DAYTON AUDIO DMA105-8 Full Range Speaker Driver
The Dayton Audio DMA105-8 is a 4" (Ø10.16 cm) full-range speaker driver designed to deliver extended and accurate sound reproduction in a compact format.
Reference : 22316
26,40 €tax incl.
22,00 € tax excl.
Shipping date: 23-10-2026.
DAYTON AUDIO DMA105-8 Full-Range Speaker Driver 35W 8 Ohm 85dB 70Hz-20kHz Ø10.2cm
The Dayton Audio DMA105-8 is a 4" (Ø10.16 cm) full-range speaker driver designed to deliver extended and accurate sound reproduction in a compact format. Compatible with an 8Ω load, it handles 35W RMS continuous power (70W max) and offers a sensitivity of 84.8dB (2.83V/1m) with a frequency response ranging from 70Hz to 20kHz. It features an aluminum cone combined with a rubber surround, a vented 25.4 mm voice coil mounted on an aluminum former, and a dual neodymium magnet motor structure creating a symmetrical magnetic field for excellent cone control. A large copper cap helps reduce distortion while improving high-frequency performance. Its exclusive 12-spoke open-frame chassis promotes heat dissipation and minimizes rear-wave reflections, while its generous 2.5 mm linear excursion ensures dynamic and detailed sound reproduction. Thanks to its 72Hz resonant frequency, low distortion, and design optimized for full-range applications, the DMA105-8 is an ideal solution for Bluetooth speakers, desktop speakers, soundbars, line arrays, and high-fidelity DIY projects requiring a compact and high-performance speaker driver.
Technical Specifications
Product TypeFull-Range Speaker Driver
Nominal DiameterØ10.16cm (4")
Power HandlingRMS: 35W
Max: 70W
Impedance8Ω
Frequency Response70Hz - 20000Hz
Sensitivity84.8dB 2.83V/1m
Voice Coil DiameterØ25.4mm (1")
Thiele-Small Parameters
Resonant Frequency (Fs)72Hz
DC Resistance (Re)7.5Ω
Voice Coil Inductance (Le)0.6mH
Mechanical Q (Qms)2.64
Electromagnetic Q (Qes)0.83
Total Q (Qts)0.63
Compliance Equivalent Volume (Vas)0.15ft³
Mechanical Compliance of Suspension (Cms)1mm/N
BL Product (BL)4.47T·m
Diaphragm Mass Inc. Airload (Mms)4.9g
Maximum Linear Excursion (Xmax)2.5mm
Cone Surface Area (Sd)54.1cm²
Materials
Cone MaterialAluminum
Surround MaterialRubber
Voice Coil Wire MaterialCopper
Voice Coil Former MaterialAluminum
Basket MaterialPolymer
Magnet MaterialNeodymium
Mounting Information
Overall Dimensions104.14mm x 104.14mm (4.1" x 4.1")
Baffle Cutout DiameterØ98.43mm (3.875")
Depth47.24mm (1.86")
Number of Mounting Holes4
Bolt Circle DiameterØ127mm (5")
Recommended Enclosure Volume
Sealed Enclosure5.66L (0.2ft³)
Sealed F391Hz
Bass Reflex Enclosure7.08L (0.25ft³)
Bass Reflex F353Hz
Speaker Power (W RMS)35.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)101.6
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)85.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)70
Highest frequency (Hz)20000
DAYTON AUDIO DMA105-8 Full Range Speaker Driver 35W 8 Ohm 85dB 70Hz-20kHz Ø10.2cm
The Dayton Audio DMA105-8 is a 4" (Ø10.16 cm) full-range speaker driver designed to deliver extended and accurate sound...
