DD HIFI DJ44GOLD Adapter 4.4mm Balanced Female Jack to 3.5mm Single-Ended Male Jack
The DD HiFi DJ44Gold is an adapter designed to connect headphones or in-ear monitors equipped with a balanced 4.4mm (Pentaconn) plug to an unbalanced 3.5mm headphone output.
Reference : 22160
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 25-11-2026.
ddHiFi DJ44Gold Shielded 4.4mm Balanced Female Jack to 3.5mm Single-Ended Male Jack Adapter Gold-Plated
DD HIFI DJ44Gold
The ddHiFi DJ44Gold is an adapter designed to connect headphones or in-ear monitors equipped with a balanced 4.4mm jack (Pentaconn) plug to a single-ended 3.5mm jack headphone output. This Black Gold edition features a more compact design than the DJ44Pro model, with a redesigned 3.5mm connector to reduce its overall size. It incorporates a low-contact-resistance 4.4mm Pentaconn socket, a pure copper 3.5mm jack connector with thick 24K gold plating, and a solid pure copper housing plated with 24K gold that also serves as a grounding shield to minimize electromagnetic interference. Its internal Nyx Series high-purity OCC copper wiring, soldered using a silver-containing alloy, ensures excellent conductivity and high-quality signal transmission. Compact (24.1 x 17.6 x 12.1mm, excluding the plug) and lightweight (approximately 9g), it is a robust, high-end solution for using a 4.4mm cable with a single-ended 3.5mm output.
Technical Specifications
Product typeJack Adapter
Connectors1x 4.4mm balanced female jack
1x 3.5mm single-ended male jack
Contact materialCopper
Contact plating24K gold
Internal wiringNyx Series: High-purity OCC copper with silver-alloy solder
Shielding housing24K Gold plated pure copper
Dimensions24.1 x 17.6 x 12.1mm
Weight9g
Package contents1x ddHiFi DJ44Gold
ConnecticMale & Female
ConnectorJack 3.5mm
ConnectorJack 4.4mm
DDHIFI DJ44GOLD Shielded Adapter 4.4mm Balanced Female Jack to 3.5mm Single-Ended Male Jack Gold Plated
The DD HiFi DJ44Gold is an adapter designed to connect headphones or in-ear monitors equipped with a balanced 4.4mm (Pentaconn) plug to an...
