Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Thierry b.
Toute la...
remy l.
bon cable bonnes prises
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
