SMSL SU-1 DAC AK4493S XMOS XU316 32bit 768kHz DSD512 MQA MQA-CD
Compact and powerful, the SMSL SU-1 DAC represents an affordable and efficient digital to analog conversion solution. Taking advantage of a careful design, it offers a great versatility while allowing a sound restitution of great quality.
4.8 / 5
Reference : 17619
79,90 €tax incl.
66,58 € tax excl.
Shipping date: 28-04-2026.
SMSL SU-1
AKM AK4493S DAC
The SMSL SU-1 is based on the use of the AKM AK4493S 32bit DAC chip, using the proprietary VelvetSound™ technology. This one allows a quality digital / analog conversion with a low level of distortion and a wide dynamic range. The result is a sound reproduction that is as rich as it is accurate for a beautiful listening experience.
XMOS XU316 USB Interface
The SU-1's USB-C input is combined with a powerful XMOS XU316 interface, efficiently processing the received audio signal. In combination with the AK4493S DAC, it allows the SMSL SU-1 to support high resolution audio streams up to PCM 32bit 768kHz and DSD512.
MQA Decoder
The SU-1 also features an MQA (Master Quality Authenticated) decoder. This format offers a very high sound quality, as close as possible to the studio recording, each file being authenticated by the artist, the producer or the copyright holder. SMSL's DAC also supports MQA-CD.
1MQA indicator
2USB indicator
3Optical indicator
4Coaxial indicator
5Stereo RCA output
6Coaxial input
7Optical Toslink input
8USB input
SMSL SU-1 review by Audio Science Review (Amir)
" SMSL cuts the functionality to minimum many need to have high quality conversion of digital to analog from multiple inputs. Performance is superb for the cost as it provides full transparency to the source. I am happy to recommend the SMSL SU-1. "
Test du SMSL SU-1 par Audio Science Review (Amir)
Product typeDAC
DAC chipAK44933S
Inputs1* USB-C
1* Optical Toslink
1* Coaxial
Outputs1* Stereo RCA
Output level2Vrms
THD+N0.00013% (-117dB)
Dynamic range121dB
SNR121dB
USB TransmissionAsynchronous
USB CompatibilityWindows 7/8/8.1/10/11
Mac OSX 10.6 or later
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA 384kHz
Optical / Coaxial : PCM up to 24bit 192kHz, MQA 384kHz
Consumption< 5W
Standby consumption< 0.1W
Dimensions (L*P*H)96*78*27mm
Weight195g
Package1x SU-1
1x USB-A to USB-C cable 1m
DAC / ADC ChipAK4493S
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
33 reviews
Le SU-1DAC est incroyable, mon système modeste devient audiophile.
J’ai déniché pour 20 € un ancien lecteur DVD Sony, en excellent état, avec un vrai charme vintage des années 2000 et une construction robuste. Pas de HDMI, mais des sorties optique et coaxiale, ce qui en fait une base parfaite. Je l’ai donc reconverti en lecteur CD dédié, associé à un DAC SU-1, le tout alimenté par un ampli Marantz.
Résultat : une véritable claque. Mes oreilles n’en revenaient pas. J’ai redécouvert toute ma collection de CD : les instruments sont parfaitement détachés, les voix naturelles, avec une présence presque “live”. Aucune dureté ni coloration numérique, tout reste fluide et précis. Même les basses, sans caisson, sont étonnamment profondes et bien tenues sur de petites enceintes bibliothèque Mission.
Je viens du monde audiophile et j’ai écouté (et possédé) des systèmes valant plusieurs dizaines de milliers d’euros. Et pourtant, à ce prix-là, avec ce DAC intégré à ma chaîne, le résultat est tout simplement bluffant — un véritable petit miracle musical.
Note : 9/10.
This review has been posted for SMSL SU-1 DAC AK4493S XMOS XU316 32bit 768kHz DSD512 MQA MQA-CD
CDA
Ce produit relaye la sortie audio optique (TOSLINK) d'une télévision 4K vers un ampli NAD + enceinte JMLab (un petit hommage au créateur de cet Entreprise Française Jacques Mahul, et à son école d'ingénieur SUPELEC dont il est était issu) de bonnes factures. Je suis très satisfait de cette conversion, en tout cas il ne dénature pas cette installation audio de "moyenne_plus" gamme.
Chaine de commande impeccable pour Audiophonics pour une "première" me concernant. Il y en aura d'autres...
Perfect avec un raccordement sur un pixel
Je l'alimente et l'utilise avec du courant propre de mon smartphone avec un cable belkin 240watts.
La sortie est meilleure que sur le 5v de ma tour.
Pour la sortie Toslink a priori, c'est très bon aussi.
Le tout sur des monitors en class D.
Approbation mitigée mais validé
Il tourne chez moi sous linux (Fedora, Arch) Carte pcie USB externe, alimenté ou pas pour envoyé un peu plus d'ampères. Inécessaire sachant que ce dac a été conçu pour accepté une très faible alimentation en entrée. Il reste évidemment le bruit, mais tout est traité en électronique pour garantir un bon fonctionnement sur tout entrées, notamment l'usb.
Je ne connais pas les caractéristiques de l'AKM mais il semblerait que je sois perplexe face à un ancien dac WM8741.
Je choisis donc [Seabound - Beyond Flatlines] pour session d'écoute sous strawberry en accès PCM à -21 LUFS pour normalisation. Les basses sont assez dynamiques voire punchy et les textures sont un peu en retrait. Le spectre a tendance a shifter légèrement. Il y a un peu de sibilance mais ça semble assez cohérent dans l'ensemble. Des micros détails sont facilement perceptible, la stéréo semble cependant restreinte en terme d'ampleur. Je me pose la question d'une éventuelle stabilisation à la chauffe de l'appareil. Attention, j'ai une tendance à baisser le volume fréquemment pour atténuer certaines phrases des titres.
Je me suis aperçu que j'avais opacifier le rendu avec de la mousse dans mes Adam audio T7v, la lecture est meilleure sans la mousse à l'intérieur et un rapprochement au mur.
Après avoir lu les deux premiers titres en entréé USB, je passe en alimentation externe et Toslink. Il semblerait que le son favorise une autre dynamique et que l'image sorte un peu au dela des enceintes, moins contenu donc.
La lecture n'est pas tout à fait la même, l'architecture du son différemment interprété mieux ressenti, plus vivante, moins gênante j'aurais tendance à dire, des timbres mieux respectés.
Le respect du master est meilleur, malgré une petite baisse de 2db sur le haut du spectre de mes Adam Audio T7v.
Plutôt pas mal pour ce prix la. Il me reste à envisagé à opacifier le local d'écoute qui marque trop de clarté.
Ne vous privez pas
Le rapport qualité prix de ce dac est incroyable. Il me plaît beaucoup. Pour le prix pas moyen d'être déçu.
Compact and powerful, the SMSL SU-1 DAC represents an affordable and efficient digital to analog conversion solution. Taking advantage of a careful...
