Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Yves F.
Marvelous DAC
Ma configuration : Denon PMA 3000NE, streamer dmp a6 master edition gen 2 + dac holo cyan 2 (connection en USB : câble Black...
Raymond L.
Service Clientèle c'est une sans faute et en plus !
Sans parler de cet achat, le service clientèle est parfait avec une aide qui ne pousse pas à acheter plus et plus cher....
Luca R.
Excellent distributeur électrique
Avec ce prix, vous ne pouvez pas demander plus , ici nous avons :
· Un beau châssis entièrement en aluminium noir.
· 5...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 12530
    In Stock
    This 3.3 MHz 20 Hz 3.3 MHz clock will allow you to replace the original quartz on an audio module or add it to a lower jitter.
    1,95 € 1,63 €Ex.
    In Stock
  • Ref : 17072
    In Stock
    This SMD LED light bulb with BA15S base has five cool blue LEDs. It is ideally suited for vu-meters, tuners or other lighting of your HiFi devices and DIY projects.
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 17066
    In Stock
    This SMD LED light bulb has five cool blue LEDs. It is ideally suited for vu-meters, tuners or other lighting of your HiFi devices and DIY projects.
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 17067
    In Stock
    This SMD LED light bulb has five warm white LEDs. It is ideally suited for vu-meters, tuners or other lighting of your HiFi devices and DIY projects.
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 19345
    In Stock
    Sonic Imagery Labs' model 252AP is a high-performance, discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise and low distortion are required. The 252AP is particularly well suited to circuits with medium to high source impedance, and to microphone input transformers with high transformation...
    95,00 € 79,17 €Ex.
    In Stock
  • Ref : 9356
    In Stock
    The Sonic Imagery Labs 990ENH-TICHA model is a high-performance, discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. This model has been designed to replace Jensen JE990, Automated Processes Inc API-2520, John Hardy Co...
    95,00 € 79,17 €Ex.
    In Stock
  • Ref : 9357
    In Stock
    Sonic Imagery Labs' model 992ENH-TICHA is a high-performance, single discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. The 992ENH-TICHA discrete OPA achieves a new standard of noise excellence with a measurement at...
    55,90 € 46,58 €Ex.
    In Stock
  • Ref : 9354
    In Stock
    Sonic Imagery Labs' model 994ENH-TICHA is a high-performance dual discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. The 994ENH-TICHA discrete OPA achieves a new standard of noise excellence with a measurement at 0.89nV/Rt.Hz...
    109,00 € 90,83 €Ex.
    In Stock
  • Ref : 9355
    In Stock
    Sonic Imagery Labs' Model 995FET-TICHA is a high-performance, discrete operational amplifier (OPA) designed for professional audio applications and areas where ultra-low noise, low distortion and highly linear, uncolored operation are required. A matched-pair FET input stage is integrated to provide superior sound quality and speed for outstanding audio...
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 19195
    In Stock
    This is a fixed-mode positive LDO voltage regulator with 1A output current. It has been designed to receive a maximum input voltage of 20 V and to provide an output voltage of 3.3 V. It is also equipped with various protections, such as output current limiting and automatic shutdown in the case of overheating.
    0,80 € 0,67 €Ex.
    In Stock
  • 3,90 € 3,25 €Ex.
    In Stock
  • Ref : 16067
    In Stock
    This Sovtek 12AX7LPS dual triode tube is a dual triode offering high linearity, making it an excellent replacement for a 12AX7 tube.
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 16027
    In Stock
    This Sovtek 12AX7WA/7025 double triode tube with low gain and extremely low microphony is ideal for the replacement of a 12AX7/ECC83 tube, or in a DIY setup. This model is known for its musicality and the roundness of its reproduction.
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 17622
    In Stock
    This double triode tube with equipotential cathodes Sovtek 12AX7WB/7025 offers a higher gain and saturation than the model 12AX7WA. This model is known for its musicality and the roundness of its reproduction.
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 16028
    In Stock
    This Sovtek 12AX7WC dual triode tube is a dual triode with equipotential cathodes. It is designed to amplify low frequency voltages.
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 16029
    In Stock
    The Sovtek 5881WXT is an extremely fialbe tetrode type power tube. Built to rigid military standards, the 5881WXT tolerates higher voltages than most other types of 6L6 tubes. It is frequently used to replace defective 7027 tubes.
    31,90 € 26,58 €Ex.
    In Stock
  • 20,90 € 17,42 €Ex.
    In Stock
  • Ref : 6173
    In Stock
    This Russian-made, audiophile-quality 6H30PI power tube from Sovtek (sometimes also called 6H30, 6N30 or 6N30P), often used in pre-amplifiers, gives your tracks an analogue touch, making them sound showery and warm.
    34,90 € 29,08 €Ex.
    In Stock
  • 23,90 € 19,92 €Ex.
    In Stock
  • Ref : 16032
    In Stock
    The 6L6WXT+ power tube is based on the vintage RCA 6L6GC design. However, it features larger plate dimensions and an improved grille structure for better power handling. It also features mica spacers with metal springs to eliminate noise and microphony.
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 6429
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 16031
    In Stock
    The Sovtek EL84SOV/6BQ5 is a pentode tube with equipotential cathode, designed to amplify low frequency power in the output stages of HiFi audio devices. It offers a soft, warm and round sound reproduction.
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 16030
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 13906
    In Stock
    Some discrete OPA use a different pinout from the DIP8 standard, such as the SS2590 from Sparkos Labs. This API to DIP8 adapter will therefore allow you to use such a OPA on DIP8 support. Mounting is simple since it is enough to place your OPA on the adapter and make a few solderings and then cut the legs that protrude under the PCB.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 15071
    In Stock
    This adapter allows you to simultaneously install two Sparkos discrete AOPs (tyoe SS2590) on a stereo connector on DIP8. It thus allows a pair of sparkos discrete mono AOPs to be used on a stereo AOP slot.
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 13969
    In Stock
    The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of discrete regulators designed to replace adjustable monolithic regulators. They are in the standard format TO-220 with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14484
    44,94 € 37,45 €Ex.
    In Stock
  • Ref : 14518
    The Sparkos Labs brand, which specializes in the design of high quality discrete electronic components, has created a range of discrete controllers to advantageously replace adjustable monolithic controllers. They are in the standard TO-220 format with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18351
    In Stock
    The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of ré discrete regulators designed to replace adjustable monolithic regulators. They are in the standard format TO-220 with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 13304
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18352
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18353
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18979
    In Stock
    After the undeniable success of the SS3601 and SS3602 discrete OPA, SparkoS Labs focused on discrete OPA that can be found in studio equipment or recording devices, such as the API2520 operational amplifier or the Jensen 990. After numerous tests and measurements, SparkoS Labs decided to offer a much more efficient OPA. Here, two SS2590 AOPs have...
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 13897
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 13168
    In Stock
    SparkoS Labs has created a range of discrete DIP8-mounted PDOs optimized to deliver excellent audio performance. They will allow you to replace less powerful AOP or quite simply to obtain a different sound.
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 13169
    In Stock
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 14810
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18874
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 13968
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14497
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
