DIY Kits & Boards
Johan V.
Exceptionnel
István R.
not easy to assemble
Paul M.
Excellent speaker cables
DIY Kits & Boards
DIY Kits & Boards
  • DAC Modules
    DAC Modules
  • Amplifier Boards
    Amplifier Boards
    Amplifier Boards
  • Preamplifier modules
  • Headphone amplifier modules
  • Switching Module
    Switching Module
  • Interface Modules
    Interface Modules
  • Subwoofer Modules
    Subwoofer Modules
  • Power Supply Kits
    Power Supply Kits
  • DSP Modules
    DSP Modules
  • Screens / Vu-meters
    Screens / Vu-meters
  • Softstart & Protection
  • PC / HTPC Modules
    PC / HTPC Modules
  • Streamer Modules
    Streamer Modules
