Connector
Max cable diameter (mm)
Max sampling rate
DAC / ADC Chip
Material
Class
Length
0 m - 30 m
Section (mm²)
0 mm - 15 mm
Diameter (mm)
Conductors material (Cable)
Input
Output
Remote Control
Networking
Color
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
Cables and Sheaths
Marc C.
Que dire ?
Bertrand j.
neutrik
Ramiro F.
Cables and Sheaths
We offer a wide range of products for the connector industry: connectors, adapters, cords, cables sold by the cut, sheaths, etc... All the necessary connectors for your HiFi installations and assemblies just for you. Each cable and each component is very important in an audiophile system, they must not be neglected.
  • Cables and cords
    Cables and cords
  • Bulk Cables
    Bulk Cables
  • Sleeves
    Sleeves
    Find here the whole of our sheaths and heat-shrinkable sheaths, allowing to finish and dress your cables, thus conferring to these last ones a professional completion while protecting them from the mechanical constraints and the shocks.
  • Cables DIY Kits
    Cables DIY Kits
    Here you will find the DIY Cable Kits that we offer: Modulation Cable Kit, Mains Cable Kit, Speaker Cable Kit (HP). Each Kit includes the necessary components to build a complete High End cable.
    Then it's up to you to play and step-by-step build your connection, in order to improve and improve your entire HiFi installation.
    We offer a custom service for cord assembly, just go to this page : Custom cable assembly with or without sleeves.
