FLAGSHIP KIMBERS Speaker Terminals (Pair)
These Flagship Kimbers speaker terminal are designed using high-quality materials. Their contacts are made of pure copper, while the clamping nut is made of brass and their body is made of black steel. The result is a robust speaker terminal with high conductivity.
1.0 / 5
Reference : 21195
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 24-11-2026.
Flagship Kimbers Speaker Terminals Pure Copper Ø15.4 x 48mm (Pair)
Photo of FLAGSHIP KIMBERS terminal blocks
These Flagship Kimbers binding posts are designed using high-quality materials. Their contacts are made of pure copper, while the clamping nut is made of brass and their body is made of black steel. The result is a robust speaker terminal with high conductivity. Furthermore, their aesthetic appeal offers a unique feature for anyone looking for original and distinctive terminals. They are compatible with banana plugs, bare wires, and 8mm spades.
Dimensions of FLAGSHIP KIMBERS speaker terminals
Product typeSpeaker terminal
Contact materialPure copper
Maximum internal conductor diameterØ4mm
Maximum panel thickness3mm
Drill diameterApprox. 8mm
MountingTo screw
Total dimensionsØ15.4 x 48mm
PackageSold by pair
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)3.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Déçu
Bel aspect cuivre rouge.
Au serrage, c'est la catastrophe.
Le gros pas de vis principal ne peut pas se serrer fermement, métal mou et le pas de vis s'écrase.
Les micro-vis de serrage foirent, leur pas de vis se tort.
Produit chinois bas de gamme.
Le cuivre pur est en effet un métal souple et il convient d’être prudent lors du serrage pour éviter le désagrément rencontré.
This review has been posted for FLAGSHIP KIMBERS Speaker Terminals Pure Copper Ø15.4 x 48mm (Pair)
These Flagship Kimbers  speaker  terminal are designed using high-quality materials. Their contacts are made of pure copper,...
