The Fosi Audio MD3 MagDac is a compact portable magnetic DAC based on the use of an ESS ES9039Q2M DAC chip and no fewer than 4 ES9603Q headphone amplifier chips in a balanced configuration. Compatible with USB Audio Class UAC 2.0 and UAC 1.0, it supports up to PCM 32bit 384kHz as well as native DSD256 in UAC 2.0 mode, and up to PCM 16bit 48kHz in UAC 1.0. It features two headphone outputs, a 3.5mm single-ended jack and a 4.4mm balanced jack, with an output power of ≥ 2x80mW under 32Ω in 3.5mm and ≥ 2x180mW under 32Ω in 4.4mm. Its stated performance includes a frequency response of 20Hz to 48kHz (±0.2dB), a signal-to-noise ratio of up to 116dB, a dynamic range of up to 116dB, THD+N of ≤0.00075% in 3.5mm and ≤0.00084% in 4.4mm, as well as a noise floor below 1.7µV in single-ended mode and 2.7µV in balanced mode. It is compatible with headphones and earphones from 16 to 300Ω. Its dual USB-C connectivity allows audio, image/data transfer, firmware updates, and smartphone charging during use.
Equipped with a 1.28" circular display, the Fosi Audio MD3 MagDac features fun animated images and emojis. It is also possible to customize the screen display with your own photos.
Sixteen high-strength N52 magnets keep the MD3 firmly attached to your phone. This avoids the need for straps and reduces clutter. An aluminum alloy insulating plate separates the PCB from the magnets, preventing any risk of magnetic interference affecting sound quality.
| 1 | LCD Screen |
| 2 | Vista Button |
| 3 | Volume + |
| 4 | Volume - |
| 5 | Menu/Confirm |
| 6 | USB-C Input (Audio Decoding/Image Transfer/Charging) |
| 7 | USB-C Input (Audio Decoding/Image Transfer/Firmware Update) |
| 8 | 3.5mm Jack Headphone Output |
| 9 | 4.4mm Jack Headphone Output |
| Specifications | |
| Product type | Portable DAC |
| DAC chip | ESS Sabre ES9039Q2M |
| Amplifier chips | 4x ESS ES9603Q |
| Inputs | 1x USB-C (Audio Decoding/Image Transfer/Charging) 1x USB-C (Audio Decoding/Image Transfer/Firmware Update) |
| Outputs | 1x 3.5mm single-ended Jack 1x 4.4mm balanced Jack |
| Compatible USB protocol | UAC 1.0 UAC 2.0 |
| Supported sample rates | UAC 1.0 : PCM up to 16bit 48kHz UAC 2.0 : PCM up to 32bit 384kHz, DSD256 |
| Max. output power | 3.5mm Jack: ≥ 2x 80mW under 32Ω 4.4mm Balanced Jack: ≥ 2x 180mW under 32Ω |
| Frequency response | 20Hz-48kHz (±0.2 dB) |
| SNR | 3.5mm Jack: ≥ 115dB 4.4mm Balanced Jack: ≥ 115dB |
| Dynamic range | 3.5mm Jack: ≥ 115dB 4.4mm Balanced Jack: ≥ 115dB |
| THD+N | 3.5mm Jack: ≤ 0.00075% 4.4mm Balanced Jack: ≤ 0.00084% |
| Noise floor | 3.5mm Jack: < 1.7μV 4.4mm Balanced Jack: < 2.7μV |
| Headphone impedance | 16-300Ω |
| Volume control | 100 steps |
| General | |
| Weight | 50g (±2g) |
| Dimensions | 70 x 45 x 12mm |
| Color | Black |
| Package | 1x Fosi Audio MD3 MagDac |
| Input | USB |
| Output | Jack 3.5mm |
| Output | Jack 4.4mm |
| DAC / ADC Chip | ES9039Q2M |
| Max sampling rate | DSD256 |
| Max sampling rate | 384kHz |
| Color | Black |
| Networking | No |
| Remote Control | No |
