Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Color
Electronic components
Hector T.
Grésille
Hector T.
Combiné avec mes Truthear Nova, j´ai enfin la puissance nécessaire pour écouter mes musiques pleinement.
Les bass sont...
Hector T.
Bien mais gros
Le connecteur fonctionne correctement, mais ma coque (Apple) bloque un peu la connexion et je dois forcer pour le brancher...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 2821
    Metal foil coils are physically the best designed. The output quality is constant up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    164,00 € 136,67 €Ex.
    In Stock
  • Ref : 2822
    179,00 € 149,17 €Ex.
    In Stock
  • Ref : 2823
    199,00 € 165,83 €Ex.
    In Stock
  • 10,90 € 9,08 €Ex.
    In Stock
  • Ref : 11994
    In Stock
    11,50 € 9,58 €Ex.
    In Stock
  • Ref : 11995
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 11996
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 11997
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 11998
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 12286
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 12000
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 12001
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 11980
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 12002
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 12003
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 12005
    In Stock
    40,90 € 34,08 €Ex.
    In Stock
  • Ref : 12006
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 12007
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 12004
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 12009
    In Stock
    40,90 € 34,08 €Ex.
    In Stock
  • Ref : 12010
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 12008
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 12012
    In Stock
    65,90 € 54,92 €Ex.
    In Stock
  • Ref : 12013
    In Stock
    74,90 € 62,42 €Ex.
    In Stock
  • Ref : 12011
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 12014
    93,00 € 77,50 €Ex.
    In Stock
  • Ref : 11979
    53,90 € 44,92 €Ex.
    In Stock
  • 113,00 € 94,17 €Ex.
    In Stock
  • Ref : 12016
    123,00 € 102,50 €Ex.
    In Stock
  • Ref : 3832
    This new range of Zero-Ohm coils combines a hand-tuned Feron core with the extreme conductivity of a Copper ribbon. This technique allows to reach a very good pulse reproduction thanks to a very low internal impedance.
    162,60 € 135,50 €Ex.
    In Stock
  • Ref : 3833
    167,30 € 139,42 €Ex.
    In Stock
  • Ref : 3834
    In Stock
    171,90 € 143,25 €Ex.
    In Stock
  • Ref : 3835
    In Stock
    176,60 € 147,17 €Ex.
    In Stock
  • Ref : 3836
    181,20 € 151,00 €Ex.
    In Stock
  • Ref : 3823
    85,40 € 71,17 €Ex.
    In Stock
  • Ref : 3825
    In Stock
    89,10 € 74,25 €Ex.
    In Stock
  • Ref : 3826
    In Stock
    91,00 € 75,83 €Ex.
    In Stock
  • Ref : 3824
    87,30 € 72,75 €Ex.
    In Stock
  • Ref : 3827
    In Stock
    92,90 € 77,42 €Ex.
    In Stock
