AUDIOPHONICS HC TRIGGER SWITCH MKII Home Cinema Power Trigger Symmetrizer / Desymmetrizer
The Audiophonics HC Trigger Switch MKII is a pilot-controlled source selector whose main purpose is to enable you to use your Hi-Fi system as the front channels of your home cinema system without touching the cables. In fact, you can connect your two systems upstream of this device, connect one or two power amplifiers or a pair of active loudspeakers to the output, and switch automatically from one source to the other.
Reference : 19956
89,00 €tax incl.
74,17 € tax excl.
Audiophonics HC Trigger Switch MKII Home Cinema Power Trigger Symmetrizer / Desymmetrizer
AUDIOPHONICS HC TRIGGER SWITCH MKII : 3/4 view
It can also be used as a balancer and desymmetrizer, thanks to its simultaneously active XLR and RCA outputs.
AUDIOPHONICS HC TRIGGER SWITCH MKII: Example of use
Audiophonics HC Trigger Switch MKII: Hi-Fi input
The part of the HC Trigger Switch MKII dedicated to receiving the signal from a HiFi source has a stereo XLR input, which is the active one by default.
For the Hi-Fi section, output triggers can be activated in two ways: Auto or Trigger.
  • In Trigger mode, reception of a 12V trigger signal from your Hi-Fi preamplifier is transferred to the output triggers.
  • In Auto mode, the detection of an audio signal above -60dB triggers the output triggers.
Note that to prevent triggers from being deactivated in the event of silence between two tracks, a time of 2 minutes 30 has been set before deactivation after the last signal detected.
Furthermore, auto mode is only available via XLR.
AUDIOPHONICS HC TRIGGER SWITCH MKII : HiFi input
AUDIOPHONICS HC TRIGGER SWITCH MKII : home cinema input
Audiophonics HC Trigger Switch MKII: Home Cinema input
The home cinema section has a stereo RCA input. The product will switch to this input as long as it receives a 12V trigger signal.
The HC Trigger Switch MKII features a front-panel gain control for the RCA input, enabling you to double the signal level offered by some home theater amplifiers on their pre-output from 1V to 2V.
Audiophonics HC Trigger Switch MKII: Dual trigger output
The HC Trigger Switch MKII has two output triggers, so it can be used in a dual-mono configuration.
Outputs include simultaneously active RCA and XLR outputs:
  • The “home cinema” signal, natively in RCA, is buffered and symmetrized by a pair of OPA1642 circuits to be available on the XLR output.
  • The “Hi-Fi” signal, natively in XLR, is buffered and desymmetrized by a DIP8-mounted LM4562 AOP before being made available on the RCA output.
The original home theater / Hi-Fi application can of course be used to mix two audio systems, as long as the RCA system has a trigger output to switch the input.
As the RCA and XLR outputs are active at the same time and perfectly independent, you can also envisage a configuration involving bi-amplification.
AUDIOPHONICS HC TRIGGER SWITCH MKII : dual trigger
Product typeHome theater trigger
Inputs1x Stereo XLR
1x Stereo RCA
Outputs1x Stereo XLR
1x Stereo RCA
Trigger voltageInput: 5-12V
Output: 12V
Auto Mode activation threshold-60dB
SNR-117dB
THD+N-106dB
Bande passante2Hz-56kHz (-3dB)
Niveau de sortieRCA : 5.8Vrms
XLR : 11.6Vrms
Input impedanceXLR to XLR: passthrough
XLR to RCA: 20Kohms
RCA to XLR: 10Kohms
RCA to RCA: 10Kohms
Output impedanceXLR to RCA: 600 ohms
RCA to XLR: 600 ohms
RCA to RCA: 600 ohms
Supply voltage12V DC
Dimensions (L x D x H)152 x 90 x 45mm
Weight310g
Package1x Audiophonics HC Trigger Switch MKII
1x 12V 1A Power adapter
2 reviews
Danach habe ich schon lange gesucht und hier endlich gefunden!
Ich habe schon länger nach so einem Umschalter gesucht der genau das kann.
Im Heimkinobetrieb nutze ich den RCA pre-out meines AV-Receivers und lasse die Frontkanäle über über meine (symmetrische) Musikanlage laufen. Hier ist auch der RCA Gain Schalter sehr nützlich weil der Signalpegel von meinem Denon AVR etwas niedrig ist.
Zum Musikhören wird beim Einschalten meines Streamers per Trigger auf den XLR Eingang geschaltet und Audiosignale vom DAC zugespielt.
Ich hatte das bisher mit einem Umschaltrelais gelöst aber das war mehr eine Bastellösung und hat machmal lautes Knacksen beim Umschalten und einen leichtes Brummen verursacht.
Die Umschaltung hiermit funktioniert ohne Knacksen und Brummen und ich konnte keine negative klangliche Beeinflussung feststellen.
This review has been posted for AUDIOPHONICS HC TRIGGER SWITCH MKII Home Cinema Power Trigger Symmetrizer / Desymmetrizer
Quick and Auto switch No noise from Symmetrizer
At first, I am only aiming to get the auto/trigger signal function, not expecting the Symmetrizer is an upgrade from no brand aliexpress Symmetrizer.
The device build is great, I did not try the audio sensing mode but only RCA trigger from AV amp.
The switch is so instant without any pops or noise when switching.
I have not encounter any distortion or strange noise from the Symmetrizer function from this device( I notice some noise with aliexpress Symmetrizer). When comparing to what I used before ( actually 2 different Symmetrizers and both from aliexpress) the noise floor is so much more lower on audiophonics. Excellent job from audiophonics to release such perfect device.
If you are going to merge a Hifi system ( XLR output ). and another system with RCA Out to a XLR Poweramp with auto signal switching, this will be the device you are looking for!
The Audiophonics HC Trigger Switch MKII is a pilot-controlled source selector whose main purpose is to enable you to use your Hi-Fi system as the...
