Marc C.
Que dire ?
Bertrand j.
neutrik
Ramiro F.
Patrick K.
Sonic Master
This cable is sooooo good that i was shocked. I did not expect this level of warm neutral detailed rich, open and airy sound from anything less then the best UP-OCC. I used to believe that OFC copper that is not cast in the Ohno Continuous casting proces and was very good quality oxygen free copper perhaps but not cast in that "special" mono crystal way, would always be less in performance then one hat was true OFC copper OCC casted. But this cable changed my opninion and my recommendations to all friends and clients, Forget about OCC and only watch for those magic three letters.... I have put WBT pure copper spades on one side and viablue banana plugs on the speaker side, The cable that it replaced was one that was 40x more expenisve 10AWG massive Lab grade OCC copper. And this 5080 humiliates that well known brand and not just by a hair, but a mile,,,,,, This Cable Is Too Good for the proce friens, Make sure you strip and mount it like it has to be done. Use the flat conductor to maximize contact surface between the conductors and connectors.... GianT killer this one
Pierre-Marin L.
1877PHONO NOVA-SPK Bananas Speaker Cables Silver Plated PC-OCC Copper 3.31mm² 5m (Pair) These 1877Phono Zavfino Nova-SPK  banana speaker cables  are positioned on a top-of-the-range cable segment, designed to offer exceptional performance thanks to...
Je confirme tous les commentaires élogieux sur ce câble...
Patricio C.
AUDIOPHONICS HPA-DM750ET Power Amplifier Dual Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and two independent Hypex...
Dale una oportunidad de escucha en tu sistema... y juzgalo tu mismo.
Más vale tener potencia bajo el pedal y no necesitarla que al revés.... y vaya si se nota ir sobrado de potencia. Antes usaba un Rotel RB-1552MkII en clase AB.. y muy bien ... hasta que pones el Purifi 9040 + Preamplificador Gustard P26 (Testado también con preamplificador Audio Research SP17 y Vincent SV-94)... no sabe uno de como puede sonar tu sistema cuando la potencia sobra. Los típicos comentarios de que la clase D no suena natural..... y que me decían algunos antes de apostar por este amplificador se disiparon una vez lo conecté a mi sistema.... al segundo día de pruebas... ya le quité la pegatina de protección frontal del Purifi 9040, puesto que tenía muy claro que me lo quedaría.
Ahora está junto con el Audio Research SP17 sonando... muy bien la verdad, pero es que la sinergia con el preamplificador Gustard P26 de mucho menor coste es aún mejor!..por increíble que parezca y para mi gusto... hacen una sinergia excelente.
Nada como probarlo en tu casa, con tu sistema... y ver de lo que es capaz esta bestia, apostaría que sí das el paso.. te lo quedas.
Saludos
Raphael A.
1MII LAVAUDIO DS200 Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Silver The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs of high resolution...
Son trop cristallin et trop orienté sur les médiums
Je l'ai testé vs. mon AUDIOPHONICS LHDC Récepteur Bluetooth 5.0 LHDC SA9910 / DAC PCM5102A 24Bit / 96kHz (moins cher, acheté il y a 5 ans) et je n'ai pas aimé le son : trop plat et cristallin, ciblé sur les médiums, pas assez rond pour mon ensemble. Ou pour mon goût. Je l'ai rendu. SAV Audiophonics très réactif, nickel.
Raphael A.
Son imbattable, rond et précis. Attention switch BT complexe
Je l'ai depuis 4 ans maintenant pour l'interface entre mon PC et ma chaine hi-fi (NAD basse/moyenne gamme). Imbattable sur la qualité sonore, j'ai testé d'autres DAC de sa catégorie et je n'ai jamais obtenu un son aussi rond, complet, précis, agréable. Convient parfaitement pour une connexion BT unique et stable. Car pour switcher d'appareil, il faut hélas l'éteindre, le rallumer et établir une nouvelle connexion. Idem quand on veut remettre l'ancien. Dommage qu'il n'y ait pas au minimum un bouton de réinitialisation BT.
Raphael A.
Je l'ai acheté il y a 4 ans. Connecté entre un DAC BT sortie jack et ma chaine hi-fi (basse/moyenne gamme), la restitution sonore est très bonne et rien n'a bougé depuis 4 ans ! Esthétique, souplesse, qualité, tenue dans le temps à ce prix, rien à dire, je recommande fortement.
Eric L.
