1877PHONO ZV-5 Vinyl Engine with "9.5" AESHNA Aluminium Tonearm Satin Black
By buying this product you get 229 loyalty points
Reference : 11065
2 290,00 €tax incl.
1 908,33 € tax excl.
1877phono ZV5The vinyl turntable1877PHONO ZV-5is an analogue vinyl stereo audiophile reading table offering classic solutions borrowed from the big names of 33 Tours with a design today.
The series ZV-5 Vynil Engineis the logical sequel to the other productions 1877PHONO experiencing a growing success with the amateurs and lovers of the black cake.
The solutions developed are a blend of proven technologies and today's high precision machine tools.
The heart of this vinyl turntable is based on a tray of 35mm (4.5kg)machined on CNC machine with diamond cutting. Because of the precision of mechanical assembly, the vinyl series ZV5 "sound" all exactly the same.
The 35mm aluminum plate uses a stainless steel ball bearing by cryogenic treatment with a mechanical decoupling configuration on a ceramic ball and viscoelastic damping with oil bath.
The rotation of the plate is thus perfectly fluid without noise or parasitic vibration transmitted to the arm 9.5 inches monocorps in machined aluminum with very high precision.
This enginebelt transmission with round cross-section septhe centerpiece of this superb vinyl turntable is based on a proven system of four aluminum inserts whose shapes are calculated to annihilate all micro vibrations towardsthe 9.5-inch armand the platen.
This motor is equipped with an independent regulated, high-level power supply (motor controller) in an external cabinet ensuring a rotation of 33 rpm or 45 rpm. It is thus possible to the tachometer supplied, independently adjust the speed of 33 turns or 45 turns per screw potentiometer on the external power supply.
Each vinyl reading table comes standard with a 9.5 inch aluminum arm 1877PHONO series Aeshna already recognized by the audiophile community for its excellent value for money. This arm of excellent quality is also available as an option with a carbon body.
This vinyl turntableis delivered as standard with an internal arm wiring of Litz Pure OCC and PTFE insulation . The cable with 24K RCA connectors supplied is the 1877PHONO DIN 5 pin model "THE COVE" with three layer PTFE / PE insulation .
In addition a complete bundle allows the installation of this turntable without difficulty.
This vinyl turntable is proving to be a serious challenger of the English and American brands audiophile because of its design quality and the experience of 1877PHONO, already renowned for its solutions dedicated to the world of vinyl.
A full English test of the 1877PHONO ZV-5 vinyl turntable in PDF in download section is available on the CANADAHIFI.COM Webzine.
Click on the logo to read the PDF file.
[Img-17649-left-thickbox_default]
Specifications 1877PHONO ZV5:
  • 35mm thick 35 mm thick aluminum disc, machined on a CNC machine, diamond cut.
  • Axis housing with a cool copper jacket wall. Trayon ceramic ball with viscoelastic liquid.
  • Body of 50mm MDC CNC plate machined in one cycle.
  • AC 33 / 45TRM AC motor with separate power supply at controlled speed.
  • Supplied with 9.5 "mono body aluminum arm" Aeshna Serie "satin silver finish.
  • Color matt black matt satin.
Specification Aeshna arms 9.5 "/ 238mm.
  • Length of arm: 9.5 inches /238.6mm.
  • Dotted: Internal: 62..5mm. External: 127mm.
  • Effective mass: 8.5g.
  • Distance from center of plate to arm pivot: 218mm.
  • Horizontal bearing: Ceramic ball.
  • Vertical Bearing: Stainless steel anti-wear cryogenic treated.
  • Cell weights recommended: 5 to 15gr.
  • Internal wiring: OCC 5Litz7 33AWG PTFE insulation.
  • DIN Output Connectors: 5 PTFE Insulated Pin Gold Plated 24K.
The bundle contains:
  • A vinyl turntable 1877PHONO ZV-5.
  • One arm 9.5 inch series aeshnaaluminum.
  • AC Motor 33/45 Lathes with belt.
  • A machined aluminum plate 30 cm and 35 mm thick.
  • A separate motor controller with 33.3 / 45 rpm adjustment.
  • One set of 15 cm for adjustment.
  • A bubble level.
  • Atachometer for speed control 33.3 turns and 45 turns.
  • Three screwdrivers for adjustment.
  • A wrench with star head for arm mounting.
  • An anti static cloth.
  • Avial of oil"Shark Oil".
  • A black machined head for the motor belt.
  • A black strap with a round cross-section.
  • A pair of black gloves.
Connectors:
  • An insulating DIN5 cable PTFEto stereo RCA "THE COVE"of 1m in PTFEOFCHC.
  • Separate power supply with shifting 33/45 lathes.
  • One mains cable with 2m locking ring for power supply
  • A mains cable of 50cm.
This product does not contain any vinyl cells.
Platinum Dimensions:
  • 480X380X50mm.
Tray:
  • 300mm in diameter, 35mm in thickness.
Power supply:
  • 210x180x60mm.
Engine 33 / 45Tours.
  • 115x125mm
Weight:
  • Platinum: 9.1kg.
  • Plateau 4.5Kg.
  • Power supply: 1100gr.
  • Engine: 1600gr.
[Img-17655-left-thickbox_default]
[Img-17667-left-thickbox_default]
[Img-17673-left-thickbox_default]
[Img-17675-left-thickbox_default]
[Img-17676-left-thickbox_default]
