Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Marcus L.
Michael M.
Worth every penny!
mathieu l.
IEC Connectors
Discover our range of IEC connectors of all sizes, for the design of your HiFi power cables.