XCITE XT32-4 Speaker Driver Exciter 20W 4 Ohms 35Hz - 17kHz The XCITE XT32-4 exciter features a unique combination of large travel and low inductance, guaranteeing vibrations with the lowest distortion across the entire frequency range....
Produit excellent bande passante après correction presque complète. Netteté, solidité et il tient le coup avec un amplificateur de 40Wrms .Xcite a toute une gamme de vibreurs très intéressante. Je recommande vivement ce produit.
Marc F.
Très pratique mais finition perfectible...
Placé en amont d'un ampli SMSL A-300 il remplit très bien sa fonction native et permet en sus d'alimenter soit cet ampli intégré soit un ampli casque Sennheiser.
Quelques regrets côté finition : à réception du produit les embases RCA n'étaient pas suffisamment serrées.
EIZZ EZ-507-4 Lockable Banana Plugs Pure Copper Gold Plated 5µ (Pair) These EIZZ EZ-507-4 banana plugs benefit from a high-end design thanks to their 99.99% pure copper contact and 5µ thick non-magnetic gold plating. These features give them...
Top qualité
Je cherchais des bananes en cuivre pur avec une excellente conductivité et blocage
J'ai trouvé !
Fabrice C.
SILKLINE ZUKI I Balanced preamplifier / DAC 32bit / 192kHz USB XMOS Silkline's Zuki I combines the functions of preamplifier and DAC . The preamplifier function has a balanced and unbalanced output and a v oltage gain of 12dB ....
SILKLINE ZUKI I
Voici un DAC avec contrôle de volume et quatre entrées analogiques qui mérite vraiment d'être connu! Ne vous arrêtez pas à son aspect austère car à l'usage vous comprendrez vite que vous avez fait une excellente affaire.
Il est très simple à utiliser et se révèle parfaitement transparent à l'écoute. Il suffit de regarder à l’intérieur pour comprendre. La qualité et le sérieux de la fabrication ne fait aucuns doutes. Point d'alimentation à découpage ici mais un énorme transformateur torique, l'alimentation ne risque pas de s’effondrer! Pas non plus de puces de conversion ESS dernier cri, plus réputées pour leurs performances que pour leur musicalité, non, juste de bons vieux Analogue Device, excellents, peu couteux et qui font le job jusqu'à 24 - 192Khz. Je ne vois pas pourquoi aller plus haut en HiFi audio...
Pareil pour la puce Xmos; elle fonctionne en USB sans driver jusqu'à 48 Khz sous Windows. Pour aller au delà, il faut installer le driver (on le trouve facilement avec le lien sur la fiche produit Audiophonics). L’installation est très facile, elle s'adapte automatiquement à votre version de Windows et fonctionne aussi sur Windows 11.
Toutes les entrées sont commutées par des relais électroniques, vous n'entendrez aucuns bruits de commutation. Le contrôle de volume est précis et de bonne qualité, l'affichage est un peu troublant, le chiffre affiché diminue au fur et à mesure que le volume augmente mais on s'y habitue très vite.
Petit bémol, contrairement aux sorties CINCH, le niveau de sortie en XLR est trop faible, cela oblige à pousser le volume proche du maximum quand on utilise ces sorties, cependant, la qualité du son ne semble pas altérée.
Vous l'aurez compris, je recommande ce produit à tous ceux qui ont besoin d'un bon DAC avec contrôle de volume et quelques entrées analogiques. Le rapport qualité prix me semble exceptionnel.
FRANK D.
Impressionnant.
Une fois compris le systeme et en ayant pris des precautions pourque les parties en plastique ne se desolaridesent pas cette fiche en vaut largement le coup a l'ecoute.
Son net et beaucoup plus transparant que toutes les autres connecteurs utilises auparavant. Meme de tout haut de gamme.
Le montage peut certe, etre simplifie, du moins il me semble...
Bruno R.
J’ai donc commandé le dimanche et reçu le mardi une Gold Lion de Genalex en 12AX7 / ECC83. Bravo à Audiophonics pour le service impeccable !
Je l’ai installée pour remplacer une lampe de la marque TAD du même type sur un ampli hifi hybride TAGA Harmony HTA-1000B équipé d’origine avec des 2 tubes Psvane en 12AU7 en plus de la 12AX7. Dans la configuration actuelle de l’ampli, des Tung-sol remplacent déjà les Psvane.
