Connector
Max sampling rate
DAC / ADC Chip
Amplifier chip
Class
Power (W)
5 - 165
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Connectic
Length
1 m - 2 m
Conductors material (Cable)
Contacts Plating (Connector)
Channel
Input
Output
Remote Control
Networking
Transmission / Reception protocol
Streaming services
Color
Conductors Plating (Cable)
Shielding
Jean Jacques R.
gaine large
j'ai du re-commander cette dimension pour mettre 2x cables de diam 7mm, je pensais que la gaine 7-14 pouvait faire 14mm de...
Jean-François G.
Nouvelle TV, nouvelle connectique: pas de sortie audio analogique ni de prise casque. L’utilisation de ce petit appareil a...
Raul P.
Good speaker
For that price speaker is relay good in full range. To get 80Hz like described you need a biger box.
Headphone amplifier / Preamplifier
Découvrez notre gamme complète d'Amplificateur casque et de Préamplificateur audio. De l'ampli casque mobile à l'ampli casque sédentaire, vous trouverez l'appareil HiFi pour casque audio correspondant à vos attentes et vos besoins.
Soyez également certain de la qualité des Préamplificateurs HiFi que nous vous proposons, qui saurons sublimer et améliorer considérablement votre rendu sonore.
  • Mobile HP Amplifiers
    Discover our range of portable headphone amplifiers, designed for use both at home and on the move, thanks to a compact form factor and an adapted design. Enjoy the best sound quality, wherever and whenever you want.
  • Desktop headphone amplifiers
    Want to enjoy optimal headphone listening at home? Our range of sedentary headphone amplifiers is made for you. A wide selection of headphone amplifiers for both sensitive headphones and high-impedance models.
  • Preamplifiers & Volume Controllers
    Discover our selection of preamplifiers and volume controllers, powerful models to promote excellent sound reproduction for your audio system.
  • Vinyl Preamplifers
    Vinyl Preamplifers
    Do you want to go back to the roots of analog HiFi and enjoy the warm sound of your turntable? A phono preamplifier is then a must to provide your system with the necessary gain to enjoy your equipment at its best.
