Une révélation
Gionatan R.
Bello ma fragile
Mi piace molto questo eccitatore. Per le dimensioni che ha il suono è buono, però i due punti di connessione sono molto fragili...
François G.
Customers reviews - There are 19456 reviews.
Gaine thermo bleue
Très bien pour le repérage des câbles
Gaine thermo rouge
Très bien pour le repérage des câbles.
Permet de 'changer de couleur' le câble ;
"NEOTECH SOCP-20 Fil de Câblage Cuivre UP-OCC PVC 20AWG Ø2.6mm" qui est bleu
Michel A.
Embase de bonne qualité. J'en ai déjà acheté plusieurs. Je recommande
Baraffe A.
100 % satisfait
Joli câble de couleur argentée, très souple, ce qui facilite son installation.
Etant donné le haut niveau de qualité technique de ce câble, toutes les informations passent sans aucune dégradation, ce qui est l’intérêt principal de la Haute-Fidélité.
Après de longues recherches sur le net, je n’ai pas trouvé mieux en termes de rapport qualité (fils de cuivre plaqués argent) / prix.
Quant à la livraison, j’ai reçu le produit 2 jours après ma commande.
Bref, je ne regrette pas d’avoir commandé ce produit chez Audiophonics.
Benjamin L.
Not as described
The unit I received (serial number 117XX) does not have the XMOS USB controller described in the documentation lised on this page, but instead seems to have an older version with a maximum sampling rate of 384kHz wich is not compatible with the SMSL driver posted on their page.
If you made the mistake of installing the driver provided by SMSL and your unit quit working, you can uninstall that in the Windows Device Manager.
That doesn´t matter for performance since I did indeed receive the MKII version with AK4493 DAC chip and the USB controller is fully compatible with the universal Windows USB drivers, but it has me wondering.
It works and sounds great.
Just be aware that you might not get what you are expecting.
Hi,
Very sorry about this mistake.
We are gonna correct that asap.
Best regards
Etienne P.
TINYSINE TSA6015 Bluetooth 4.0 Receiver Board CSR8635 wih Microphone Input This Bluetooth receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus possible to use this module to...
Très bon produit, fonctionne parfaitement.
M'a permis de connecter une casque audio et microphone via bluetooth à mon téléphone. Le système dispose d'un bouton permettant de faire play/pause pour la musique diffusée en bluetooth ou permet de décrocher quand on reçoit un appel (la sonnerie s'entend par la sortie audio).
James F.
Works well, prompt delivery, so-so documentation
There are not so many options for AES3 from a Pi HAT, and no others at this price.
Despite the item showing as out of stock and estimated delivery of 5 weeks, it arrived 10 days from ordering.
The only negative relates is the documentation (reason for dropping one star). The documentation is what is on the product web page, and on the silk screen of the PCB (for jumper positions). What is missing? I'd like to have known output voltage level for AES3 to understand viable cable lengths without risk of decoding errors, and a dimensioned drawing of the connector positions and sizes as there is no off the shelf enclosure solution for this HAT (needs to be at least 50mm deep).
Regarding performance & functionality, after setting the power supply jumpers and configuring Moode Audio, it worked first time.
In summary, great to have something quite specialist like this at this price point.
Paul D.
Conforme à mes espérances !
Rapport qualité-prix excellent, produit bien fini et livré avec toute la connectique nécessaire.
Puissant, ne chauffe pas, bref, fait le job.
Seul (minuscule) bémol : aurait été absolument parfait si les prises d'entrées (jack et micro usb) avaient été placées à l'arrière.
Câble cuivre OFC plaqué Argent
Très bonne qualité avec isolant PTFE
Existe en rouge et noir
Très bien en câblage interne
(Pour l'alimentation ou câblage borniers HP)
Câble Cuivre OFC plaqué Argent
Yacine B.
produit conforme, expédition rapide malgré la pandémie
Square of double sided adhesive tape 9448A 14x14x0.2mm (unit) This square of double sided adhesive tape allows to glue radiators and heatsinks for SBC Raspberry pi, Beagle bone, odroid as well as small DAC or ADC.