Pour faire court : je suis scotché par le bond qualitatif avec cette lampe Genalex, ressenti dès les premières minutes d’écoute ! C’est le jour et la nuit comparé à la TAD !!
Les graves sont justes… parfaits. Bien définis sans être envahissants. Sur les percussions de batterie, on ressent la vibration des peaux sur les fûts, la petite résonnance qu’on entendrait si la batterie était réellement devant nous. C’est bluffant.
Très beaux mediums aussi pour les guitares électriques par exemple.
C’est globalement plus aéré et l'écoute est agréable car pas fatigante.
Il n’y a que sur les voix que, si la bande passante est chargée (par exemple sur un morceau de metal) qu’elles ont tendance à rester un poil en retrait.
Mais cela tient peut-être aux autres lampes ou aux enceintes tout simplement.
Bref, je recommande cette lampe sans aucune hésitation !
Alain p.
top du top
OGUZHAN O.
SBOOSTER BOTW P&P MKII Regulated Linear Power Supply 5V 3A / 6V 1.75A / 6.5V 1.6A With the SBooster BOTW P&P ECO MKII regulated linear power supply, purification of the electrical signal begins immediately where the polluted current enters the power supply....
With Bluesound Node N130
I use it with Bluesound Node N130 and it gave lots of sound improvements
OGUZHAN O.
Good Quality Materials but hard to make cable
1) 10 mm Neotech 3220, There is a reducer in it, without it cable a bit loose. Anyways lots of pvc shaving i manage to fit with reducer.
2) Tip of the connector, split 2 parts, you have to keep it together while soldering. After i finish 1 pair i try rca sockets, one of them bended like eliptical, because of this doesnt fit. I tear it again, use a little force and voila! Then I said to myself wish i chose to make easier version of rca like whole metal body.
OGUZHAN O.
Very Good Quality for price
Nice grip, good contact. I use it with Mogami W2497 cables no issues.
Mika N.
TOPPING PROFESSIONAL E2X2 OTG USB Audio Interface 2 Inputs 2 Outputs 24bit 192kHz Black Topping's E2x2 OTG is an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very high level of...
Very good sound card with professional sound. Works very well in Windows 11.
All the best!!!
Gaine PTFE parfaite
Mais là je dois avouer que je suis bluffé par l'option gaine ptfe proposée par Audiophonics en option avec le fil nu argent pur élecaudio qui est tout simplement adapté a l'usage pour lequel il est conseillé et personnellement je n'ai eu aucun problème pour enfiler les 150 cm de pur argent dans la gaine même si il faut un peu de patience et de dextérité.
Merci encore Audiophonics pour cet excellent conseil.
Cela reste quand même très cher pour une gaine mais le résultat est qualitatif.
Eric S.
FX-AUDIO TUBE-02 PRO 5725 Tube Preamplifier / Headphone Amplifier Class A With the Tube-02 Pro, Fx-Audio offers a small tube preamplifier and headphone amplifier in a compact and affordable format. Its preamplifier stage uses a pair of 5725 tubes,...
Belle surprise !
Branché sur un ordinateur. Quelle amélioration, notamment sur le rendu des instruments acoustiques ! J’ai changé les tubes d’origine qui bridaient un peu les performances de ce ampli casque que je recommande…chaleureusement.
Lars Nuqa Clement B.
ET3 and Oversampling advantage ?
Has anyone taken an audio CD (16 bit /44,1 KHz) and experimented with raising the oversampling Frequency at playback over I2S outlet ? Theoretically, oversampling works as a filter and it could impact on experienced sound audio quality even if bitrate are the same. Share your experience with us here, please !
Laurent G.
Expédition rapide, produit d'origine pour ma station ZD937
Il est dommage que l'élément céramique soit introuvable et impose de changer le fer complet, car même si le fer de rechange n'est pas très cher, c'est quand même encore une forme de gâchis.
Merci.
Gorazd K.
OYAIDE TUNAMI TERZO RR RCA Interconnect Cable 0.7m (Pair) This high quality modulation cable is assembled with the most famous Focus 1 connectors and a 102SSC cable, a top of the line model from Oyaide. This cable is presented to us...
Top quality product. The cable is a bit stiffer, which is expected given the manufacturing method and the materials used. The connectors are really excellent quality. You can tighten them and they hold firmly, without moving. In my opinion they are sonically balanced, but here there are differences depending on personal preferences and the type of system.
Tom K.
cd transport with usb audio out!
There really arent that many cd players with usb audio output on the market. This one is affordable and surprisingly well built (and heavy for its size).
