Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Gianfranco P.
Wonderful
Peter Š.
Peter Š.
Tomislav N.
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 13740
    In Stock
    Jantzen Audio Cross Cap MKP 400V capacitors are considered to be the best value for money for the design of passive filters for loudspeakers. Of European manufacture, this new competitor to the German, French and English references enjoys a very high quality of design.
    13,80 € 11,50 €Ex.
    In Stock
  • Ref : 11773
    In Stock
    Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the German, French and English references enjoys a very good design quality. They are ideal for parallel RL and RLC "plug" correction in parallel circuit, instead of low quality...
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 11764
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 11765
    In Stock
    2,70 € 2,25 €Ex.
    In Stock
  • Ref : 11774
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 11775
    In Stock
    18,00 € 15,00 €Ex.
    In Stock
  • Ref : 15563
    21,30 € 17,75 €Ex.
    In Stock
  • Ref : 11776
    In Stock
    23,20 € 19,33 €Ex.
    In Stock
  • Ref : 11766
    In Stock
    3,40 € 2,83 €Ex.
    In Stock
  • Ref : 11777
    In Stock
    25,20 € 21,00 €Ex.
    In Stock
  • Ref : 11767
    In Stock
    4,50 € 3,75 €Ex.
    In Stock
  • Ref : 11778
    29,80 € 24,83 €Ex.
    In Stock
  • Ref : 11768
    4,80 € 4,00 €Ex.
    In Stock
  • Ref : 11779
    In Stock
    32,20 € 26,83 €Ex.
    In Stock
  • Ref : 11769
    In Stock
    5,40 € 4,50 €Ex.
    In Stock
  • Ref : 11780
    In Stock
    37,70 € 31,42 €Ex.
    In Stock
  • Ref : 15459
    In Stock
    Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most other standard electrolytic capacitors.
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15480
    In Stock
    4,70 € 3,92 €Ex.
    In Stock
  • Ref : 15468
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15481
    In Stock
    5,40 € 4,50 €Ex.
    In Stock
  • Ref : 15469
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15482
    In Stock
    5,50 € 4,58 €Ex.
    In Stock
  • Ref : 15470
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15471
    In Stock
    2,10 € 1,75 €Ex.
    In Stock
  • Ref : 15458
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15460
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15461
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 15483
    In Stock
    6,70 € 5,58 €Ex.
    In Stock
  • Ref : 15472
    In Stock
    2,10 € 1,75 €Ex.
    In Stock
  • Ref : 15484
    In Stock
    9,40 € 7,83 €Ex.
    In Stock
  • Ref : 15473
    In Stock
    2,60 € 2,17 €Ex.
    In Stock
  • Ref : 15462
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 15463
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 15485
    In Stock
    10,70 € 8,92 €Ex.
    In Stock
  • Ref : 15486
    In Stock
    11,40 € 9,50 €Ex.
    In Stock
  • Ref : 15474
    2,80 € 2,33 €Ex.
    In Stock
  • Ref : 15475
    In Stock
    3,10 € 2,58 €Ex.
    In Stock
  • Ref : 15464
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 15487
    In Stock
    14,20 € 11,83 €Ex.
    In Stock
  • Ref : 15476
    In Stock
    3,30 € 2,75 €Ex.
    In Stock