Parfait pour mettre un radiateur sur un raspberry
Male USB-C 3.0 DIY Connector OTG This connector to be mounted will allow you to create your own cables with USB-C connectors. This will allow you to take advantage of the reversible format of this connector,...
Conforme
Parfait pour alimenter un raspi4 proprement avec un câble et une bonne alimentation
DAYTON AUDIO UM15-22 Ultimax DVC Speaker Driver Subwoofer 800W 2x2 Ohm 87dB 15Hz - 1000Hz Ø38cm The Ultimax range of double coil subwoofers from Dayton Audio is the guarantee of powerful bass. Designed using the latest subwoofer technology, the Ultimax is the ultimate low...
The beast
Un monstre pas encore testé mais les perfs sont connues et appréciées de tous a mettre en volume clos et un bon caisson en devenir qui sera associé a petit atohm s500
LINDY CROMO LINE Male USB-A to Male Micro USB-B Cable 2.0 Gold Plated 1m The Cromo series is the most powerful USB cables manufactured by Lindy. This one relies on a well thought out design and oriented towards a technical reality, to meet a need for...
Joli cable
Joli câble et qualitatif pour relier un raspberry sous volumio avec un fda FX audio dx502
Bon montage sans condensateur sur le trajet et surtout utilisable en mono tension et montage propre les câbles de raccordement sont fournis donc gros plus
Jimmy G.
Trés bon produit
J'ai acheté cet ampli pour une enceinte bluetooth nomade "compacte". Alimenté par une batterie li-ion 22,2v 10Ah cet ampli a une tres bonne réponse sur toute la plage de fréquence et est trés dynamique. Sa consomation est trés correcte, il ne chauffe pas même en utilisation intensive. les potars de reglage aigu/grave sont precis et agissent là ou on en a besoin. Bref que du bon pour moi.
Livraison rapide en plus de ca.
Eric A.
Très bon rapport qualité/prix
Aucun soucis particulier au montage. Attention tout de même à avoir une pane assez large et un bon fer pour bien chauffer l'ensemble.
Aucune différence à l'écoute par rapport au câble nu, c'est bien ce qu'on demande à ce type de produit ! Et tellement plus pratique, fini les resserrage de borniers toutes les semaines ...
arnaud g.
AC / DC Switching Adapter 100-240V to 24V 6A DC This AC/DC switching adapter can receive an input voltage of 100-240V AC and then have an output voltage of 24V 6A DC. The power supply has a 5.5/2.5mm DC jack connector at the...
Correct
Produit conforme mais reconditionné je pense, car de marque Epson. Câble secteur défectueux (fait disjoncter mon tableau électrique même branché à vide - vu avec le sav)
Thibaut d.
Bonne qualité de fabrication, il est souple et les prises tiennent bien. Pas besoin de mettre plus chère.
Thibaut d.
Pour le prix, c'est un très bon ticket d'entrée pour la correction active. Filtre actif, réglage de niveau et de délai, inversion de phase et correction IIR (attention pas de FIR donc pas de correction de la phase).
Bref c'est du tout bon
Ballocca G.
Accurate and solid construction, pleasant appearance when mounted.
The real dimensions of the footprint are 5.08 and 10.16 mm (0.2 and 0.4 inches).
Ballocca G.
Not the best for its color
Accurate and solid construction, pleasant appearance when mounted, but the left channel should be identified with the white color.
Michalis B.
Great Diy module!
Lets see some things before my review!
If your job is electronics (repairing, service, and more) it is a great idea to buy this very nice module as diy unit, ofcourse because the cost is much lower than a complete unit!
You must be familiar with this type of electronics!
The second thing is that, this module is great and with a rich sound, really very close to CD quality.
One thing that i don't like to much (and believe me IT IS NOT UNIT PROBLEM) is that, the bluetooth source (your mobile phone for example) MUST be as close to the unit for better results!
