Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Domenico C.
Highly performing
Truly high-performance signal cables: I've tried several others over time, even more expensive ones. But these are the...
freddy w.
bluffé et dubitatif
Bj, j'ai suivi un avis au final d'un ami qui m'a assuré que j'allais tomber parterre en écoutant ce cable...
Françoise B.
Dans un système de qualité, ceux qui sont encore septique sur le traitement du signal numérique ethernet il faut essayer cet...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 4197
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero...
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4198
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4195
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 4199
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 4200
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 4201
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 4202
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4203
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 4204
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 4205
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 4206
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 4208
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 4209
    In Stock
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 4210
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4222
    159,90 € 133,25 €Ex.
    In Stock
  • Ref : 4207
    In Stock
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 4212
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4213
    61,90 € 51,58 €Ex.
    In Stock
  • Ref : 4211
    In Stock
    48,90 € 40,75 €Ex.
    In Stock
  • Ref : 4215
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 4216
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 4214
    In Stock
    53,90 € 44,92 €Ex.
    In Stock
  • Ref : 4217
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 4218
    In Stock
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 4219
    In Stock
    109,90 € 91,58 €Ex.
    In Stock
  • Ref : 4220
    In Stock
    119,90 € 99,92 €Ex.
    In Stock
  • Ref : 4975
    In Stock
    Mundorf BS100 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal internal structure for good magnetic characteristics with very low losses and low distortion.
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 4987
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 4988
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4981
    Out of stock
    27,40 € 22,83 €Ex.
    Out of stock
  • Ref : 6118
    In Stock
    Mundorf BS140 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal internal structure for good magnetic characteristics with very low losses and low distortion.
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 2765
    In Stock
    60,90 € 50,75 €Ex.
    In Stock
  • Ref : 6119
    In Stock
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 6117
    In Stock
    42,90 € 35,75 €Ex.
    In Stock
  • 49,90 € 41,58 €Ex.
    In Stock
  • Ref : 2763
    In Stock
    58,90 € 49,08 €Ex.
    In Stock
  • Ref : 18331
    Metal foil coils are physically the best designed. The output quality is constant up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    299,90 € 249,92 €Ex.
    In Stock
  • Ref : 12288
    359,90 € 299,92 €Ex.
    In Stock
  • Ref : 12287
    In Stock
    149,90 € 124,92 €Ex.
    In Stock
  • Ref : 2800
    25,90 € 21,58 €Ex.
    In Stock
