TONEWINNER ETM-3 Measurement Microphone
The Tonewinner ETM-3 measurement microphone is designed to enable you, in conjunction with certain home cinema devices from the brand, to perform automatic acoustic correction of your system. It connects directly to the home cinema processor and, based on the performance of your speakers, applies optimal equalisation for perfect immersion and sound consistency.
Reference : 21294
39,00 €tax incl.
32,50 € tax excl.
Shipping date: 24-11-2026.
Tonewinenr ETM-3 Measurement Microphone for Home Theater Calibration
TONEWINNER ETM-3 : Front view
Using the Tonewinner ETM-3
  • 1. Connect the microphone to your home cinema amplifier.
  • 2. Position the microphone at the desired listening position.
  • 3. Keep the room quiet and avoid any movement during the measurement process. This may take between 1 and 3 minutes depending on the number of speakers.
  • 4. From your device's interface, navigate to the following menu: Menu → Acoustic Test → Auto Room Test.
  • 5. When the measurement process is complete, press the ‘Apply’ button to save the configuration.
Technical specifications
Product typeMeasuring microphone
CompatibilityHD-5000
HD-3900
HD-3700
HD-3000A
HD-3080+
HD-3100PRO
AT-300
AT-200
DirectivityOmnidirectional
Cable connectorJack 3.5mm
Cable length5m
Dimensions60 x 53mm
PackageSold by unit
TONEWINNER ETM-3 Measurement Microphone for Home Theater Calibration
The Tonewinner ETM-3 measurement microphone is designed to enable you, in conjunction with certain home cinema devices from the brand, to perform...