In other words if this unit sold with an external antenna, i believe that be the very first choice...in low price!
Thanks Audiophonics for your great products!!
stephane j.
tres satisfait !! TRES BON S.A.V / Societe serieuse
Navettes d'un très beau bleu ;
Expédition rapide
S.A.V très sérieux ET a l’écoute de votre demande
MERCI , Audiophonics
borniers RQP
ces borniers sont excellents car même sils sont en laiton et non en CU/Tellurium, ils sont solide, le filetage fait 8 mm de diamètre je les ai monter sur du MDF de 22mm sans problème, j'ai simplement rajouter une rondelle plate large de 8,pour que l'écrou ne soit pas sur le bois,( et détail important non précisé dans la présentation,) sur la partie de serrage il y a une bague libre, pour pouvoir serrer sans couper le câble; ça fait la différence.
Eric w.
ELFIDELITY AXF-107 Power Filter PCI Express / PCI Express 16x The AXF-107 module from Elfidelity is a switch mode power supply filter for computers connected in PCI Express or PCI Express 16x and designed to provide cleaner power to all...
Eric W
Works fine, especially in lower frequencies. Great value for money. Lowers noisefloor (below -50db) neatly. Efficient reduction of 50Hz. hum. Just a clever product, Problemless, easy installation.
Roger P.
Alientek D8
I first tested by D8 with my Headphone: Windows PC -foobar2000 - XMOS USB - Hifiman HE1000. Worked like a charm. Sound quality is pretty impressing, highly resolving, not too harsh though, with almost black background and plenty of headroom even with recordings at lower volumes. Wow! Didn’t expect that at such a price. Any EQ settings do not affect the headphone output, but that's all right.
Next I connected a pair of Dali Rubicons. Not impressed this time, the sound was concealed by a very disturbing hiss, clearly audible at low volumes and still noticeable at middle ones. That’s bad! Renders the D8 completely useless for critical listening, at least with this kind of speakers. To my ears it’s far worse than I expected based on Audiophonics’ warning:
"This amplifier emits a slight breath into the speakers during silent passages in the music. Although the phenomenon is very slight, it is still important to take into account when using desktop speakers with close listening."
So I packed out my toroidal coil (100uH/3A) which I bought just in case, based on the advice of a tinkerer on diyAudio. I unscrewed the box, cut the conducting path at the marked spot, scratched open a solder pad on each side of the cut and soldered two wires onto them to connect the coil to. Closed the box and ahhh! The HISS IS GONE, completely gone! A big THANK YOU to the tinkerer!
Eventually, I could start enjoying the music and the quite powerful dynamics of this little baby. Wow! Now I am pleased. The sound is crisp and clear, much better than I could expect from such a miniscule device - both in terms of size and price. Makes me think why the manufacturer did not add a 50 cents inductor to the circuit in the first place. I am not being pedantic here but I have to deduct one star for this.
* https://www.diyaudio.com/forums/attachments/class-d/660221d1517587780-fda-alientek-d8-inductor_placement-jpg
Michel G.
C'est jolis mais bof
Sur le son ce n'est pas plus efficace qu'une grosse prise secteur d'un magasin de bricolage. Par contre ça fait pro.
POINT A AMELIORER : la prise est n'a pas la bonne dimension, elle entre mal et a du mal a tenir, celle que j'ai reçu. Il faut la mettre et plus y toucher.
Michel G.
