FIIO M21 Digital Music Player DAP
New
The FiiO M21 is a stylish Hi-Res portable audio player (DAP) that delivers excellent audio performance. Powered by an 8-core Snapdragon 680 SoC and running Android 13, it ensures fast processing speeds and a smooth user experience, while offering broad compatibility with services such as Tidal, Qobuz, Apple Music, Spotify, and Deezer.
By buying this product you get 32 loyalty points
Reference : 21644
329,00 €tax incl.
274,17 € tax excl.
FiiO M21 Baladeur numérique DAP 4xCS43198 Snapdragon 680 WiFi Bluetooth 5.0 LDAC 32bit 384kHz DSD256 Bleu
FiiO M21
To ensure high-quality sound, the M21 features four CS43198 DAC chips and a balanced amplifier architecture. Its output power reaches 950mW, making it ideal even for use with high-impedance headphones.
The M21 features two USB-C ports, a balanced 4.4mm jack output, and a single-ended 3.5mm jack/coaxial combo output. Its 4.7-inch display ensures a clear and responsive viewing experience. Its dual power mode allows you to use either an external power supply or the internal battery, making it just as convenient for stationary use as it is on the go. Additionally, its bidirectional Bluetooth 5.0 and Wi-Fi capabilities make the M21 particularly versatile.
FiiO M21: 4 CS43198 DAC chips
The four CS43198 DAC chips enable a fully differential eight-channel output design, unlocking the full potential of headphones through exceptional dynamic performance and excellent resistance to interference. The headphone amplifier section employs a two-stage design: the first stage handles voltage amplification, while the second stage handles current amplification, ensuring a purer, more detailed sound.
FiiO M21: DAC Chips
FiiO M21: Amplifier Chips Diagram
FiiO M21 : Un processeur SoC performant
FiiO M21: A high-performance SoC processor
The FiiO M21 is powered by a Qualcomm Snapdragon 680 processor, an octa-core SoC manufactured using a 6nm process that delivers high performance while minimizing power consumption. This SoC enables the M21 to run Android 13 while maintaining a smooth user experience and ensuring compatibility with Hi-Res audio apps.
FiiO M21: Processor Description
FiiO M21: Internal structure
To minimize crosstalk between the digital and analog circuits, the M21 features separate power supply circuits. The analog circuit is also divided among several independent power supplies that power the DAC and the headphone amplifier. This dedicated power supply and its distribution deliver greater audio detail and a refined, natural sound.
The M21's audio circuit incorporates high-precision film resistors and low-drift capacitors to improve sound consistency across channels and frequencies. Ten high-capacity, low-impedance tantalum capacitors power the amplifiers and the digital-to-analog converter, ensuring a constant power reserve and a powerful, dynamic sound.
FiiO M21 : Structure interne
FiiO M21: A high-precision clock signal
To ensure optimal synchronization and stability, the M21 features a 5th-generation FPGA paired with two femtosecond quartz oscillators. As a result, the system delivers a high-precision, low-jitter clock for faithful reproduction of PCM and DSD signals at any sampling rate.
FiiO M21: Clock Signal Diagram
FiiO M21: Long battery life
Thanks to its 4000mAh high-voltage battery, the M21 delivers up to 15 hours of playback via its unbalanced output and up to 12.5 hours via its balanced output, ensuring long hours of listening without any loss of quality. Plus, the built-in 20W fast charging capability lets you fully recharge the battery even during short charging sessions.