I have invested in an usb audio based system to get the best sound possible and this device enables me to play my old cd's with the same fidelity.
I havent tried the ripper functionality yet, but it's cool that is has this function.
Delivery and packaging was top notch as always with audiophonics.
Marco R.
7 stelle di Qualità
Arrivato da pochi giorni questo amplificatore e nonostante è ancora in rodaggio, non smette di piacermi. Palcoscenico largo e tridimensionale, ottima separazione degli strumenti, e non stancante, ottima musicalità. Collegato a delle PMC TWENTY5 22 che già suonavano bene ora ancora di più. Non posso far altro che consigliarlo, anche per l'ottimo rapporto qualità prezzo, e all'ottimo servizio di consulenza di Audiophonics.
Freddy A.
un plus
Et bin non , c'est comme un relooking , dans mon cas plus de tension dans la musique , un grave mieux maitrisé, des détails révélés, ouais ils étaient là mais coulés dans le bruit.
La scène sonore est dans mon cas identique , ou s'il y a un truc je ne l'entends pas .
Bref au vu de l'investissement , je précise que je ne suis pas fan de I2S que tout le monde encense, mais que je trouve trop technique pour mes vieilles oreilles...Donc en coax, comme en aes, ça fait le taf .
Dominique R.
NICHICON KW Electrolytic Audio Capacitor 50V 4700μF The KW series is a range of electrolytic capacitors specially designed for audio use. They offer excellent performance and technical characteristics.
Top !
J'ai remplacé les 2 condensateurs sur mon petit Taga Harmony HTA 700B après le claquage de l'une deux et ça remarche fort bien ! Je suis satisfait, merci pour votre envoie rapide !
Fabien F.
conforme à la documentation, avec un bon son même à faible volume. Je l’ai testé avec des large bandes Supravox 135lb (rendement 95db) et malheureusement le souffle est encore légèrement audible à 2m quand il n’y a pas de son. par contre pas de pb avec des enceintes à rendement standard, ou pour alimenter des sub, ce qui est le but d’utilisation finale de mon projet. il faut absolument ajouter un radiateur de 2,4dc/W sur le mini radiateur de base, qui chaude assez fort même sans audio en entrée (conso des mosfet de 5W au repos). notez qu’il consomme beaucoup moins et ne souffle plus en mode standby.
Eric A.
Sigismond Z.
Envoie
Super ,comme toujours rapidité,et bon enballage,Merci a l'équipe
Pierre M.
GLA-RCA Volume Control Module 20KOhm with Encoder / Display / Remote control This volume control module includes an encoder, a display and an IR remote control. This GLA-RCA module features a low-distortion chip...
Fonctionne
bonjour ; fonctionnement correcte , mais tassement de dynamique et quelque peu bruyant ...!
Thierry d.
éclairage vintage
Parfait pour mon ampli Scott A 436 : les Vu-mètres sont à nouveau splendides .
FIIO SR11 Streamer WiFi Airplay Roon Ready 32bit 768kHz DSD256 Silver FiiO's SR11 network player is a compact, high-performance streamer designed to work in conjunction with the K11 DAC/headphone amplifier. Based on an X2000 processor, it is...
Remarquable avec Roon
Je l'utilise comme Endpoint sur un DAC Audio GD avec Roon sur un NUC avec RoonRock comme serveur. L'écoute est absolument remarquable. Hyper stable, aucune crasse dans l'envoi des données au DAC et pas de coupure avec Qobuz. Paradoxalement, je trouve que j'y ai gagné par rapport à un Roopie en Endpoint.
Peter Š.
more than good
Phantastic clearly sound DoP 64 over optical output PO100 to RAWMDA1 DAC much better than simply USB conversion. WIthout noise and without any ground loops. Thanks AUdiophonics and S.M.S.L.
Excellents
Qualité irréprochable, à un prix raisonnable. Rendu sonore équilibré et ouvert avec le neotech NEI-3004G...dépasse toutes mes espérances, c'est le meilleur câble que j'ai eu chez moi et pas le plus cher. J'avais un doute sur l'absence de soudure mais c'est hyper naturel. Franchement, si vous voulez confectionner un câble qualitatif sans vous ruiner...
André G.
Câble secteur au top
Ayant testé de ombreux câbles secteur de moyen et haut de gamme, le câble Audiophonics répond à mes attentes après avoir écouté toutes sortes de musique. Il transmet les harmoniques avec un minimum de pertes ou de colorations. A recommander. Merci Audiophonics pour cet excellent travail.
