OYAIDE PA-02 V2 Shielded Balanced Interconnect Cable Copper 2x0.75mm² Ø8.0mm
The Oyaide PA-02 V2 is a balanced dual-conductor shielded audio cable designed to ensure reliable transmission of both analogue and digital...
