Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Rastislav K.
Nice
Marc A.
Un bon cable...
David m.
une super prise hifi
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 1792
    In Stock
    Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor coating and the winding is impregnated with a special oil.
    209,00 € 174,17 €Ex.
    In Stock
  • Ref : 1793
    In Stock
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 2181
    In Stock
    The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 2174
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 2182
    31,50 € 26,25 €Ex.
    In Stock
  • Ref : 2183
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 2184
    In Stock
    La métallisation de la feuille du condensateur MCap Supreme SilverGold est composé d'Argent pur mélangé a 1% d'Or très pur. L'or Modifie la structure cristalline d'argent et maximise son excellente conductivité électrique.
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 2185
    40,80 € 34,00 €Ex.
    In Stock
  • Ref : 2187
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 2189
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 2191
    95,00 € 79,17 €Ex.
    In Stock
  • Ref : 2192
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 2193
    In Stock
    129,90 € 108,25 €Ex.
    In Stock
  • Ref : 2195
    In Stock
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 2196
    120,80 € 100,67 €Ex.
    In Stock
  • Ref : 2197
    132,80 € 110,67 €Ex.
    In Stock
  • Ref : 2198
    153,30 € 127,75 €Ex.
    In Stock
  • Ref : 2194
    In Stock
    105,00 € 87,50 €Ex.
    In Stock
  • Ref : 4018
    In Stock
    Thanks to the latest winding technologies, Mundorf is able to manufacture its MCap ZN capacitors from ultra-pure, RoHS-compliant tinfoil. Their high conductivity ensures lively sound reproduction of music.
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4019
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 4023
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 4025
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 4026
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4027
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4029
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4030
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 3831
    This new range of Zero-Ohm coils combines a hand-tuned Feron core with the extreme conductivity of a Copper ribbon. This technique allows to reach a very good pulse reproduction thanks to a very low internal impedance.
    158,00 € 131,67 €Ex.
    In Stock
  • Ref : 3830
    In Stock
    155,00 € 129,17 €Ex.
    In Stock
  • Ref : 13777
    The Mundorf MCoil Drum Core Ferrite selfs are made of OFC Copper wire. They are developed for applications requiring small dimensions, low distortion and the lowest possible internal resistance, while maintaining an excellent price/quality ratio.
    14,50 € 12,08 €Ex.
    In Stock
  • Ref : 6008
    In Stock
    These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of tinned Copper with a diameter of 1.2mm allow compatibility with most "Snap In" capacitors.
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 6007
    18,50 € 15,42 €Ex.
    In Stock
  • Ref : 5993
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 5992
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 5991
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 5996
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 5995
    In Stock
    30,90 € 25,75 €Ex.
    In Stock
  • Ref : 5994
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 5998
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 5997
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 6001
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
