TOPPING HYNOTONE ARES Guitar Distortion Pedal
-15%
Topping, following on from its Topping Professional range of USB audio interfaces, unveils a distortion pedal for guitar with its new Hynotone range.
4.0 / 5
Reduced price!
Reference : 20457
Limited time offer:
99,00 €tax incl.
-15%
84,15 €tax incl.
70,13 € tax excl.
Shipping date: 24-11-2026.
Topping Hynotone Ares Guitar distortion pedal
TOPPING HYNOTONE ARES pedal picture
Topping, following on from its Topping Professional range of USB audio interfaces, unveils a guitar distortion pedal as part of its new Hynotone range. The pedal is based on a 5-stage JFET circuit, faithfully reproducing the warm, dynamic character of the tube designs favored by musicians.
Ideal for styles such as metal or hard rock, the Topping Hynotone Ares pedal offers a complete interface for adjusting the sound to your preferences. It incorporates three EQ potentiometers (Bass, Mid, Treble), a volume control, a gain control, and three switches with specific functions: “Bite”, “Tight” and “Boost”. Thanks to its design, it's perfectly suited to 7-string guitars and Drop tunings.
Please note that the pedal's power supply is 9V via DC 5.5/2.1mm jack negative center (Typ: 10mA / Max: 100mA).
Description of TOPPING HYNOTONE ARES potentiometers and control switches
Topping Hynotone Ares: JFET circuit
The Topping Hynotone Ares 5-stage JFET circuit delivers the warmth and dynamics characteristic of tube amplifiers, while maintaining excellent tonal clarity. The result is organic, reactive distortion, faithful to the nuances of the guitarist's playing.
JFET circuit for HYNOTONE ARES TOPPING pedal
Tone adjustment for TOPPING HYNOTONE ARES pedal
Hynotone Ares Topping: Tone control
Equipped with a true tone stack, the Hynotone Ares Topping pedal features Bass, Mid and Treble controls, faithfully reproducing the EQ control of tube amplifiers. This flexibility allows guitarists to sculpt their sound with great precision, whether it's a big, saturated sound or a sharper, more defined distortion.
Hynotone Ares Topping: 3 precision adjustment switches
BITE function on HYNOTONE ARES TOPPING pedal
BITE
The BITE function of this distortion pedal adds raw, gritty distortion by enhancing the midrange.
TIGHT function on HYNOTONE ARES TOPPING pedal
TIGHT
The TIGHT function, for its part, refines the bass for a more aggressive and precise sound.
BOOST function on HYNOTONE ARES TOPPING pedal
BOOST
With a built-in BOOST function, the Ares distortion pedal tightens the bass and enhances the midrange, delivering an aggressive, modern sound.
Product typeGuitar pedal
EffectDistorsion
CircuitJFET
InputJack 6.35mm
OutputJack 6.35mm
Tone control
Input impedance1Mohm
Output impedance1Kohm
Power supply9V via DC 5.5/2.1 jack negative center (Typ: 10mA / Max: 100mA)
Dimensions65 x 125 x 60mm
Weight315g
Package1x Topping Hynotone Ares distortion pedal
Top à ce prix
Bonjour,
Guitariste et audiophile, j'étais intrigué par cette pédale fabriquée par une marque issue du monde de la hi-fi et j'ai donc sauté le pas.
Niveau qualité de fabrication, rien à dire, c'est propre, les switchs et les potards inspirent confiance, le boitier est robuste. je trouve les potards très agréable et à titre personnel, je trouve le design générale simple mais très efficace.
Niveau son, on a bien affaire à une distorsion, un peu aigue à mon gout mais pas criard pour autant. Les potards agissent plutôt bien sur le son. Par contre il y a à redire sur les switch.
Le boost fonctionne très bien, on entend clairement la différence quand on l'active. Il a le même effet qu'un boost placé avant la pédale, il fait ressortir des harmoniques et donne un son plus tranchant, plus "metal". Une réussite pour moi.
Par contre, je n'entends pas du tout de changement de son avec les deux autres (le bite et le tight). Le tight est préconisé pour les guitares 7 cordes, ce que je n'ai pas, il est donc normal (je suppose) de ne pas entendre de différence. Le bite n'est pas préconisé pour une config en particulier et je n'entends aucune différence avec ou sans. A voir si on entend quelque chose sur une autre config.
La pédale a été testée sur un ampli à lampe blackstar avec une Ibanez équipée de Di Marzio air norton et tone zone.
Conclusion: Une excellente pédale pour ce prix même si certains switch ne semblent pas impacter le son. Comparé à une Chug Lite, elle n'a pas à rougir. Juste une question de goût.
This review has been posted for TOPPING HYNOTONE ARES Guitar Distortion Pedal