FiiO M21 : Long battery life
FiiO M21: Buttons and Connectors
FiiO M21 : Boutons et ports
1Screen
2Status LED
3ON/OFF button
4Volume +
5Volume -
6Multifunction button
7Mode selector
8HOLD button
9Balanced 4.4mm jack headphone output
10Single-ended 3.5mm jack headphone output
11microSD slot
12USB-C port (data/charging)
13USB-C port (charging/power)
14Glass back panel
15Aluminum alloy frame
16Next track
17Play/Pause
18Previous track
Product typeDigital audio player (DAP)
InputsBluetooth 5.0
WiFi
1x Micro SD slot (up to 2To, not included)
1x USB-C (power)
1x USB-C (data)
OutputsBluetooth 5.0
1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 4.4mm headphone output
WiFi2.4GHz / 5GHz
Airplay
DLNA
Internal storage / available storage64Gb / 52Gb
DAC chips4x CS43198
ProcessorQualcomm Snapdragon 680
Screen4.7" (750x1334px)
Battery capacity4000mAh
Battery life15h (single-ended)
12.5h (balanced)
Charging time1.5h (quick charge)
Supported Bluetooth codecs (transmission)AAC, SBC, aptX, aptX HD, LDAC, LHDC
Supported Bluetooth codecs(reception)SBC, AAC, LDAC
Supported sampling rates (DAC)DSD up to DSD256
PCM up to 32bits 384kHz
Supported sampling rates (USB Audio)DSD up to DSD512
PCM up to 32bits 768kHz
Supported sampling rates (Coaxial)DSD DoP up to DSD128
PCM up to 24bits 384kHz
Output parameters (3.5mm output, Super High Gain)
Output power2x 480mW @ 16Ω, THD+N < 1%
2x 405mW @ 32Ω, THD+N < 1%
2x 45mW @ 300Ω, THD+N < 1%
SNR≥ 124dB (A-wt)
THD+N0.0003% (1kHz/-4dB@32Ω)
Output impedance1Ω
Frequency response20Hz-85kHz < 2dB
20Hz-20kHz < 0.02dB
Noise floor2µV
Output parameters (3.5mm output, High Gain)
Output power2x 380mW @ 16Ω, THD+N < 1%
2x 290mW @ 32Ω, THD+N < 1%
2x 35mW @ 300Ω, THD+N < 1%
SNR≥ 123dB (A-wt)
THD+N0.0004% (1kHz/-4dB @ 32Ω)
Output impedance1Ω
20Hz-20kHz < 0.02dB
Noise floor2.1µV
Output parameters (Line output)
SNR≥ 111dB (A-wt)
THD+N0.001% (1kHz/-2dB@32Ω)
Output impedance0.4Ω
Frequency response20Hz-85kHz < 1.8dB
20Hz-20kHz < 0.02dB
Noise floor1.6µV
Output parameters (4.4mm output, Super high gain)
Output power2x 540mW @ 16Ω, THD+N < 1%
2x 950mW @ 32Ω, THD+N < 1%
2x 185mW @ 300Ω, THD+N < 1%
SNR≥ 126dB (A-wt)
THD+N0.0005% (1kHz/-12dB@32Ω)
Output impedance1.5Ω
20Hz-20kHz < 0.03dB
Noise floor2.7µV
Output parameters (4.4mm output, High Gain)
Output power2x 600mW @ 16Ω, THD+N < 1%
2x 720mW @ 32Ω, THD+N < 1%
2x 90mW @ 300Ω, THD+N < 1%
SNR≥ 125dB (A-wt)
THD+N0.0005% (1kHz/-8dB@32Ω)
20Hz-20kHz < 0.03dB
Noise floor2.7µV
Dimensions~68 x 121 x 17mm
Weight~193g
ColorBlue
Package1x FiiO M21
1x Protective case
1x Câble USB-C
UAC Decoding frequency response curve 1
est conditions: -5dB sinusoidal signal, 20Hz-85kHz, line-out (10kΩ load)
Courbe de réponse en fréquence du décodeur UAC 1
UAC Decoding frequency response curve 2
Test conditions: -5dB sinusoidal signal, 20Hz-85kHz, headphone out, high gain mode (32Ω load)
Courbe de réponse en fréquence du décodeur UAC 2
UAC Decoding frequency response curve 3
Test conditions: -5dB sinusoidal signal, 20Hz-85kHz, headphone out, super high gain mode (32Ω load)
Courbe de réponse en fréquence du décodeur UAC 3
UAC Decoding frequency response curve 4
Test conditions: -5dB sinusoidal signal, 20Hz-20kHz, line-out (10kΩ load)
Courbe de réponse en fréquence du décodeur UAC 4
UAC Decoding frequency response curve 5
Test conditions: -5dB sinusoidal signal, 20Hz-20kHz, headphone out, high gain mode (32Ω load)
Courbe de réponse en fréquence du décodeur UAC 5
UAC Decoding frequency response curve 6
Test conditions: -5dB sinusoidal signal, 20Hz-20kHz, headphone out, super high gain mode (32Ω load)
Courbe de réponse en fréquence du décodeur UAC 6
UAC Decoding Distortion Curve 1
Test conditions: -4dB sinusoidal signal, headphone out, high gain mode (32Ω load)
Courbe de distorsion de décodage UAC 1
UAC Decoding Distortion Curve 2
Test conditions: -4dB sinusoidal signal, headphone out, super high gain mode (32Ω load)
Courbe de distorsion de décodage UAC 2
UAC Decoding Distortion Curve 3
Test conditions: -0dB sinusoidal signal, BAL line-out (10kΩ load)
Courbe de distorsion de décodage UAC 3
InputWiFi
InputMicro SD
OutputJack 4.4mm
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipCS43198
Max sampling rate768kHz
Max sampling rateDSD512
ColorBlue
FIIO M21 Digital Music Player DAP 4xCS43198 Snapdragon 680 WiFi Bluetooth 5.0 LDAC 32bit 384kHz DSD256 Blue
The FiiO M21 is a stylish Hi-Res portable audio player (DAP) that delivers excellent audio performance. Powered by an 8-core Snapdragon 680 SoC and...
