YULONG Audio D200 DAC ES9016 DSD 32bit / 384kHz
By buying this product you get 55 loyalty points
Reference : 9000
559,00 €tax incl.
465,83 € tax excl.
The DAC DSD 32 bits / 384 kHz has an architecture similar to the DA8 but articulated around the Saber ES9016.
Featuring simplified operation, compact, solid construction and a complete set of inputs: USB, Toslink, SPDIF and AES for digital inputs.
The result is a good balance between dynamics, resolution and fullness. It is optimized for all types of music.
The D200 uses an ESS9016, accompanying an OP275 LPF, and an OPA1632 as a buffer and preamp.
The Class A headphone output is high-end. A design built with MJD243 / 253 transistor and with short circuit protection at output. A high quality power supply including a Canadian Plitron toroidal transformer.
The LCD screen makes it easy and intuitive to use. The LCD screen darkens by 80% after 5 seconds of inactivity. User settings are automatically saved.
You can activate pure DAC mode, which will disable volume control and turn off the headphone amplifier for ultimate DAC performance.
TheThe USB input is based on an asynchronous XMOS interface, featuring three low noise clocks. It supports DSD, 32MB / 384kHz PCM, and is compatible with MacOSX, Linux and Windows.
Technical characteristics :
  • THD + N less than 0.0005%
  • DSD native / Dop
  • Class A Headphone Amplifier
  • Frequency response: 20 - 30kHz at 0.2dB
  • Signal to noise ratio: -125dB
  • Dynamic:> 122dB
  • Aluminum housing
  • Weight: 1.6kg
  • Dimensions: 250 x 180 x 45mm
Qobuz
Test in French