Un plus indegnable
J'ai un Airtght atm1, une paire de Proac resp. 1.5 et un lecteur reseau Linn akurate ds. Voulant voir si un dac pouvait ameliorer mon Linn j'ai acheté d'occase un petit Dac Chinois (75€), le Mavrick d1. Qu'elle suprise de voir qu'il améliorait nettement mon Linn que j'ai payer 25 fois le prix (à neuf). J'ai vu que lon pouvait upgrader en changeant l'OPA (j'ai découvert ce que c'etait). J'ai acheté celui qui etait recommandé, l' OPA 627 à 6,90€. Et la la claque. Tout était plus 2lisible" et les voix sont plus naturel le. Du coups j'ai voulu allé plus loin. J'ai lu un commentaire sur Audiophinic indiquant que le sparko avait amélioré son le mavrick. Et pour mois c'est aussi le cas, notammanent dans les basses, tout est encore plus maitrisé. Mais le gap n'est pas aussi impressionnant qu'avec l'AOP 627. Je pense que mon dac qui est arrivé à ses limtites. Dans tous les cas il pourra me servir pour un Dac à venir.
Michel f.
Un super dac audiophile pour ce prix
J ai acheté ce dac il y a 2 semaines et que dire presque 4 kilos des composants de premier choix conception audiophile composants de très haute qualité.L écoute est très musicale aéré et avec une pèche d enfer.Mais attention les moindre petits détail son perceptible ce qui veut dire que les mauvais enregistrements sautent aux oreilles .Pour ma part j ai redécouvert mes enregistrements avec beaucoup de plaisir il faut dépenser au moins 2 a3 fois le prix pour avoir cette qualité chez la concurrence Un super achat.
Thibaut d.
DAYTON AUDIO DMA90-4 Speaker Driver Full Range Aluminium 30W 4 Ohm 89.3dB 85Hz - 20kHz Ø8.9cm The Dayton Audio DMA90-4 wideband Dayton Audio DMA90-4 aluminum cone provides excellent performance and low distortion. This speaker can be integrated into many audio projects,...
Installés dans des charges BR en tube PVC, franchement le rendu est vraiment convaincant dans une petite pièce.
patrice f.
précision sur le 3220
en complément de mon avis du 20-02-2020,je précise que je n'ai pas comparé ce câble au SC221 occ ni au 3004
Otto T.
The cherries on the cake!
After having had installed Audiophonics IAN CANADA FIFOPI ULTIMATE reclocker in my Audiophonics DAP/DAC Sabre ES9018 Mk2 100Mhz by sound engineer www.lentusaudio.nl, they advised me to order the 45Mhz and 49Mhz Ultra Low Jitter clocks to replace the standard ones.
The results are extremely good! More rifined highs and lows. Blacks are black (silence is silence).
Listening has become much more relaxed with every kind of music.
Capot aluminium brossé pour Slimline 280 mm .
Très bien pour remplacer la tôle 1mm du boîtier slimline, permet d'y fixer solidement transfos et supports de tubes
Boitier Slimline 2U 280mm
Avec le Capot aluminium brossé 280 millimètres en complément, donne une base solide pour ampli à tubes
Interrupteur 2 Pôles 2 Positions
Très bon switch, par contre il est plus gros que le modèle 1 Pôle 2 Positions.
A prendre en compte si l'on utilise les deux types pour un même projet
Interrupteur 1 Pôle 2 Positions
Je l'ai utilisé dans plusieurs projets ;
Retour d'expérience très positif, solide pas de jeu, contact franc, joli look rétro, aucun soucis avec ce matériel
Kévin C.
J'ai hésité un moment avant de trouver les bons connecteurs et franchement je ne suis pas déçu !
Le fait que l'on puisse visser au lieu de souder est vraiment pratique, seul hic il faut une clef Allen minuscule pour le serrage du câble sur le pico central, j'ai dû me la fabriquer en sacrifiant une clef Allen plus grosse.
Mais sinon qualité de finition au top et ce qui est bien c'est que l'on peut serrer sur la sortie source ou ampli la fiche donc une fois mise et serrer la connexion est parfaite et pas de risque d'arrachement.
Je recommande chaudement ce produit pour ceux voulant faire leur câble RCA eux-mêmes
Frederic J.
Simplest possible solution to separate power from signal, nicely made, works perfectly, delivered fast. I will shop here again. Thanks!
Christian F.
Top Seller
Very Fast Shipping and Top Quality Product
Thanks
Dominique M.
