IFI AUDIO UP PLAY Portable Bluetooth 5.2 Transmitter
New
The iFi Audio UP Play is a compact Bluetooth transmitter designed to connect a smartphone or computer to wireless headphones or earphones. Supporting several codecs, including LDAC, it can transmit music up to CD quality when the paired devices are compatible with this format. Its small size allows it to be integrated into a mobile or desktop setup without requiring a dedicated installation.
Reference : 22673
69,00 €tax incl.
57,50 € tax excl.
iFi Audio UP Play Portable Bluetooth 5.2 Transmitter
IFI AUDIO UP PLAY: Front view
The UP Play from iFi Audio is a compact Bluetooth transmitter designed to connect a smartphone or computer to wireless headphones or earphones. Supporting several codecs, including LDAC, it can transmit music up to CD quality when the paired devices are compatible with this format. Its small size allows it to be integrated into a mobile or desktop setup without requiring a dedicated installation.
iFi Audio UP Play: Suitable for Apple and Android sources
On iPhone, the UP Play transmits the Bluetooth signal in AAC and allows the smartphone to be paired with compatible wireless headphones or earphones. On Android, it supports several high-resolution codecs, including LDAC, aptX Adaptive and aptX HD; the format used depends on the codecs shared by the smartphone and the paired headphones. This versatility makes it easy to integrate the transmitter into different mobile systems while taking advantage of the formats supported by each device.
IFI AUDIO UP PLAY: K2
iFi Audio UP Play: K2 Technology
The K2 technology built into the UP Play acts on the reproduction of digital content to restore harmonics and high frequencies that processing may have attenuated. Enabled from the iFi Nexis app, it applies to music transmitted wirelessly and aims to bring its tonal balance closer to that of the original master. It thus allows the processing to be adapted to listening, whether files come from a digital library or a streaming service.
iFi Audio UP Play: Shared listening with two headphones
The UP Play can connect two pairs of Bluetooth earphones or headphones simultaneously in SBC, allowing the same program to be shared from a single source. This shared transmission is particularly suitable for watching a video or listening to music together, without having to switch between devices.
IFI AUDIO UP PLAY: Headphones
iFi Audio UP Play: Low-latency mode
Bluetooth can introduce a delay between picture and sound, noticeable when watching videos or gaming. The UP Play features a low-latency mode associated with the aptX Adaptive codec; it is enabled from iFi Nexis, subject to compatibility with the headphones used. This function aims to tighten audiovisual synchronization so that dialogue, sound effects and on-screen action are more consistent.
iFi Audio UP Play: Built-in microphone
A microphone located at the base of the UP Play allows you to take calls or join in-game chats without removing the device. Qualcomm noise and echo reduction processing helps limit unwanted sounds picked up during the conversation, making communication easier on the move or in a busy environment.
IFI AUDIO UP PLAY: Nexis
iFi Audio UP Play: Control and updates with iFi Nexis
The iFi Nexis app provides access to settings that extend the transmitter's functions: management of paired devices, display of the active codec, activation of K2 Technology or low-latency mode. It also allows OTA updates to be installed, keeping the UP Play up to date and bringing control of its main functions together on a mobile device.
Technical specifications
Product typeBluetooth transmitter
InputsUSB-C
OutputsBluetooth
Bluetooth version5.2
Supported Bluetooth codecsLDAC / aptX Adaptive / aptX HD / aptX / AAC / SBC
Transmission range≥ 10m
Supply voltage5V DC / ≥0.5A
Consumption< 10mA
Dimensions27.6 x 20.8 x 8mm
Weight3g
ColorBlue
Package1x iFi Audio UP Play
OutputBluetooth
DAC / ADC ChipNC
ColorBlue
Supported Bluetooth codecsAAC
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX Adaptive
The iFi Audio UP Play is a compact Bluetooth transmitter designed to connect a smartphone or computer to wireless headphones or earphones....
