By buying this product you get 241 loyalty points
The Denafrips Arcas is a high-end streamer featuring carefully selected components to deliver exceptional sound quality. Its components include a UPOCC O-Core transformer, a custom oven-controlled crystal oscillator (OCXO), a unique proprietary streamer module with an ARM Cortex Quad-Core processor, and an FPGA/CPLD chip with galvanic isolation. The Arcas is compatible with numerous protocols such as Roon Bridge, HQPlayer NAA, Airplay, and DLNA to offer a variety of configuration options. The network connection is made via an RJ45 Ethernet port, while the signal output can be made via numerous digital ports: 2x AES/EBU, coaxial SPDIF, Toslink optical, or I2S LVDS via HDMI or USB-B. Other connectors allow you to connect an external clock or play local files via USB Host or TF card slot. This network player is capable of delivering up to 32-bit 384kHz and DSD512 via its I2S outputs, providing ultra-high-resolution streaming to the DAC in your Hi-Fi system.
The Denafrips Arcas does not support standalone network playback (it cannot directly access streaming services) and requires the use of a third-party application (such as BubbleUPnP, Mconnect, Roon, or Audirvana, for example) for music control and playback.
Proprietary streamer module developed by Denafrips with AMR Cortex quad-core processor and high-quality quartz oscillator.
Deliberate design aimed at removing the EMI filter for sound quality adjustment exclusive to the new Denafrips product.
O-Core 60VA shielded transformer, manufactured in-house by Denafrips using high-purity copper.
Temperature-compensated crystal oscillators for digital signal processing.
Benefit from Denafrips' years of experience in digital signal processing, integrated into an FGPA chip. Galvanic isolation via optocoupler.
OEM electrolytic capacitors compliant with Denafrips specifications. High-bias linear power regulator.
| 1 | 2x AES/EBU output |
| 2 | I2S output via HDMI LVDS |
| 3 | I2S output via USB-B |
| 4 | Toslink optical output |
| 5 | Coaxial output |
| 6 | External clock input 49.152M |
| 7 | External clock input 45.1584M |
| 8 | TF card slot |
| 9 | RJ45 Ethernet port |
| 10 | 2x USB Host Port |
| 11 | AC power input |
| Specifications | |
| Product type | Streamer Digital transport |
| Ethernet | RJ45 |
| Inputs | Ethernet TF card slot 2x USB Host ports |
| Outputs | 2x AES/EU output 1x I2S via HDMI LVDS 1x I2S via USB-B 1x Toslink optical 1x Coaxial |
| Supported sample rates | Optical Toslink, SPDIF coaxial, AES/EBU outputs: PCM up to 24-bit 192kHz, DSD DoP64 I2S output via HDMI: PCM up to 32-bit 384kHz, DSD DoP64, DSD up to DSD512 |
| Supported streaming protocols | Roon Bridge, HQPlayer NAA, Airplay (16/44.1kHz), DLNA (16/44.1kHz) |
| General | |
| Power supply | AC115V/60Hz, AC230V/50Hz |
| Energy consumption | ≤ 20W |
| Dimensions | 215 x 230 x 45mm |
| Weight | 3.5kg |
| Color | Silver |
| Package | 1x Denafrips Arcas |
| Input | Micro SD |
| Input | USB |
| Input | RJ45 |
| Output | Optical Toslink |
| Output | Coaxial SPDIF |
| Output | USB |
| Output | I2S LVDS via HDMI |
| Output | AES/EBU |
| DAC / ADC Chip | NC |
| Max sampling rate | 384kHz |
| Color | Silver |
| Remote Control | No |
| Streaming services & Network protocols | DLNA |
| Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
| Streaming services & Network protocols | AirPlay |
| Streaming services & Network protocols | HQPlayer NAA |
