Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
mickael C.
Une des meilleures prises
mickael C.
Michel P.
Michel P
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 15336
    In Stock
    The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer details and a much better spatialization.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4071
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 16061
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4072
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4073
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4074
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 16109
    The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors.
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 16113
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16114
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16115
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16116
    In Stock
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 16118
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 16122
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16123
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16124
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16125
    In Stock
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 16134
    In Stock
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 16136
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 16137
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16126
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16127
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16138
    In Stock
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 16139
    In Stock
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 16143
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16128
    In Stock
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 16129
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16140
    In Stock
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 16141
    In Stock
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 16130
    In Stock
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 16142
    In Stock
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 16131
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16132
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16133
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 13615
    In Stock
    These coils are recommended for filtering bass speakers. Their low impedance improves impulse response for a loudspeaker with better handling.
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 1696
    The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
    155,00 € 129,17 €Ex.
    In Stock
  • Ref : 1695
    165,00 € 137,50 €Ex.
    In Stock
  • Ref : 1697
    In Stock
    he Zero Ohm Coil (ZOC) is a transformer format coil. It is made of FERON, a high quality material that limits distortion to a minimum.
    In Stock
  • Ref : 1707
    In Stock
    339,00 € 282,50 €Ex.
    In Stock
  • Ref : 1708
    In Stock
    239,00 € 199,17 €Ex.
    In Stock
  • Ref : 1709
    In Stock
    399,00 € 332,50 €Ex.
    In Stock
