DAYTON AUDIO DMA105-4 Full-Range Speaker Driver
The Dayton Audio DMA105-4 is a 4" (Ø10.16 cm) full-range speaker designed to deliver extended and natural sound reproduction in a compact form factor.
Reference : 22314
26,90 €tax incl.
22,42 € tax excl.
DAYTON AUDIO DMA105-4 Full-Range Speaker 35W 4 Ohm 90dB 70Hz-20kHz Ø10.2cm
The Dayton Audio DMA105-4 is a 4" (Ø10.16 cm) full-range speaker designed to deliver extended and natural sound reproduction in a compact form factor. Compatible with a 4Ω load, it supports 35W RMS (70W max) continuous power handling and offers a sensitivity of 89.8dB (2.83V/1m) with a frequency response ranging from 70Hz to 20kHz. It combines a rigid aluminum cone with a rubber surround, a ventilated 25mm voice coil mounted on an aluminum former, and a dual neodymium magnet structure generating a symmetrical magnetic field for excellent cone control. A large copper cap helps reduce distortion while improving high-frequency response. Its exclusive 12-spoke frame promotes ventilation and minimizes rear reflections, while its design facilitates integration into numerous DIY projects. Thanks to its low distortion, 2.5mm linear excursion, 72.7Hz resonant frequency, and extended response, the DMA105-4 is an excellent choice for Bluetooth speakers, soundbars, compact desktop speakers, line arrays, and high-performance full-range systems.
Technical Specifications
Product typeFull-Range Speaker
Nominal diameterØ10.16cm (4")
PowerRMS: 35W
Max: 70W
Impedance4Ω
Frequency response70Hz - 20000Hz
Sensitivity89.8dB 2.83V/1m
Voice coil diameterØ25.4mm (1")
Thiele-Small Parameters
Resonant frequency (Fs)72.67Hz
DC resistance (Re)3.4Ω
Voice coil inductance (Le)0.3mH
Mechanical quality factor (Qms)2.6
Electromagnetic quality factor (Qes)0.63
Total quality factor (Qts)0.51
Equivalent air volume of the moving mass compliance (Vas)0.15ft³
Mechanical compliance of the suspension (Cms)1.06mm/N
Force factor (BL)3.35T·m
Moving mass + air load on the diaphragm (Mms)4.53g
Maximum linear excursion (Xmax)2.5mm
Diaphragm surface area (Sd)54.1cm²
Materials
Cone materialAluminum
Surround materialRubber
Voice coil wire materialCopper
Voice coil former materialAluminum
Basket materialPolymer
Magnet materialNeodymium
Mounting Information
Overall dimensions104.14mm x 104.14mm (4.1" x 4.1")
Cutout diameterØ98.43mm (3.875")
Depth47.24mm (1.86")
Number of mounting holes4
Mounting circle diameterØ127mm (5")
Recommended Enclosure Volume
Sealed enclosure2.83L (0.1ft³)
F3 Sealed enclosure113Hz
Bass reflex enclosure5.66L (0.2ft³)
F3 Bass reflex enclosure62Hz
Speaker Power (W RMS)35.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)101.6
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)2.5
Lowest frequency (Hz)70
Highest frequency (Hz)20000
DAYTON AUDIO DMA105-4 Full Range Speaker 35W 4 Ohm 90dB 70Hz-20kHz Ø10.2cm
The Dayton Audio DMA105-4 is a 4" (Ø10.16 cm) full-range speaker designed to deliver extended and natural sound reproduction in a...
