Internal width
mm
mm
Internal depth
Internal height
Material
Diameter (mm)
Height
mm
mm
Button type
Number of positions
Color
DIY enclosures and cases
Pavel V.
Very good streamer
Want to start a DIY audio project? This category is for you. You will find all our cases, in which to install your components in order to protect them and of course, to create a performing and aesthetic product.
  • Aluminium Boxes / Cases
    Discover our range of Aluminium cases and chassis for the design of your DIY audio devices.
  • Slimline chassis
    Slimline chassis
    Here you can find all HiFI 2000 enclosures from the Slimline range, which is characterized by thin enclosures that can be installed in racks.
  • ECO Chassis
    ECO Chassis
    The HiFi 2000 ECO range includes a number of enclosures characterized by a high quality of design, combined with a contained price.
  • Galaxy Chassis
    Galaxy Chassis
    Discover the Galaxy range from HiFi 2000. Models with a very nice design quality, particularly robust and ideal for the integration of DIY audio projects.
  • 19" Chassis
    19" Chassis
  • 19" Chassis with Heatsink
  • Mini Dissipante Cases
  • Other Chassis
    Other Chassis
  • Spare Parts
    Spare Parts
    Spare Parts
  • Heatsink
    Heatsink
  • Switches
    Switches
    Switches and buttons are divided into 2 categories:
    • Monostable switch (pushbutton or fugitive button): Returns immediately to its initial position when pressed. It has only one possible position.
    • Bistable switch: When pressed, the switch is engaged and changes position. Several positions are therefore possible, unlike a monostable switch.
  • Various accessories
    Various accessories
