UGREEN BT505 Bluetooth 6.0 Receiver
The Ugreen BT505 is a Bluetooth 6.0 receiver designed for wireless audio playback from mobile devices, featuring LDAC compatibility to transmit high-resolution audio. This extends the frequency response from 20 Hz to 40 kHz, covering the entire audible spectrum and beyond under suitable conditions. The unit is powered by a 300 mAh battery offering up to 15 hours of battery life.
Reference : 21671
44,90 €tax incl.
37,42 € tax excl.
UGREEN BT505 Bluetooth 6.0 Receiver LDAC
UGREEN BT505 : Front view
The Ugreen BT505 is a Bluetooth 6.0 receiver designed for wireless audio playback from mobile devices, featuring LDAC compatibility to transmit high-resolution audio. This extends the frequency response from 20Hz to 40kHz, covering the entire audible spectrum and beyond under suitable conditions. The unit is powered by a 300mAh battery offering up to 15 hours of battery life.
Product typeBluetooth receiver
Bluetooth version6.0
Output1x Stereo RCA
1x Jack 3.5mm
Supported Bluetooth codecsSBC, AAC, LDAC
Transmission range10m
Battery300mAh
Autonomy15h
Power supply5V
Dimensions71 x 66.5 x 24mm
Package1x Ugreen BT505
1x USB-A to USB-C cable
1x 3.5mm jack cable
OutputJack 3.5mm
DAC / ADC ChipNC
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
The Ugreen BT505 is a Bluetooth 6.0 receiver designed for wireless audio playback from mobile devices, featuring LDAC compatibility to transmit...