Superbe découverte que ce câble
J’ai acheté ce câble pour une liaison amplificateur enceintes,sur la recommandation d’un ami l’ayant acquis récemment.Ayant essayé beaucoup de câbles,même très cher,5000€ par exemple,je l’ai commandé pour voir en comparaison de mon Furutech actuel.Branché par l’intermédiaire de fourches et bananes la première impression fut mitigée!Le furutech étant branché sans bananes je tentais une écoute dans ces conditions,et là,surprise ,ce câble est étonnant,sa qualité en dehors d’un équilibre et d’une dynamique sans faille,est une aération du à une impression de moindre distorsion ,subjective bien sûr ,mais l’écoute est d’une précision jamais entendu sur mon système.Voila un achat que je ne suis pas près de regretter.Si j’avais pu j’aurais mis 10
Julien P.
Pratique
Simple et accessible. Impacte à la mesure la forme de la courbe de fréquence dans les basses. réduit un peu une légère bosse d'impédance dans les medium (Profondeur de l'enceinte ?)
Ne vole pas, ne se désagrège pas.
Julien P.
Bornier costaut
Et un peu trop gros à mon gout. Sur une petite biblio ça prends de la place !! Mais ceci dit c'est du solide et si on prend la peine de faire une feuillure, ça finit bien l'enceinte
Julien P.
Dommage pour le tout plastique (face avant, bornier) et attention à la soudure de ne pas faire fondre l'attache :)
Distorsion qui remonte sous les 2200hz, mais une coupure à 2kHz en LR24 fait très bien l'affaire !
Attention de ne pas trop lui en demander en terme de puissance, rapport à la disto, mais pour un salon 40m2 c'est parfait !
Julien P.
DAYTON AUDIO DC130BS-4 Classic Speaker Driver Midbass Shielded 30W 4 Ohm 92dB 55Hz - 4000Hz Ø14cm Dayton Classic woofers are designed for 3-way construction as low-midrange speakers, but can also be used as subwoofers. Their versatility means they can be used in both closed...
Fait bien le taf :)
Pour une petite biblio à pas cher, fait très bien l'affaire. La distorsion remonte malheureusement assez facilement dès 1500hz, mais une coupure franche type LR4 peut maitriser ça.
Son petit diamètre est parfait pour une directivité propre et un raccord autour de 2kHz.
L'extension dans les basses n'est pas folle, mais en surlitrant ou en baissant la Fs de l'event, on obtient une jolie courbe "façon clos" qui va très bien une fois posé sur une étagère proche du mur arrière.
Un bon soldat selon moi ! Voir le projet tritix MT (anglophone)
Julien P.
Pratique et propre
Feuilles très pratiques à découper (Cutter + ciseaux) ça permet d'avoir l'isolation bien ajustée à la forme de l'enceinte. J'ai complété la colle avec de la néoprène en spray de peur que la plaque ce détache. Ceci dit j'aurais pu l'éviter car le poids du goudron n'est pas si important que ça.
Très content de mon achat, ça donne une finition superbe à l'intérieur de l'enceinte !
Damien P.
Du lourd
Un vrai upgrade de câbles par rapport aux classiques de grandes marques à prix équivalent. Conquis par la qualité des connecteurs, j'ai acheté 4 paires de des Elecaudio rc-901 pour monter des stratos maison. Un régal
Damien P.
Joli
Beau petit câble court, plutôt fin. Prix compact pour une valeur sûre.
Damien P.
Female Jack 3.5mm Stereo 4 Pins Connector Gold Plated Ø4mm (Unit) This connector will allow you to design your own 3.5mm audio jack cables. This one benefits from gold plated contacts, ensuring both good electrical conductivity and resistance...
Moyen
Pas le top niveau qualité, mais il faut faut dire qu'il n'y a pas beaucoup de choix question prise femelle à ce niveau de prix. Utilisé comme interconnexion "originale" de câble de masse pour pouvoir permuter rapidement entre deux différents câbles de platine vinyle "maison".