Marco R.
È da qualche giorno che ho questo finale di potenza, ma devo dire che,quanto già scritto da altre persone sulla qualità dell'oggetto, sia a livello di costruzione, che di suono. Il palcoscenico è più grande, gli strumenti sono più divisi e intellegibili tra di loro. Che dire se non un ottimo finale di potenza. E devo anche complimentarmi con la professionalità per i consigli e l'aiuto nel post vendita, in particolare per un errore di consegna poi subito risolto.
Grazie a tutto lo Staff di Audiophonics.
David S.
impeccable
Exactement la bonne dimension, identique à ceux endommagés sur mon ampli qui vous dit merci.
efficace
Le son est plus net et apporte de la matière . Les détails sont mieux détourés . RQP réaliste . bien .
Hector T.
MOONDROP ECHO-B Adapter DAC Headphone Amplifier USB-C to Balanced Jack 4.4mm 32bit 384kHz The Moondrop Echo-B is a compact, high-performance USB-C to 4.4mm balanced jack adapter, designed to deliver a high-resolution audio experience with ease. It incorporates a...
Grésille
Hector T.
Combiné avec mes Truthear Nova, j´ai enfin la puissance nécessaire pour écouter mes musiques pleinement.
Les bass sont puissantes, le fond noir et intéressant, et le rapport qualité-prix est parfait.
Hector T.
HIDIZS LT03 Male Lightning to Female USB-C Adapter Gold Plated The Hidizs LT03 is a Lightning male to USB-C female adapter, notably compatible with iOS and Android devices, and ensuring a very good transmission quality. Its contacts are...
Bien mais gros
Le connecteur fonctionne correctement, mais ma coque (Apple) bloque un peu la connexion et je dois forcer pour le brancher correctement.
J´ai eu quelques grésillements; à voir si c´est l´adaptateur qui en est la source.
Heinz-Juergen F.
Perfect working with RPI 4 & Hypex Plateamp
SeeTitle
Roland S.
Dac tv
Je viens de recevoir ce tout petit dac et immédiatement branché entre le décodeur TV et un atoll in 50 se. Je le teste en ce moment sur une version moderne des trois mousquetaires et ma foi il semble bien faire son boulot. En tout cas c'est un + comparé au son de la TV et pour un prix ridiculement bas.
Sinon toujours satisfait d'audiophonics ,un excellent site.
Walter V.
TINYSINE TOSLINKBEE Interface Module SPDIF Optical to I2S DIR9001 CS8421 24bit 96kHz This Tinysine ToslinkBee interface module converts an SPDIF signal via an optical Toslink input into an I2S signal. A DIR9001PW Burr-Brown chip converts the SPDIF signal to I2S,...
Great product!
Male Jack DC 5.5/2.1mm Connector Gold Plated Ø6mm This DC 5.5/2.1mm male jack connector will allow you to design your own power supply cables. It offers a nice design quality, with a metal body and gold-plated contacts ensuring...
Joli mais non..
Le pôle positif accepte 1mm2 malgres l' insertion en tube. La pâte de la masse est trop fragile . Joli, transmet le signal mais fragile et cher pour ce que c' est. Je préfère elecaudio en alliage ou en cuivre tellurium.
NAEL C.
Marvelous !
the difference is night and day ! i was using a dac that had no galvanically isolated USB input, adding the HS02 in the chain made an impressive change, i know electrical interferences can cause clocks to missbehave and add what is commonly referred to as "digital glare" but i was not axpecting such a change. anyway the device works and does wonders if you have a dac that is not properly isolated. Even my girlfriend was shocked at how much difference it made !
Jean-Marc S.
AUDIOPHONICS DIGIPI+I2S Digital Interface WM8804G for Raspberry Pi SPDIF I2S TCXO This Audiophonics DigiPi+I2S interface expands the output connectivity of a Raspberry Pi, giving it an additional panel of digital audio outputs. It includes a Toslink optical...
rpi5
fonctionne très bien avec avec rpi5 et picoplayer (en tant que player uniquement) ! Merci des conseils Audiophonics
jean-michel g.
Câble opéra Triangle
Après un d’utilisation, je valide que c’est un super câble avec beaucoup de finesse et de fluidité. Très agréable à l’écoute.
De plus, couleur de la gaine très discrète.
